Driving over 100 miles in 4th
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RubberTank, Oct 30, 2011.
  1. Oct 30, 2011 at 1:16 PM
    RubberTank
    RubberTank [OP] Well-Known Member
    Thousand oaks, CA
    i didnt notice until I got to where i was going, but I drove over 100 miles in 4th gear, I have an auto tranny, I dont know much about this, but is it a problem or am i fine?
  2. Oct 30, 2011 at 1:20 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    How fast were you going? Our manual goes up to 65mph in 4th.
    Did you purposely have it in 4th, or did your automatic transmission stick in 4th?
  3. Oct 30, 2011 at 1:20 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I did the same thing when the truck was new. I probably drove farther than you did. Then I discovered why I was getting poor gas mileage. LOL. I have almost 36000 on it now and no problems. I think if you drove under 70mph you are probably alright.
  4. Oct 30, 2011 at 1:22 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    It a toyota....they can run at almost red line for hours.
  5. Oct 30, 2011 at 1:22 PM
    MrsPib
    Angie
    Texas
    Where in the world do you hide, that I have never seen your firey red Tacoma on I-35?
  6. Oct 30, 2011 at 1:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You didnt hurt anything, 'cept your gas millage.
    And even on the rev limiter! :) I treated my first gen like it was a diesel when off roading. Foot to the floor, letting the rev limiter keep the RPM's in check.
  7. Oct 30, 2011 at 1:23 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You had O/D Off? I've driven around 100 in 4th without a tow package. If you have the Tow Package you should be alright because you have the trans cooler. You should be alright.
  8. Oct 30, 2011 at 1:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2nd gens dont have an OD on/off button. They have 4th gear, then "D" (5th, also known in some circles as "Over Drive").
  9. Oct 30, 2011 at 1:47 PM
    paidfor
    Austin, TX
    2013 TRD OR 4x4
    I am in far north Austin off of 620. Mainley go to the work and home. To the lake for fishing or to Mason for hunting. Went to Cabelas this morning. I have a ton of stuff changed on the Tacoma now, so it looks a little different.
  10. Oct 30, 2011 at 1:53 PM
    Warhorseforever
    Will
    Sand Lapper
    That's true I didn't realize that he was 2nd gen.
  11. Oct 30, 2011 at 2:25 PM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2022 Lunar Rock Trail Edition
    Screen ProTech kit, JDMCAR center console organizer, JDMCAR Center Console Armrest Cushion, Toyota door sill protectors, Black Toyota tailgate letter inserts
    So, when pulling a trailer (such as my boat), I should be in 4th? That's what I've been doing, but wanted to be sure I was doing right.
  12. Oct 30, 2011 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont have to be in 4th. If it holds 5th, then keep it there. I only go into 4th if the tranny tries to "hunt" between gears. I tow my boat (3000#) in 5th all the time.
  13. Oct 30, 2011 at 2:30 PM
    Warhorseforever
    Will
    Sand Lapper
    x2 my 1st gen 3.4 V6 will stay in 5th for the most part of my trips to where I land it usually flat interstates and back roads. When it starts shifting up and down and won't stay in a gear that when you turn O/D off, or take it out of D in the case of 2nd gens, as to not over work the trans.
  14. Oct 30, 2011 at 2:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 1st gens have a 4 speed. 4th is the Over dive gear.
  15. Oct 30, 2011 at 4:45 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Reminds me of my 2005 the first day I had it (after trading in my 2001 for it). I took it to Baja the very night I got it, and the '01 had a 4 speed auto... I didn't know the '05 had a 5 speed auto. When I saw 4 and D next to each other on the display, I didn't know there was another gear 'under' the D! I drove over 200 miles the day I got my '05, at highway speed... and it was so smooth and nice in 4th gear, I didn't give it a second thought! The next day I thumbed through the owner's manual and had a Homer Simpson moment... "DOH"!! When you see that there is an L and 2 next to each other (and no '1')... that helps too!
