DRL Failures, Locker Indicator Flashing, and Chasing Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Dec 11, 2019.
  1. Dec 14, 2019 at 9:02 AM
    #361
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    I added the following update to the beginning of the first post in the hopes that people will at least make it that far before responding......
    "UPDATE:
    After initially declining to allow them to do so, Toyota decided to allow the dealership to perform additional diagnosis at my expense. The dealership will be performing the same oscilloscope test as previously performed with each aftermarket part disconnected, one by one. If the test shows the same or substantially similar voltage/signal noise as was previously present after all of the parts are removed, I would expect Toyota to perform further diagnosis and/or repair under warranty. If the signal noise drops to the same level as the stock truck they tested, I will remove whatever aftermarket part was causing the signal noise and repair the vehicle myself at my expense."
  2. Dec 14, 2019 at 9:05 AM
    #362
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    They already figured that out and denied the repair. Case closed go home. But I will compliment the OP to say he is one relentless mofo that won't back down when he feels he is correct. For that the OP is good in my book. Still don't agree with him tho.
    :fistbump:
    BillsSR5 and boynoyce like this.
  3. Dec 14, 2019 at 9:06 AM
    #363
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    OK, let's look at this saga from another angle. The OP is willing to pay the dealer, out of pocket, to find out which of his many mods is the culprit (and why did Toyota initially say no to that? Isn't that how dealers make most of their money, in the service bay?). Isn't he doing the TW world a great service to warn you all about a faulty after market light, once it is identified?
    44-16 Taco, Toki, Skydvrr and 4 others like this.
  4. Dec 14, 2019 at 9:07 AM
    #364
    therealprotaco
    Gilbert, AZ
    Totally respect that. If people didn't disagree with each other lawyers wouldn't exist!
    Superdave1.0[QUOTED] likes this.
  5. Dec 14, 2019 at 9:16 AM
    #365
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Sounds about right to me..
    made me thing a little more on how i have my crap wired up.
    :fingerscrossed:
    HEY ; OP put a update with the answer on the first page so we don't need to read 20 pages to find out.
    therealprotaco[OP] likes this.
  6. Dec 14, 2019 at 9:29 AM
    #366
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Quote the whole paragraph.
    BillsSR5 likes this.
  7. Dec 14, 2019 at 9:38 AM
    #367
    splitbolt
    NW Arkansas
    Agreed...
    I wish I would have found a lawyer with his fire when I was looking into a MMA lawsuit over LF fluid.
  8. Dec 14, 2019 at 9:38 AM
    #368
    therealprotaco
    Gilbert, AZ
    They do have raptor lights. They were installed after their first failure but before their 2nd failure. They had the + to an add a fuse and the - was wired to the DRL ground directly.
  9. Dec 14, 2019 at 9:52 AM
    #369
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
  10. Dec 14, 2019 at 10:02 AM
    #370
    therealprotaco
    Gilbert, AZ
    I have not, mostly because I see no reason spend all the time redacting PII just to “feed the troll” so to speak. Parts are listed in the first post. All but the raptor lights are plug and play, installed per-manufacturer (the aftermarket manufacturer) instructions. The raptor lights are installed with an add-a-fuse into IGN 2 and grounded to the body ground for the battery.
    The dealer notes say nothing other than what has already been posted. That being said, just to satisfy your apparent curiosity, let me take some screenshots of the Toyota Owner’s app service history notes. Doing some yard work at the moment but I’ll tag you in the post later today when I post them up.
  11. Dec 14, 2019 at 10:12 AM
    #371
    aussiecrum
    aussiecrum Active Member
    Phoenix
    Still shopping for it
    I suspect Toyota said no to that because if they retest and the results come in that the mods aren’t at fault or they can’t prove it’s their fault, they’re on the hook to repair this issue and any future issues. They made a couple hundred on the test and lost 1000 for a headlight. It’s like giving a blank check to OP saying it’s not the mods fault so any future failures can be argued the same way.
    OP I wish you the best and hope you succeed...but the issue is obviously complex with lots of moving pieces. Electrical issues are like trying to pin down ghosts. It seems unlikely that the mods aren’t at least partially to blame in some respect. That said, Toyota can absorb some loss. Good luck.
  12. Dec 14, 2019 at 10:45 AM
    #372
    therealprotaco
    Gilbert, AZ
  13. Dec 14, 2019 at 10:55 AM
    #373
    quick67coupe
    quick67coupe New Member
    Landon
    2019 TRD Offroad
    When testing I think it may be worth taking a closer look at the ground and make sure there is no positive voltage introduced there some how. Also it should be confirmed (if not already done) that truly is a ground. If nothing else make sure both leads are disconnected during the tests.
    Also in case i missed it do we know what component in the DRL failed to cause it to stop functioning? Do you know if it is the same component of the DRL in each of the failures? My suspicion is no but it would be an interesting data-point if that was looked into further.
    Best of luck
  14. Dec 14, 2019 at 10:58 AM
    #374
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I know this can sound funny, but I've cleared up many issues in past rigs, with adding grounds. Heavy gauge wire to frame. Then reground the Engine, chassis, and body.
  15. Dec 14, 2019 at 11:00 AM
    #375
    therealprotaco
    Gilbert, AZ
    Just for kicks, here is another screenshot of the Toyota owners app from
    When I had a front end vibration and paid to have the dealership perform a road force balance on the aftermarket tires instead of asking them to diagnose the vibration under warranty.
    Not sure why it says the ToyotaCare service was a customer pay. It was not.
  16. Dec 14, 2019 at 11:01 AM
    #376
    therealprotaco
    Gilbert, AZ
    I did that on my ‘03 WRX. Grounding kit solved all kinds of issues.
  17. Dec 14, 2019 at 11:05 AM
    #377
    therealprotaco
    Gilbert, AZ
    I don’t have any information on what the failure was in the first two DRLs other than what is in the notes above. I’m not sure if Toyota did any type of “autopsy” or not.
  18. Dec 14, 2019 at 11:05 AM
    #378
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It’s either a warranty charge or customer pay, so an aftermarket tire rebalancing wouldn’t be warranty work. They probably marked it customer pay and didn’t charge you for it is my guess.
  19. Dec 14, 2019 at 11:06 AM
    #379
    therealprotaco
    Gilbert, AZ
    Interesting. I did pay for the road force balance since it was performed at my request. The 10k Syn service was the normal 10k ToyotaCare. That I did not pay for.
  20. Dec 14, 2019 at 11:07 AM
    #380
    T4RFTMFW
    Nope. The failure was an open circuit in the assembly, so they fixed that and it worked.
    If they had the time and inclination with pattern failures to diagnose the causation and not the symptom (repeat issues with DRLs) then we’d be here today doing the same thing with the oscilloscope.
    A lot of technicians treat the failure and not the problem, mainly because they don’t get paid to nerd out unless a customer is paying for it.
