Drivers side popping noise on rough terrain.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rowan11b, Apr 7, 2018.
  1. Apr 7, 2018 at 8:30 AM
    Rowan11b
    Rowan11b [OP] Well-Known Member
    2017 dcsb trd or
    https://youtu.be/aCnarWD4TF4
    Also does it while slowly turning occasionally, especially after backing out of my driveway. I've heard CV axle bind, but I only have about 1.5in of lift and it did it while stock. I've heard needle bearing but it does it in 4x4. I've heard a cracked crash bar mount since I get a simiar pop when jacking the front end up, but I don't see anything. I've heard lca bushings but they appear intact and fine. Everything is tight.
    Dealer says it's because I installed coilovers and are already trying to weasel out of helping me before even seeing the truck, last time I brought it in the tech drove the hell out of my truck in the parking lot and said the noise was stuff rolling around in the cab. Typical Larry h Miller dealership garbage.
    Any solutions?
  2. Apr 7, 2018 at 8:36 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did you check skid plate bolts?
  3. Apr 7, 2018 at 8:37 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Sway bar link probably
  4. Apr 7, 2018 at 8:40 AM
    Rowan11b
    2017 dcsb trd or
    Already looened them.l, and did it before and after I installed a pro skid.
  5. Apr 7, 2018 at 8:45 AM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
  6. Apr 7, 2018 at 8:45 AM
    na8rboy
    WI
    It definitely sounds metal on metal. Lot of others have had cab mount issues.
  7. Apr 7, 2018 at 10:02 AM
    Rowan11b
    2017 dcsb trd or
  8. Apr 7, 2018 at 10:12 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    That's a lot of popping...
    How much lift?
    Stock UCAs?
    Maybe the spindle hitting the coil during droop.
  9. Apr 7, 2018 at 10:17 AM
    Rowan11b
    2017 dcsb trd or
    Jba's and 1.5-1.75in from coilovers. I don't think so, happens occasionally on flat pavement aswell.
  10. Jun 9, 2018 at 10:53 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Did you figure this out?
  11. Jun 10, 2018 at 2:52 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    To me, it sounds like something is swinging around and banging on something...
