DRL Dimmer Problem?
Discussion in 'Lighting' started by Gage Dent, Jul 19, 2015.
  1. Jul 19, 2015 at 7:49 PM
    Gage Dent
    Gage Dent [OP] Member
    Gage
    Giles County, Virginia
    2013 MGM DC Tundra TRD Rock Warrior
    Tonight, I noticed that when I start the engine, put it in Drive and release the emergency brake. The DRLs stay dim instead of brightening. My headlights work fine and my side marker lights work fine. But a few times I can leave my lights in the DRL position and turn the ignition off then on and they don't even come on after I start driving. There is only 30,000 on my truck and it's never done this. They have always been dim until I put it in gear then they become bright so just kind of confused on what to do. Help is greatly early appreciated!
  2. Jul 19, 2015 at 8:00 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    One of the filaments could be burned out. Try replacing the bulbs and see what happens.
  3. Jul 19, 2015 at 8:07 PM
    Gage Dent
    Gage
    Alright. I'll try that tomorrow morning. That would cause both to not work correctly?
  4. Jul 19, 2015 at 8:11 PM
    Gage Dent
    Gage
    And I probably should point this out as well. I'm no expert so I could have caused this problem. I just recently replaced my side marker lights with 194 led bulbs. Could they be pulling too much power their way?
  5. Jul 19, 2015 at 8:15 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    DRL's are designed to run at a reduced voltage and should never be as bright as your headlight's on hi beam.
  6. Jul 19, 2015 at 8:19 PM
    Gage Dent
    Gage
    Yea, true. but, I mean...they are pretty bright when on by themselves. And then dim when headlights are on. But now they are staying dim the whole time
  7. Jul 19, 2015 at 8:22 PM
    adamiata
    adamiata --
    Auburn, AL
    You know you have a helluva good truck when you have to find something so silly "wrong" with it. Lots of folks like that here.
    Just drive the thing man!
    Gage Dent [OP] likes this.
  8. Jul 19, 2015 at 8:24 PM
    Cruzintaco
    Cruzintaco Well-Known Member
    Sanjose
    2001 PreRunner TRD
    K&N drop in filter EGR Silencer Delete More MODS soon to come!
    take a few pictures to compare the lights and post them here, cause my 01 has them too and when I turn on my headlights on (low beam) its a bit brighter than the DRLs cause I think thats what youre talking about Id post to show but I dont have my truck at the moment
  9. Jul 19, 2015 at 8:25 PM
    Cruzintaco
    Sanjose
    2001 PreRunner TRD
    wait so they dim when you turn on all the lights?
  10. Jul 19, 2015 at 8:28 PM
    Gage Dent
    Gage
    Yea I know man! I run my DRLs from sunrise to sunset! I just don't want my love for LEDs to have caused this minor detail.
    And my headlights are definitely brighter than my drls. This is just about the dimming of the drls
  11. Jul 19, 2015 at 8:31 PM
    Gage Dent
    Gage
    Yea I mean they dim down a little bit. Just like if I leave my drls in the on position and start the truck. They come on dim then brighten up once I start rolling
  12. Aug 18, 2015 at 3:59 PM
    Cruzintaco
    Sanjose
    2001 PreRunner TRD
    Maybe check the connections.. cause it seems like theres a power draw coming someplace.
    Also do they dim again when you stop? cause like you jsut mentioned they get brighter when you start rolling, cause im guessing when you roll, obviously the Alternator charges too soo its providing more power to the lights
  13. Aug 25, 2015 at 7:36 PM
    Flyryguy78
    Flyryguy78 Well-Known Member
    Winter Park CO
    '13 TRD OFF-ROAD ACLB 6spd.
    TX BAJA Suspension. Black 16" TRD wheels. BFG AT TA/KO winter tires
    I'm having same issues with switchbacks at the moment. White leds on with e brake. Dim Amber on when e brake released. 6 spd manual
