DRL Failures, Locker Indicator Flashing, and Chasing Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Dec 11, 2019.
  1. Dec 11, 2019 at 6:54 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I'm going to go out on a limp and say it's your raptor lights. How did you install them?
    BillsSR5, 12TRDTacoma, Toki and 3 others like this.
  2. Dec 11, 2019 at 7:07 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    it would be brilliant to pull them all and test. If the problem is still there it cannot be explained away as a non-oem component or issue with the stock wiring....but I'm no EE just a troubleshooter diy type A.
  3. Dec 11, 2019 at 7:15 PM
    MaHoTex
    MaHoTex Well-Known Member
    2019 Silver Tacoma TRD Sport
    Yep. The shitty part is now that Toyota has it documented that this aftermarket stuff caused some damage (true or not) it is highly unlikely they will ever cover anything electrical related.
  4. Dec 11, 2019 at 7:47 PM
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Stocklocker[QUOTED] likes this.
  5. Dec 11, 2019 at 7:50 PM
    therealprotaco
    Gilbert, AZ
    The Raptor lights are installed with an “add-a-fuse”, I believe 5A. The rest of the lights were all “plug and play” into the stock wiring.
  6. Dec 11, 2019 at 7:53 PM
    Couesfanatic
    Couesfanatic Well-Known Member
    Which dealer? I also have the Baja fogs but no problems with my DRL's. I have no other aftermarket electronic parts though.
  7. Dec 11, 2019 at 7:54 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    OP....unlike Stocklocker who is a Canadian electrician....which is slightly more prestigious than being an Afghani gynecologist which is slightly below being an American professional canine anal sac drainer.... I am well versed in diagnosing these types of things.
    See...I am a professional victim of perpetual bad karma. It’s the by product of being a dick. You can close this thread now because I’m gonna tell you the real reason your DRL keeps shitting the bed...
    Ready?
    The Universe hates raptor lights. You took a perfectly good truck and defiled it with the running lights of the biggest piece of shit bro dozer on the planet.
    Your DRL will continue to fail until you take those rotten things off and apologize to the Universe for trying to emulate a fucking Ford.
  8. Dec 11, 2019 at 7:56 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Is there a chance that one of the connector pins pushed back out when you connected the plastic watertight connectors? A bad connection can do weird things with noise and spikes. When you can, do a tug test and make sure none of the wires will move or pull out when the connectors are pushed together and locked.
    some ideas:
    My first suspect would be the raptor lights as well, as they are likely the most cheaply-constructed. Baja Designs has a pretty solid reputation and a lot of guys run them. You could have a defective one, but I’d suspect them last.
    How often do you use your winch and is it very well-connected to the negative battery terminal? Was the winch installed at the time of the first failures?Starting and stopping a winch motor creates a voltage spike that can be a problem if the winch in not properly grounded through a low impedance connection to the negative.
    therealprotaco[OP] likes this.
  9. Dec 11, 2019 at 7:57 PM
    therealprotaco
    Gilbert, AZ
    That is the biggest reason I want them to run the test with the aftermarket parts unplugged. I just don’t want to have to worry about warranty coverage being denied if my radio decides to shit the bed a year from now.
    I have been telling Toyota from the start, I’m 100% willing to pay for any faults they can prove were caused by aftermarket parts. Unfortunately as you can see from the dealership emails, they did a lot of guessing but didn’t do this scope test until yesterday. The truck has been in the shop for about 20 days now and they even approved the repair at one point.
  10. Dec 11, 2019 at 7:57 PM
    Stocklocker
    17TRDORDCSBAT
    Are the raptor lights wired in parallel with the DRLs? I can see that being a problem for the DRLs. Don’t the DRLs also dim when the headlight turn on? Maybe the dimmer circuit is being fried by the raptor lights?
  11. Dec 11, 2019 at 8:00 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    TOYOTA!
    Sorry I couldn't resist!
    Back to your regularly scheduled thread!
  12. Dec 11, 2019 at 8:00 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    There is nothing concise about a two paragraph email. That’s too damn long. If you can’t explain it in 2 sentences then you need a conversation. Doesn’t have to be a meeting, a phone call will do. But trying to convey two paragraphs of info to nearly a dozen people is difficult. Having them all get the message, interpret it and be on the same page is nearly impossible in email.
  13. Dec 11, 2019 at 8:01 PM
    Stocklocker
    17TRDORDCSBAT
    I called a buddy and we are turning off power exports to California tonight in retaliation. Better gas up and get yourself some Chem-lights, because it’s gonna get real fuckin dark.
  14. Dec 11, 2019 at 8:05 PM
    therealprotaco
    Gilbert, AZ
    The connectors were very tight after installation but I haven't checked them since then. I will definitely doublecheck when i get the truck back.
    Winch is rarely used and very well connected to the battery terminals. The winch was last used several weeks before failure #3 and then a couple times since (it took almost 2 months for the FTS to get out here to do a diagnosis)
    They are wired into a totally separate circuit and grounded to a body ground near the fuse box. They are installed with an "add-a-fuse" into the IGN2 fuse under the hood.
  15. Dec 11, 2019 at 8:05 PM
    #35
    therealprotaco
    Gilbert, AZ
    No need to apologize, a good informative TW thread wouldn't be legit without a little "BS"
  16. Dec 11, 2019 at 8:11 PM
    #36
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I don't believe the DRL dim. I think they just look like they dim as a result of the headlamp being much brighter.
  17. Dec 11, 2019 at 8:13 PM
    #37
    skiploder
    FZJ80/XJ LS swap
    You cut our power, we’ll cut our penicillin exports. How will Canada deal with its rampant STD problem without good old America antibiotics? While you are all peeing goopy liquid fire, we’ll then boycott maple syrup imports, and then Canada will implode.
    You guys still buying milk in plastic bags up there in Canuckistan? WTH?
  18. Dec 11, 2019 at 8:13 PM
    #38
    therealprotaco
    Gilbert, AZ
    They actually do dim from what I understand. The DRL relay does something in the grounding and changes the brightness. @caribe makaira was explaining it to me when this whole saga first started.
    I wish they did shut off totally when the headlights were turned on. The truck looked pretty stupid at night with only one DRL on. I was able to turn them both off during the day through the radio.
  19. Dec 11, 2019 at 8:15 PM
    #39
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    You can dim them in the radio if you want.
  20. Dec 11, 2019 at 8:18 PM
    #40
    therealprotaco
    Gilbert, AZ
    This wiring diagram is also one of the reasons that I question what is going on here. If the ground for both DRLs are run in parallel, why is only one of them dying time after time?
