DRL Failures, Locker Indicator Flashing, and Chasing Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Dec 11, 2019.
  1. Dec 14, 2019 at 8:19 AM
    #341
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    For those of you also following along with interest as opposed to just trolling; another interesting legal argument here would be estoppel and/or waiver based on Toyota and their agent’s (the dealership) actions thus far. Haven’t looked deeply into that based on this fact pattern, but Toyota did initially authorize the repair and subsequently denied it without performing any further diagnosis.
    Tsinajinii and xxTacocaTxx like this.
  2. Dec 14, 2019 at 8:20 AM
    #342
    therealprotaco
    Gilbert, AZ
    Sounds good, I appreciate your opinion!
  3. Dec 14, 2019 at 8:20 AM
    #343
    therealprotaco
    Gilbert, AZ
    I think we’ll have to agree to disagree on this one!
  4. Dec 14, 2019 at 8:22 AM
    #344
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    In any case, I wish you luck.
  5. Dec 14, 2019 at 8:23 AM
    #345
    therealprotaco
    Gilbert, AZ
    Thanks!
    Superdave1.0 likes this.
  6. Dec 14, 2019 at 8:24 AM
    #346
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    Just messing with you. I think there's a lot more regarding that excerpt, given the context. Such as, a manufacturer can't deny your warranty claim for a head unit going out simply because you changed the wheels.
  7. Dec 14, 2019 at 8:25 AM
    #347
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Took the words out of my mouth.
    His mods are COMPLETELY related to the issue at hand. If Toyota ends up paying for this, they are extremely nice and just want to get OP out of their hair.
  8. Dec 14, 2019 at 8:25 AM
    #348
    therealprotaco
    Gilbert, AZ
    I know, and I appreciate that in addition to just having some fun on TW, you actually added some good info!
  9. Dec 14, 2019 at 8:28 AM
    #349
    therealprotaco
    Gilbert, AZ
    So it is your opinion that if the further scope testing with all aftermarket parts uninstalled shows the same (or substantially similar) voltage/signal noise, Toyota should not repair or at least perform further diagnosis? That would be in spite of the fact that the evidence they are relying on (went looking for to support their pre-conceived conclusion) would have been found to be totally irrelevant?
    xxTacocaTxx likes this.
  10. Dec 14, 2019 at 8:30 AM
    #350
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    This is covered under the landmark case "Johnson v Ford Motor Company" in 1974 which set the legal precedent of "no takesy backsies"
  11. Dec 14, 2019 at 8:34 AM
    #351
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Toyota having a few people look at an Internet forum is not the same as someone specifically looking at your issue with a running light.
  12. Dec 14, 2019 at 8:34 AM
    #352
    Superdave1.0
    SoCal
    Yes, because if this were an issue we would have heard about it. As of now, YOU are the only one with a DRL blowing out. Your lighting mods could have caused damage to other components in line. Body modules, relays, fuses, whole fuse blocks can go out. Even if say you return to stock, and the problem is still there, it's likely from one of your mods. It is common sense, you directly modified the system that is broken. Again, If you did lighting mods and your transmission blew out, Toyota wouldn't have denied anything.
  13. Dec 14, 2019 at 8:44 AM
    #353
    therealprotaco
    Gilbert, AZ
    Thank you for the thoughtful response. I really do appreciate it.
    I have had several discussions about burnt out DRLs, with people on this forum but it certainly does not seem to be a “common” occurrence. Interestingly, despite other individuals having documented DRL issues (including at least one with multiple failures), the dealership did mention that the FTS searched their database for the entire country and found no other instances where a 3rd gen Tacoma required multiple DRL (headlight housing) replacements.
    That means that either the database has a documentation lag or Toyota (the FTS) was lying again. I have no way to know which it is at this point so I haven’t raised the issue.
    Edit: I can only recall one with documented multiple failures. I wanted to correct the mistake right away.
  14. Dec 14, 2019 at 8:46 AM
    #354
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  15. Dec 14, 2019 at 8:48 AM
    #355
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    Pretty sure this covered in in the first, and many other posts.
    No mods to factory wiring. The only mod that wasn't plug and play is raptor lights, which used an add-a-fuse.
    therealprotaco[OP] likes this.
  16. Dec 14, 2019 at 8:50 AM
    #356
    therealprotaco
    Gilbert, AZ
    I wanted to correct the clerical error in my prior post, I can only recall one conversation with another owner with multiple documented DRL failures. Just wanted to clarify ASAP since I know you are following along so intently!
  17. Dec 14, 2019 at 8:53 AM
    #357
    xxTacocaTxx
    Best Slope CO
    Just because you have the attention span of an ADD 8 year old doesn't mean everyone else does. How could you possibly know what other forum members have or have not read?
  18. Dec 14, 2019 at 8:54 AM
    #358
    Superdave1.0
    SoCal
    Did that other member have raptor lights too?
  19. Dec 14, 2019 at 8:59 AM
    #359
    therealprotaco
    Gilbert, AZ
    As it happens I don't know. They reached out to me before this all started. I will ask and see how they have them installed as well and post up here when they respond.
  20. Dec 14, 2019 at 9:01 AM
    #360
    xxTacocaTxx
    Best Slope CO
    Did you make it to the end, where it says, " To be clear, the FTC explicitly said: “the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.”"
    OP is willing to PAY OUT OF HIS POCKET for the diagnostic testing needed to figure that out.
