drop bracket to Long travel?
Discussion in 'Long Travel Suspension' started by Grantman, Jun 1, 2014.
  1. Jun 1, 2014 at 10:22 PM
    Grantman
    Grantman [OP] Well-Known Member
    Grant
    Hampstead, NC
    2011 Tacoma 4X4 supercharged
    TRD supercharger
    I have a 6" BDS lift with Fox coil overs and custom leaf springs in the back. My question is, has anyone ever seen a truck go from a drop bracket lift to a long travel set up? I really like the height of the lift I have now but would love to have more travel. Would it be passable to use a long travel system with the drop bracket in place? That would be what I would really want to do, keep the height of the drop bracket and then get the extra travel with a long travel bolted on it.
    Any help, ideas, pictures, shops who could do the work, would be greatly appreciated. Thank you.
  2. Jun 1, 2014 at 10:23 PM
    Manwithoutaplan
    ID
  3. Jun 1, 2014 at 10:28 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  4. Jun 1, 2014 at 10:29 PM
    Manwithoutaplan
    ID
    what up homie :D.
    do you hear your name when someone mentions your name?
  5. Jun 1, 2014 at 10:30 PM
    PLC721
    Patrick
    Chandler, Az
    I heard you whispering my name so I got excited
  6. Jun 1, 2014 at 10:40 PM
    Manwithoutaplan
    ID
  7. Jun 1, 2014 at 10:41 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
  8. Jun 1, 2014 at 10:46 PM
    Grantman
    Grant
    Hampstead, NC
    TRD supercharger
    Why would that not work?
  9. Jun 1, 2014 at 10:59 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    That's not exactly true. You can bolt longtravel on to a drop bracket but be prepared to spend some money. If your spindles don't bolt up, you will need new custom fabbed ones that are the same length as your current ones. Also, you will need a custom shock length and it will be a little tough figuring that out. BUT! If you really want it to work, you can. I'd also gusset/strengthen the actual drop bracket while you are at it since it needs to be just as strong if not stronger than the original mounting area for the LCAs.
  10. Jun 1, 2014 at 11:03 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    im sorry i should have answered differently, see you can bolt it up to your db with some modifications (as i can see that was already mentioned)
    theres a picture somewhere that someone has done it, not sure if it was a 4x4 tho. it would be a bit expense. for the price of the already db lift and adding LT i would just sas the truck :cool:
  11. Jun 2, 2014 at 6:37 AM
    PLC721
    Patrick
    Chandler, Az
    It will bolt up 100%, but the problem is, besides being top heavy with a messed up COG is that the 4" lower crossmember will act as a point of leverage and twist when using the LT as it was intended.
