DRL Failures, Locker Indicator Flashing, and Chasing Electrical Gremlins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Dec 11, 2019.
  1. Dec 16, 2019 at 3:43 PM
    #461
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sorry, a bit off topic but does that device allow you to hook it up to your battery then you run all your accessories (ditch lights, cb radio, light bar etc) directly to it? I've been looking for something like that as my wiring is getting to be a mess as I have like 6 power cables going to my battery, lol.
    GreyBaldTaco likes this.
  2. Dec 16, 2019 at 3:53 PM
    #462
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    You can check out the currently online users section of TW and see the thousands, if not tens of thousands, of hits bots make on this site every day. It wouldn't take more than a basic set of algorithms coupled with GL fingerprinting to identify in specificity who we all are, where we live, and where our vehicles are serviced. This information could be handed over to paying customers, like Toyota, for aggregate use or to identify potential areas for loss. The internet is freakily powerful and forums like this offer a huge, dynamic repository of data.
  3. Dec 16, 2019 at 4:00 PM
    #463
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Even more simple to note, this thread has had a lot of "guests" watching. Right now as I type there are 28 members and 12 guests watching the page. Who are all these guests?
  4. Dec 16, 2019 at 4:05 PM
    #464
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    @therealprotaco
    Maybe unrelated - maybe not?
    This story is based on AC (Not DC). But LED's are kinda new to this game. So Maybe something there? Anyway.
    I was talking to a fellow electrician about various jobs that we have been on. He told me the story of a commercial lighting job he installed where all of the fixtures were LED. Not sure if you know what a 3 Phase Service is? But in large installation's, it's commonplace to use 2 or 3 phases (120V +) and share a single neutral (120V -). Long story short, the installer was sharing the neutral on 3 different lighting circuits. Now here is the good part - After the install was complete, the electrician started turning on lights to make sure everything worked. Turned on the first switch - all the lights worked on that circuit. Turned on the second switch - weird sh!t started happening. He said that 5 fixtures were damaged before he gained enough senses to turn OFF the circuit. He told me that the problem was corrected by installing (2) more neutrals (so that each circuit had it's very own neutral).
    Maybe sharing grounds (on a DC Circuit) "could" have the same affect?
    Just FYI.
    MikeyD.25 and therealprotaco[OP] like this.
  5. Dec 16, 2019 at 4:08 PM
    #465
    TuRDLYFE
    2020 AG TRD Pro 6MT
  6. Dec 16, 2019 at 4:09 PM
    #466
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What year was this?
  7. Dec 16, 2019 at 4:10 PM
    #467
    Superdave1.0
    SoCal
    Say that S word one more time...
  8. Dec 16, 2019 at 4:11 PM
    #468
    PhenixFord
    Randy
    Arkansas
    My friend didn't really say. I suspect within the last couple?
  9. Dec 16, 2019 at 4:13 PM
    #469
    TuRDLYFE
    2020 AG TRD Pro 6MT
    LEDs are designed to run on low voltage, DC circuits. In AC applications, the bulbs require drivers that effectively bleed that voltage. For your buddy's application, the neutral lines needed to match the wire gauge for current carrying capacity and he sounds like he baked the drivers on those AC bulbs. Of note, if you don't have a driver, the LEDs on an AC circuit would switch on and off at the frequency of their parent circuit (in most cases, 60Hz). It's a helluva seizure-inducing light show if you've never seen it.
    Skydvrr likes this.
  10. Dec 16, 2019 at 4:16 PM
    #470
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    So you have confirmation on the noise source, but zero confirmation on the reason to the failure.
    On the equipment I work on, LED lights are common place and failure is common. We have JW Speaker headlamps that were failing regularly until they were updated. With these high powered LED lights the failure point was obvious. The driver circuit would burn up causing the output to diminish, yellow or shut off completely. On the smaller LED's, such as the DRL's there is seldom a visual clue to the reason for failure, but I would still look at the driver circuit as the main reason. Now whether there is an external source causing the failure, I can't say.
    I hope that in this case the problem is solved and you can move on.
  11. Dec 16, 2019 at 4:16 PM
    #471
    PhenixFord
    Randy
    Arkansas
    So you don't know anything about 3 Phase 4 wire circuits? The neutral only hast to be big enough for (1) single phase. Because every time you add an additional phase, you reduce the load on the neutral.
  12. Dec 16, 2019 at 4:21 PM
    #472
    splitbolt
    NW Arkansas
    He should have used 3-pole breaker and burned up more lights than he did.
  13. Dec 16, 2019 at 4:22 PM
    #473
    PhenixFord
    Randy
    Arkansas
    He never made it to the 3rd switch. :bananadead:
  14. Dec 16, 2019 at 4:26 PM
    #474
    PhenixFord
    Randy
    Arkansas
    I really don't know how they figured out that sharing the neutral was the culprit. This type of installation is quite common for large installs. Done quite a few myself.
  15. Dec 16, 2019 at 4:27 PM
    #475
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    each circuit is 'supposed' to have its own neutral.
    LEDs on an AC circuit use drivers to rectify into DC power (like your alternator) and smooth it out (capacitors, choke, similar to you cars battery)
    disclaimer: im not an electrician, just fascinated by that tingly feeling you get when you think all the power is off and touch the black wire...or red, or green, or blue, or whatever the ass before you installed.
  16. Dec 16, 2019 at 4:29 PM
    #476
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sorta sounds like he got 2 legs and no neutrals to those lights.
  17. Dec 16, 2019 at 4:35 PM
    #477
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Point being, sounds like his install was unbalanced. I presume he wired one phase to neutral on the first circuit. You only reduce the load on the neutral when all of the circuits are de-energized. If one is energized, in order to remain balanced, the second phase sends current back to the neutral bus. This, presumably, could have damaged each fixture's rectifier.
    Veejay Sharma, an Electrical Engineer with Samlex, wrote this great whitepaper on 120/240 VAC single split phase and milti-wire branch circuits. If you won't take my word for it, maybe he can shed some light on it... no pun intended.
  18. Dec 16, 2019 at 4:37 PM
    #478
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Thanks for all the additional info guys!
    Does anyone have an opinion on using diodes to keep feedback current out of the stock electronics? I’d like to have an ignition switched circuit to use but want to make sure it’s “shielded”. My thought is to have an add-a-fuse in the ign2 under the hood and a relay with a diode in between. I can then use that relay to trigger any other relays that I want to be switched.
  19. Dec 16, 2019 at 6:00 PM
    #479
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    It’s a nonlinear load. The neutral needs to be upsized. Quite common in the commercial/industrial world. I’m surprised an electrician did not know this.
  20. Dec 16, 2019 at 6:07 PM
    #480
    TuRDLYFE
    2020 AG TRD Pro 6MT
    Yup. Evidently I know nothing about 3Φ-4W installs though. ;)
