Driveline vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nelz1, Oct 29, 2007.
  1. Oct 29, 2007 at 5:03 AM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    I have founf that a pipe clamp around the driveshaft (in the outermost runout) has lessened the vibration alot!!
  2. Oct 29, 2007 at 10:03 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Can you post some pics for the less mechanically inclined so we can see what you're talking about?
  3. Oct 29, 2007 at 10:30 AM
    Nelz1
    Boston
    I have no pics but all I did was use a hose clamp large enough for the driveshaft. I found the clamps in the plumbing dept at homedepot.
    I used a runout gauge a found my rear driveshaft to be out alot so it was wobbling when driving. I put the clamp on in exactly that spot with the tightining screw directly oppose the max runout.(in hopes it would counter balance that wobble)
    So my low end vibe at 20 30 and 40mph is nearly gone..
    with some tweaking readjustment of the band or a bit more or less weight in that area I think It may be taken care of.
    I measured my pinion angles and they were perfect and my center carrier bearing was also checked to be alligned with front and rear pinions.
    Look around there alot of info floating out there(maybe not toyota specific though)
    good luck
  4. Oct 29, 2007 at 11:17 AM
    nd
    Nate
    Greenville, SC
    cool, thanks for teh instructions
  5. Oct 29, 2007 at 11:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not to bust your bubble...but sounds like you have other issues and/or this is a bandaid of sorts. Not really sure what a hose clamp is gonna accomplish -from a technical perspective.
    If you thought the driveshaft was out of balance - why didn't you just get it re-balanced?
  6. Oct 29, 2007 at 11:32 AM
    Nelz1
    Boston
    The clamp is a weight and the bench balancing will do the same job (balance the shaft).
  7. Oct 29, 2007 at 11:46 AM
    Janster
    Jandy
    Lancaster, PA
    It's a bandaid...... and won't last. How long do you think that hose clamp will last before it gets loose and/or flies off?
    Sorry - just not something I would do. I'd pay the extra money and take my driveshaft to a reputable driveshaft shop and have it checked/rebalanced.
  8. Oct 29, 2007 at 3:25 PM
    fitter565
    fitter565 Active Member
    Nelz1, Heres another idea to help your balancing. Go to a tire shop and get a few oz's of the stick on wheel weights. They come in 1/4 oz segments. I would weigh the band clamp and then add or subtract the weights till you find the sweet spot.
  9. Oct 29, 2007 at 4:11 PM
    Nelz1
    Boston
    Thanks I was considering that and it makes the most sense....a liitle more caressing and she'll be happy girl..
    once this is ironed out its time to screw it all up with a lift and wheels..
  10. Mar 27, 2008 at 3:33 PM
    04asphalt
    04asphalt Well-Known Member
    PreRunner
    because I'm having this vibration problem and I NEED A SOLUTION:(
  11. Mar 27, 2008 at 3:55 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    If this isn't covered by the warranty, then I second what someone else said, and go to a drive line shop and have it rebalanced. Excess Vibration in the drive line can cause parts to fatigue quicker, and not to mention, can be very uncomfortable.
  12. Mar 27, 2008 at 5:32 PM
    Coreyjon
    Upstate, Ny
    Roger dodger you old codger :D
  13. Mar 28, 2008 at 3:56 PM
    AM300
    AM300 Member
    08 Taco 4x4 SR5
    Have you tried another dealer?
  14. Nov 13, 2008 at 1:59 PM
    TRDATER
    TRDATER MASTER KNUCKLE BLEEDER
    RUST BELT, OHIO
    2009 007 TRD
    ICONS FRT AND REARS BABY, HIDS, OFFROAD WITH SPORT HOOD. 285-70-17 M/TS
    The clamp will work as a weight to balance the shaft, i would recommend sending it out to get balanced. Vibrations are not good for tailshaft bushings nor seals
