Driveline Vibration. Need HELP!
Discussion in 'Technical Chat' started by nujerzidevil, Apr 15, 2015.
  1. Apr 24, 2015 at 2:14 PM
    nujerzidevil
    nujerzidevil [OP] Well-Known Member
    NJ
    2011 TRD Sport
    5100's OME 885x TSB - ICON 3 leaf AVID BOLT ON SLIDERS SCS SR8 HANKOOK MT 285/70/17 Tepui Kukenam RTT mounted on ATO bed bars
    Is anyone using a 3 leaf icon AAL with a 4 leaf TSB ?
  2. Apr 26, 2015 at 9:54 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
  3. Apr 27, 2015 at 12:16 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Did you happen to check your ujoints? I would only be focused on the angle between the rear diff and the center bearing, the angle between the tcase and that center bearing would not have changed lifitng the truck, and dropping that carrier bearing will only screw up the angle worse. I just installed an fj80 axle and we pointed the pinion a few degrees down from pointing right at that center bearing and i am vibe free, and we didnt touch anything else. The interesting part about the 80 axle is its offset to the right by 3inchs so pinion angles critical.
  4. Apr 27, 2015 at 5:05 PM
    nujerzidevil
    NJ
    2011 TRD Sport
    Everything is so conflicting that I read. I guess it's just going to be a trail and error situation right now. I was curious if anyone out there has the same rear setup as me and to see if they got any vibrations.. And what fixed it.
    Wouldn't a faulty u joint cause a vibration at any speed? I'm also thinking it's not because I have good movement when I disconnect the driveshaft.
  5. Apr 27, 2015 at 6:28 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Sub'd for possible future diagnosis...
  6. Apr 28, 2015 at 4:15 AM
    slander
    Hickory, NC
    A bad u joint will cause vibration when you are on the gas and if its really bad when you are off. Lowering the carrier bearing is a band aid that moves the angle further towards the tcase. What you need is some degree shims and leave the pinion 3 or 4 degrees down to account for axle wrap.
    If you have a welder, you can cut the perches off and weld some new perches on with the axle at the correct angle.
  7. Apr 28, 2015 at 4:43 AM
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    sub'd....some good info here
  8. Apr 29, 2015 at 4:33 AM
    nujerzidevil
    NJ
    2011 TRD Sport
    I have 3 degree shims pointing pinion up, thicker end of the shim towards the rear. I do admit my vibration decreaed after installing them. Vibration before shims were from take off till about 30 mph. After installation vibration only at take off till about 10 mph.
  9. Apr 29, 2015 at 6:04 AM
    slander
    Hickory, NC
    How bad are they? If they are just shaking the rear view mirror a bit up to 10mph i would call that mitigated! You wont get much less vibes than that unless you install a traction bar which may be a little overkill depending on how you use your truck.
  10. Apr 29, 2015 at 2:48 PM
    nujerzidevil
    NJ
    2011 TRD Sport
    Lol no it's not shaking my mirror. It's a shudder, it's felt throughout the truck. Can I live with it? Sure if I had to I would. But I do think it can be eliminated. Yes it's very annoying to keep going under there and change shims and adjust the cb. I want to go to a lower shim or take it out completely but would like some advice with my angles that I posted where to go next.
    If it really is axle wrap, why would it start happening after I lifted the truck and not stock?
  11. Apr 30, 2015 at 7:43 PM
    justrynarip
    justrynarip Well-Known Member
    Bryan
    Detroit, MI
    09 TRD Sport
    OME lift, AAL, 17" ultra phantom wheels, 32" goodyear wrangler tires, OEM running boards, custom grille, doug thorley long tube headers, URD mark III exhaust with magnaflow muffler, TRD CAI, on demand backup camera switch
    If it's axle wrap, it was happening before the lift too but you just didn't notice it because the pinion angle was OK. If you are getting vibes at low speeds w/out being on the gas too much, I wouldn't attribute it to axle wrap, since that's only going to affect upon heavy torque. By the way, I removed my carrier bearing drop and now vibes are pretty much gone. Again, I have the stock 3 leaf with an AAL. My angles are 3 degrees from output to first shaft, 0.2 degrees from first to second shaft, and 2.2 degrees from second shaft to pinion. I'd say that's pretty good because my pinion U-joint phasing is cancelling out my output U-joint phasing, where the middle joint is essentially acting as a straight shaft. I think my problem is solved now.
    Matt.loup likes this.
  12. May 1, 2015 at 1:20 PM
    justrynarip
    Bryan
    Detroit, MI
    09 TRD Sport
    After driving around some more, I found that the vibes are still there, but just not as bad as they were before. It was never that bad, just a little shuttering as I approach a stop.
  13. May 23, 2015 at 11:18 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Where is everyone purchasing the Axle Shims?
  14. May 23, 2015 at 2:25 PM
    nujerzidevil
    NJ
    2011 TRD Sport
    I bought mine from headstrong but wheelers has steel shims if that's what your looking for.
  15. May 23, 2015 at 10:33 PM
    #35
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    To be honest, I'm not too sure what it is I'm looking for...except for eliminating the nasty vibration I'm getting. I just had my driveshaft serviced(all 3 unjointed replaced, new carrier bearing, etc) and now my vibrations are happening around 20mph and increase a bit the faster I go. I'm not too sure what I need to do.
  16. May 23, 2015 at 11:14 PM
    #36
    fourpointTRD
    fourpointTRD Well-Known Member
    Humboldt, CA
    14 DCSB TRD OR 4WD
    Bilstein 5100s x4, OME 883 with 1/4 inch spacer on driver's side, OME TP04 leaf spring trim packer, Wheeler's Superbumps rear, black FJ Trail team wheels, Gorilla Wheel Locks (73631T), Huskyliners xact contour, Rockymounts Clutch SD and Driveshaft, Toyota OEM Bedmat, Plasti-dipped badges and front emblem
    Good info on here!
  17. May 24, 2015 at 6:30 PM
    #37
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    What tool did you all use to determine the angles & where can I buy it?
  18. May 24, 2015 at 6:40 PM
    #38
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  19. May 24, 2015 at 7:00 PM
    #39
    fourpointTRD
    Humboldt, CA
    14 DCSB TRD OR 4WD
    I tried out the clinometer app today, but it seemed kind of tricky, getting a consistent reading.
  20. May 24, 2015 at 7:06 PM
    #40
    Brent Waldman
    Brent Waldman Active Member
    Brent
    Grand Junction Colorado
    2005 Tacoma TRD Off Road
    2.5 in lift
    Pick up a tom woods one piece drive shaft with a double cv at the output shaft. No more vibration issues. Not sure why toyota keeps using a carrier bearing other than clearance. Just more parts to have problems with.
