Drivers door upper hinge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bogatzi, May 1, 2015.
  1. May 1, 2015 at 6:26 PM
    Bogatzi
    Bogatzi [OP] Active Member
    Simcoe, Ontario
    2011 DCLB TRD Sport
    Has anyone had to replace their door hinge? My upper hinge is sloppy. The hinge bracket moves excessively around the hinge pin.
    I noticed little pieces of metal coming out where the hinge pin meets the hinge bracket.
    I am curious if just the pin, or the entire hinge has to be replaced.
    Thanks
    Bogatzi
  2. May 2, 2015 at 7:10 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Probably replace the entire hinge. The pieces of metal coming out is probably a bushing of some sort.
    This is on a 2011. Damn what are you driving through to cause all of that damage? It looks like shit. Have you ever washed it?
  3. May 2, 2015 at 7:40 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Wut?
    Not familiar with white lithium grease, huh?
  4. May 2, 2015 at 12:27 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    good old fashioned 30weight oil works best in places like this and its a lot less of a mess
  5. May 2, 2015 at 1:03 PM
    Bogatzi
    Simcoe, Ontario
    2011 DCLB TRD Sport
    It does look pretty cruddy. White lithium grease it is, as well as anything else that settled in it. Here are some better pictures, one a lot cleaner. In the first picture, you can see a piece of metal coming up from the area between the pin and the bracket. The second picture shows one of the pieces of metal that came out.
  6. May 3, 2015 at 9:54 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Actually more familiar than I would like to admit. I have usually seen it applied a little more judiciously, like where it is needed rather than coat everything in the vicinity. Either way it looks like shit! :)
    DouginNC likes this.
  7. May 3, 2015 at 9:58 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    In my opinion (looking at the second set of pictures) The hinge bushings are shot. I doubt they can be replaced if you could even source them. You will probably need to get a new hinge or at least one from a junker.
  8. May 3, 2015 at 4:02 PM
    Bogatzi
    Simcoe, Ontario
    2011 DCLB TRD Sport
    Thanks Jimmyh, I guess I'm making a trip to the dealership.
