Driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by currierstaco, May 5, 2011.
  1. May 5, 2011 at 9:57 PM
    currierstaco
    currierstaco [OP] Active Member
    Little Rock AFB
    05 sport pkg 3in lift on 20s and terra grappl
    spyder headlights, hids all around, painted bug deflector and window gaurds, 20s and terra grapplers, ready lift kit front, add a leaf rear, led tails and third, billet grille top and bottom, 2 polk audio mm1240dvc subs behind rear seat, hifonics 1000.1 amp, jvc deck, power acoustics 5 farad capacitor.
    Does anyone know where to get a one piece driveshat for an 05 dbl cab 4x4 taco. Need to get rid of my carrier bearing
  2. May 5, 2011 at 10:06 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    try tom woods custom drive shafts
  3. May 5, 2011 at 11:13 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    X2!! Tom Woods is a crap shoot! Sometimes the shaft he builds has vibration problems. The last thing you need is to deal with that type of thing long distance.
    For a driveshaft? Buy local! That way if any issues arises they can resolve it on the spot!
    If you have to go out of state? Try Ebay there was a guy that sells custom shafts for about $315 shipped.
  4. May 6, 2011 at 4:59 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I think the DC requires too long of a shaft to be one piece?? maybe someone knows...
  5. May 6, 2011 at 9:56 AM
    DevL
    DevL Well-Known Member
    Uh.... no. Not true.
  6. May 6, 2011 at 12:07 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    Tom Woods and dont look back.
    quality stuff, they guarantee their work, free shipping. What else do you need?
    i got one of theirs in my front and a 1 piece in the rear also - no vibs. I had 2 one piece DS from them - one before I had a crawler and one after (had to get it shortened 8")
    I sent my original 1 piece back to TW - they resized it, new joints and shipping for well under $100. Local guy wanted almost $200 just to resize without new joints.
  7. May 6, 2011 at 7:30 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I installed a Tom Wood one piece rear drive shaft a few week ago. Have not have a problem with it. Less that a 1/2 hour install with hand tools. 10 bolts to remove the old two piece shaft and 8 bolts to install the new one.
  8. May 9, 2011 at 1:30 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    i had a one peace on my truck for 3 days and i have a dbl cab..... needless to say that i forgot about it and hit a waterfall streight on and smashed it in half because it hangs lower than the two peice....
  9. May 9, 2011 at 8:33 AM
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    why are you needing to get rid of the carrier bearing?
