driveline vibration with 6" or just 3"
Discussion in 'Suspension' started by allrsdup, Oct 28, 2007.
  1. Oct 28, 2007 at 7:19 AM
    allrsdup
    allrsdup [OP] Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    so i see that a lot of people are getting vibrations with 3" lifts. anyone with 6" lift have any input as too if they are experiencing any vibrations and how they fixed the problem?
  2. Oct 28, 2007 at 10:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Most likely witha 6" lift, you will experience some sort of vibration.
    Each situation is different and each persons 'repair' is different - pending a variety of things..... You really can't plan a 'fix' ahead of time. I would research a bit first, install lift, and make your own judgements of what you need to do.
    Here's a good webpage with ds angle information:
    http://www.4xshaft.com/techinfo.html
    Good Luck!
