Driver side door hard to open
Discussion in '1st Gen. Tacomas (1995-2004)' started by zbadboy, Nov 19, 2022.
  1. Nov 19, 2022 at 10:48 AM
    zbadboy
    zbadboy [OP] Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    I know this is a common problem on these trucks. I searched and found the thread provided below. The second post mentions the clip that holds the tension rod in place but does not mention the part number or source for the part. After taking my door panel off I noticed mine was broke and is what is causing the problem. Does anyone know the part number and source. Thanks
    https://www.tacomaworld.com/threads/driver-and-passenger-side-doors-hard-to-open.346456/
  2. Nov 26, 2022 at 10:05 AM
    zbadboy
    Arizona
    Palomino Camper
    Maybe if I reword this I can get some help. Can someone post a schematic of the drivers side interior door parts. I need the part number or source for the clip that holds the rod between the exterior door handle and the interior one. Thanks
  3. Nov 26, 2022 at 3:24 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
  4. Nov 27, 2022 at 9:10 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Head on over to Toyota | Parts Catalogs | PartSouq and plug in your VIN number. Next, click on BODY
    From there, scroll down the page until you see the diagrams for the front door. Click on each one until you get to the one you want.
    NOTE: Example images above are from a 2002. The numbering (6751-6754) for the front door may differ from your results.
