Dropping ATM Oil pan - Is this gasket okay?
Discussion in '1st Gen. Tacomas (1995-2004)' started by STree, Nov 5, 2011.
  1. Nov 5, 2011 at 11:24 AM
    STree
    STree [OP] Member
    Jacksonville, Fl
    02 PreRunner DBL Cab
    So I am dropping the pan today in conjunction with draining and filling the ATM fluid. This will be my first time dropping the pan. I am planning on purchasing the synthetic rubber gasket made my Fel-Pro (available locally at Advance Auto Parts). Link below with information on the technology:
    http://www.federalmogul.com/en/Afte...s/Fel-ProDrivetrain/AutomaticTransmissionPan/
    Does anyone have experience with this type of gasket? Is it okay to use? Would the use of a cork, regular rubber, Toyota gunk, or other aftermark FIPG be a better material?
    Thanks in advance.
  2. Nov 6, 2011 at 4:51 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    the website looks pretty legit if that tells you anything. id try it.
  3. Nov 6, 2011 at 11:28 AM
    hulkit
    hulkit Well-Known Member
    sacramento ca
    2000 tacoma 2.4l automatic
    ya i dropped my pan for the first time and got a normal gasket
    just fyi when u pull the pan down the original gasket will be stuck to iether side and when i say stuck i mean REALLLY stuck if u can manage to take it out with the pan it will be much easier to clean it off then on the transmission part
    oh ya and dont try and take a knife to it try not to scratch the oilpan too much use alcohol or some other thing to loosen the old gasket off
    oh ya are you getting a trans filter also? cause i would recommend changing it if your down there
  4. Nov 6, 2011 at 11:32 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i always used permatex silicone gasket maker in the grey color, my trans pan, both diffs, engine oil pan are all used with it and only my front diff leaks a few drops, but then again i do bash shit with it
    also first gen filters are magnetic and just clean off
  5. Nov 6, 2011 at 11:36 AM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    I've used Fel-pro cork gasket material with good results. I'd imagine that their rubber stuff is good too.
    Be careful stripping your old gasket material and stay away from any steel gasket scrapers. Those things are nothing but easy ways to gouge your gasket surfaces.
  6. Nov 6, 2011 at 1:29 PM
    x2468
    Would kitchen grade steal wool do the trick?
  7. Nov 6, 2011 at 1:42 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Gaskets are made to leak. Scrape your mating surfaces clean of all old gasket material. I use gasket scrapers, but if you don't have that availability, anything from a plastic or metal putty knife to a screw driver will do the job. As previously posted, be careful not to gouge the mating surfaces. It's hard not to scratch a lil, but gouges will be bad. Some sort of silicone gasket maker material will do the job, like RTV. Blue is for water pumps and valve covers, black RTV would be the best in your case. You don't need to put a whole lot on, just enough to create a seal. Be sure to get the correct torque spec for the pan bolts. If you don't have a torque wrench, I would use the rule of thumb. Take your 1/4" drive socket set with a long extension and hand tighten all the bolts evenly, once all bolts are hand tightened evenly, take your 1/4" ratchet and give then just a little snug. It may not seem like enough, but trust me it is. You don't want to snap a bolt. Once the pan is tightened all the way, take your finger and run it around the outside of the mating surfaces to spread and clean the excess material. Then add fluid, get it heated and running, and check for leaks.
  8. Nov 7, 2011 at 5:09 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i use the felpro gasket. ..no leaks.
  9. Nov 7, 2011 at 7:44 AM
    Bobber Bill
    Los Angeles, CA
    I always use 3M Roloc Scotch-Brite pads with my angle die grinder. Makes quick work of removing 30+ yr old gaskets. Do it that way if you have access to air tools. Just make sure you keep that scotch-brite moving and not in one spot for too long
  10. Nov 7, 2011 at 8:37 AM
    STree
    STree [OP] Member
    Jacksonville, Fl
    Good to know someone else has had success with this particular product. I didn't get a chance to perform the work this past weekend so it will have to wait until this weekend.
    Also, I plan on using a plastic putty knife to remove remnants of the old gasket. Would a Gasket Remover product aid in this process or is it really not worth it? Such as:
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Low-VOC-Gasket-Remover-Permatex_7740009-P_N2132_T|GRP2132_____
    Last Question, through my research on this topic, I noticed some posts about coating the plastic gasket with a form of High Tack Gasket Sealant on both top and bottom. In your opinion, is this warranted or perhaps overkill? Here's an example of the Gasket Sealant:
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_High-Tack&153;-Gasket-Sealant-Permatex_89016795-P_N2131_T|GRP2132_____
    Thank you to everyone who has replied. This site is a blessing.
  11. Nov 7, 2011 at 10:08 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i just used an old putty knife and a scotchbrite pad to get the RTV off. it was a pain in the ass. ..which is why i went with the felpro gasket instead of using RTV again.
    i'm not familiar with that gasket remover. ..it may be worth looking into and trying though ..anything to make getting that crap off easier would definitely be useful.
    as for the gasket sealant, i wouldn't use it.
    check this link out for more general info...
    http://home.centurytel.net/stevenjackie/transmission flush/tranny.html
  12. Nov 7, 2011 at 2:04 PM
    STree
    STree [OP] Member
    Jacksonville, Fl
    Thank you for the link. Did you follow the cooler line flush steps or just stop after dropping the pan and refilling?
  13. Nov 8, 2011 at 9:28 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    i personally let the dealer replace my tranny fluid. it's not something that i usually like to mess with. ...the only reason i dropped my pan was because it was leaking and the dealer wouldn't agree to use my felpro gasket instead of their FIPG to make the repair.
