DRL
Discussion in 'Hawaii' started by justinitsuj, Feb 24, 2012.
  1. Feb 24, 2012 at 3:41 PM
    justinitsuj
    justinitsuj [OP] Well-Known Member
    Justin
    Mills illest
    Debadged//blacked out//6" fabtech//stubby//spintech//thule//wet okoles//weathertech floor mats//
    anyone on oahu immobilized their day time running lights? my truck is still pretty much new and don't want the bulbs to burn or melt the housing. Looking for someone to do that for me. Thanks!
  2. Feb 24, 2012 at 6:22 PM
    Murkules
    Murkules Well-Known Member
    Dane
    Hawaii
    2016 Tacoma TRD Offroad DCSB Super White
    What year Tacoma? I disabled mine just by pulling a plug and the HL still work fine when I switch it on.
  3. Feb 24, 2012 at 7:06 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Yeah I think Imma disable mine as well....Wanted to be able to just pull a fuse.
  4. Feb 24, 2012 at 7:25 PM
    Murkules
    Dane
    Hawaii
    Pulling the fuse won't work
  5. Feb 25, 2012 at 10:07 AM
    justinitsuj
    Justin
    Mills illest
    I thought there was mOre to do then just snip one wire?
  6. Feb 25, 2012 at 10:08 AM
    justinitsuj
    Justin
    Mills illest
    I have a 2011
  7. Feb 25, 2012 at 12:10 PM
    Murkules
    Dane
    Hawaii
    I have a 1st gen. It's a little more complicated for the 2nd gens. I'll see if I can find the thread
  8. Feb 25, 2012 at 12:20 PM
    Murkules
    Dane
    Hawaii
  9. Mar 2, 2012 at 3:28 AM
    09638 SCRAPER
    oahu,hawaii
    11 trd sport sr5 prerunner
    2% tint, 20% entire windshield tint, led bulbs, hids, debadged, grey plate covers, shaved antenna, alpine in dash, rockford t2 and amps, rockford highs and mids, 35x12.50x20 toyo mt's, 20x12 fuel octane's deep, 1.5 inch wheel spacers, camburg UCA's, 6" lift w/4" blocks & AAL, 3" body lift, open hood scoop, BHLM, painted emblem, K&N filters, weather tech mats. Next Mod: resevoir rear shocks, Vinyl camo wrap when I'm bored of the grey...
    get led replacements if you want the drl still, they dont get hot at all.
    if you dont want the drl dealer can turn off for around 100 by plugging it in to computer. remember that if you just undo the wire or take out the bulb your front turn signal wont work since it uses the same bulb.
  10. Mar 3, 2012 at 3:15 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    I switched mine over to LEDs so it wouldn't melt the plastic and so far so good. The LED's are dimmer than the filament bulbs though :(
  11. Mar 5, 2012 at 10:43 PM
    holokai
    holokai Well-Known Member
    Honolulu
    '12 PreRunner SR5 Access Cab
    Installed: OEM Bed Mat, Secondary Air Filter Delete/AFE/stock CAI elbow mod, LEDs ( Rear License Plate, Map, and Dome Lights), Ceramic Tint (Front 35%, Rear 27ish%), Viper Security, Image Dynamics Front Components, 4 channel Arc Audio Amp (rear channels bridged for sub), Kicker CVT 6.5 (yes, it's a tiny sub but it's enough to keep me happy), Headunit (Bluetooth and iPod/Pandora), EGR Window Visors, OEM Door Sill Protectors, Roll-N-Lock, Wet Okoles, Fog Lights with 2500k bulbs, UltraGauge EM, Spidertrax spacers, Smittybilt Side Steps, Tooter 2.7 Intake Manifold Spacer Upcoming: LCE Headers?
    Was it a hassle to install the resistors to keep the blink rate the same?
  12. Mar 6, 2012 at 11:37 AM
    808TRDTaco10
    Justin
    Big Island, Hawaii
    I didn't install any resistors. I have the hyper flash. :bananadead:
    Kinda used to it now to be honest.
  13. Mar 6, 2012 at 9:08 PM
    holokai
    Honolulu
    Shoots. Not sure how the cops on Oahu would like that; especially downtown/Waikiki. Guess I'll do the DRL LED mod when I get motivated to find a good place to mount the resistors and read through the threads :p
  14. Mar 11, 2012 at 5:55 PM
    justinitsuj
    Justin
    Mills illest
    is the hyper flash the only downside of those bulbs? thinking i might just go that route
  15. Mar 12, 2012 at 2:20 PM
    808TRDTaco10
    Justin
    Big Island, Hawaii
    No, they are also considerably more dim than the regular filament bulbs. I think the quality of the LEDS that I have in particular aren't the best though to be honest. Pretty big trade-off for not worrying about melted lenses but I'd might as well keep it that way after spending the dough on the LEDS.
  16. Mar 14, 2012 at 5:15 PM
    justinitsuj
    Justin
    Mills illest
    thanks for the info. Just switched my bulbs to the 3507's that i've been reading on the forums. A lot of people saying that it burns cooler then the 4157's so giving that a try first.
  17. Mar 14, 2012 at 11:05 PM
    ShaydenandDiezel
    ShaydenandDiezel Well-Known Member
    Hawaii
    TRD
    6 inch Pro Comp Suspension Lift. K&N intake. Air Raid throttle body spacer. 20 inch XD Diesel rims. 33x13.50 Irok tires. Single in dual out exhaust with SS tips.
    I spoke to leeward servco service department today an they said there is a retro part they can install so you don't melt the housing. They replace the plastic with glass. Not sure if this helps anyone. I am going to go in an get mine done.
  18. Mar 15, 2012 at 8:45 AM
    holokai
    Honolulu
    Thanks for following up! Let us know how it goes. . .
  19. Mar 15, 2012 at 12:31 PM
    808TRDTaco10
    Justin
    Big Island, Hawaii
    I think I should look into this. It just dawned on me that if I get into an accident the other person could point out my dim LED's and put me at fault. :eek:
  20. Mar 15, 2012 at 4:41 PM
    justinitsuj
    Justin
    Mills illest
    spoke to toyota leeward today and the guy informed me that they will only replace the housing if its under the 3 year or 36k miles. The extended warranty doesn't cover the melted headlights. He said any small sign of bubbling, take it in and they will replace it with the new piece that they just started carrying 3 months ago. Hope this helps anyone!
