driveline vibration fix write up..................may work for you too.
Discussion in 'Technical Chat' started by tacomaman06, Mar 2, 2009.
  1. Jan 23, 2013 at 8:18 AM
    #101
    AZarchitect
    AZarchitect Well-Known Member
    Mesa
    01 PreRunner TRD SR5 2x4
    Stock
    Same here Shane! Did you figure out what it was?
  2. Feb 7, 2013 at 5:04 PM
    #102
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    hope some of you guys can help me out. I have a 2006 dcsb prerunner with just over 100K miles
    I installed a skyjacker 2'' leveling kit up front drove it around for a while and everything was good
    I installed the toytec TSB AAL(I do not have TSB springs, they said it was fine, just a difference in length). I am having a nasty very noticeable vibration around 5 mph and between 20-30. I tried the carrier bearing drop, and I don't believe it helped much or at all, so I took that out. I bought 3 degree axle shims, and installed those, vibrations are still there. I put the carrier bearing drop back in, and vibrations are still there? Are there any other suggestions? I am just about ready to remove the AAL.
    Here are pics of the install (I know there are no bump stops on there, I wanted to be able to remove the centering pins before cutting it)
    does it matter if my carrier bearing seems to have moved toward the back a little bit?
  3. Feb 9, 2013 at 9:54 PM
    #103
    BamaToy1997
    Bill
    Navarre, FL
    I think I saw a similar thread talking about this and I posted this suggestion there as well. Since it seems that different thicknesses are sometimes required depending on factors such as lifts and other mods, being able to use varying thicknesses of metal would help. If you used alignment shims, similar to the ones below, you could save some effort by just loosening the support bolts enough to fit the correct thickness (Or your test thickness) of shims, then just tighten up and go. Need less angle? Add a thin 1/64" shim. Need more angle? Take out a 1/32" shim and replace with a 1/64".....etc.
  4. Mar 2, 2013 at 5:04 PM
    #104
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    I second the above. I could not find 1/4" aluminum flat stock, so I bought 1/8" and put two in on each side. No difference. Took one out of each side and the vibrations are completely gone! I have the Toytec 1 1/2 " AAL without the TSB and 5100's up front at 1.75" and had tried the 3* shims (actually made it worse). YMMV.
  5. Mar 3, 2013 at 2:36 PM
    #105
    Basshunter
    Basshunter Idaho
    When you grab the driveline how much play should the carrier brg have in it?mine has a lot of up and down play, I thought these should be fairly tight so driveline doesn't start a vibration. Thx for any replies.
  6. Aug 11, 2013 at 8:58 AM
    #106
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
  7. Sep 13, 2013 at 1:06 PM
    #107
    ink junky
    TACO LOVER
    TEXAS
    Anybody know where I can get some of these exact spacers?
  8. Sep 18, 2013 at 10:36 PM
    #108
    Man Overboard
    Man Overboard Member
    2005 SR5 Prerunner
  9. Feb 25, 2014 at 2:52 AM
    #109
    xrricky
    xrricky Member
    Rick
    05 tacoma trd off road
    3 inch leveling kit, 33" bfg mud terrain on black american racing wheels
    My 05 taco is lifted 4" there is real bad vibrations from 1- 15km/hr
    What size spacers should I install? Is 1/4" enough for a 4" lift??
  10. Feb 25, 2014 at 10:45 AM
    #110
    ppna1984
    ppna1984 New Member
    Mexico
    12 doublecab 4x4
    3" lifted Rancho 9000XL Shocks with myRide. 33X12.50R18 Open Country M/T
    I think that you should try with different measures, Is good to start with 1/4, but I think that you must install maybe 1".
  11. May 2, 2014 at 11:43 PM
    #111
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
  12. Jun 11, 2014 at 5:30 PM
    #112
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  13. Jul 7, 2014 at 7:38 AM
    #113
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
  14. Sep 2, 2014 at 12:35 PM
    #114
    Yota Man
    Yota Man Taco enthusiast
    Cole
    Red Deer, Alberta
    '14 TRD Sport Storm Trooper
    3" Revtech leveling kit, 17x9 XD Revolvers on 275/70/R17 BFG K02s, smoked mirror signals, Spyder tail lights with aftermarket tint, Bulletproof Fabricating grill, debadged everything, trifecta tonneau cover, Flowmaster 40 series cat back exhaust with 4'' MBRP exhaust tip, Black headlight mod and tint, L.E.D. reverse, license, and all interior lights, AJT shifter, more to come.
    So I have my taco leveled out with 3" up front and 1" in rear. I've had this vibration for months recently it has gotten to be a very violent vibe at 60km/h. The dealer couldn't help me out and I spent a couple hundo on getting my wheels balanced with a road force balancer. It helped for a couple of days. Well I just did this mod to my truck and it worked wonders. It cost me 8.50$ in hardware and 10 minutes of my time to cut some spacers and drill a couple holes and mount them. Absolutely no vibration at all I could not be happier. Thanks a shit ton for this thread
    KeystoneGoodie likes this.
  15. Sep 2, 2014 at 1:29 PM
    #115
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    How did you know much angle to make your spacers?
    Where can I purchase these kind of spacers?
  16. Sep 2, 2014 at 2:44 PM
    #116
    Yota Man
    Cole
    Red Deer, Alberta
  17. Oct 12, 2014 at 8:45 PM
    #117
    burl51
    burl51 Active Member
    SF BAY AREA
    2014 TACOMA SR5 4X4
    STILL NEW
    Well at 500 miles had a vibe took to capitol Toyota San Jose. They told me this is normal WTF huh. I took it back a second time 1200 miles talked with the shop foreman he went for a ride with me said something was not right. Brought it back to have it looked at Service manager said nothing they could do could not find anything wrong. Asked to talk with the shop foreman because I did not believe the sleezy service manager. Service manager told me I already told you there is nothing wrong with your truck. Guess I am going to have to escalate this to a higher level. If anyone has had a dealer fix the 50 to 60 mph shutter vibe fix please let the Tacoma world know. We need to stick together. Maybe Toyota will listen to the masses. Oh yea 3000 miles and getting worse. One more thing Vinny service manager said he never heard of a vibration problem with tacomas.
    Burl
    fullback likes this.
  18. Oct 13, 2014 at 7:40 AM
    #118
    Yota Man
    Cole
    Red Deer, Alberta
    I've made more and more spacers because the vibration came back. Same thing is happening to me man. If It isn't fixed soon I'm gonna lose my shit .
  19. Jan 21, 2015 at 12:56 PM
    #119
    SilverComa
    SilverComa Active Member
    Austin, TX
    2012 Silver Tacoma Pre
  20. Jan 27, 2015 at 5:27 AM
    #120
    SSTX
    SSTX Active Member
    Stu
    NE Texas
    15 DCSB TRD Off Road 4x4 Blue Ribbon
    N-Fab Nerf Bars, Undercover Flex tonneau cover, Weathertechs, tailgate and receiver hitch locks matched to factory ignition key.
    My 2013 DCSB Sport 4x4 (19k miles, all stock, original tires) is at the dealer today for the same issues. Minor takeoff shudder, driveline vibration anywhere between 40-80mph that's bad enough to blur images in the rear view mirrors. First trip to Toyota service they formally acknowleged the vibration was there and was abnormal, so I guess I lucked out there. Their initial attempt at a fix doesn't sound very encouraging, new rear leaf springs under warranty and they had to order an inclinometer to check/reset the pinion angle? I guess we'll see this afternoon.....I still suspect the u-joints/carrier bearing.
    ETA - The service writer has already used the old "some of this vibration is a normal characteristic" line.........
