dry filter/oiled filter which is better
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverTacoma, Jul 27, 2008.
  1. Jul 27, 2008 at 6:51 AM
    SilverTacoma
    SilverTacoma [OP] Member
    wisconsin
    07 Tacoma dblcab L/B
    stock so far
    hi i owned a 97 tacoma that was recalled by toyota. I just bought a used 07 dbl cab LB silver tacoma, I am going to be putting an intake on it, i read about the oiled filters and the dry air filters, and how it could mess up your MAF. my Question is can i use an oiled filter w/STOCK MAF, If i do and mess it up is there an after market MAF that can handle it? Or do I just stick with a dry one?.... I am also going to be installing a throttle body extender, put one in on my old truck and it really helped. thanks for all your help
    -SilverTacoma
  2. Jul 27, 2008 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Jul 27, 2008 at 8:17 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I will never use an oiled filter again. It's old technology being used on new vehicles with many electronic sensors and such that can be affected. With options like the AFE ProdryS or the AEM Dryflow (I have/had both), there's simply no reason to use an oiled filter.
  4. Jul 27, 2008 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    +1
    To add, they dont filter well, either. :)
  5. Jul 27, 2008 at 8:36 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Yeah, I left that to you with your link. BITOG rules.
  6. Jul 27, 2008 at 9:47 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    I also have an aFe Prodry... I LOVE IT!!!!
  7. Jul 27, 2008 at 9:59 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly, i wouldnt go with a complete intake.......its really a waste of money, and if you go with a filter like the afe pro dry s, and remove the secondary filter, your mileage will be above that of an intake, since intakes work in the upper rpms anyway. just food for thought. and also, dont go with a throttle body.....they wont do anything for a fuel injected motor, honestly. just trrying to save you some $ and get the best bang for your buck.:)
  8. Jul 27, 2008 at 1:18 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've run the oiled filters for many years in many vehicles and never had any problems with them. I cleaned them regularly (every 6 months). When I cleaned them, I let them dry overnight and was careful not to over-oil them.
    I'm currently running an AFE dry filter and have only owned it for a couple weeks and haven't made a full tank of gas through it yet. So - I don't have any feedback on it yet.
    I thought I'd give this dry-technology a try and see what happens.
    If this didn't exist - I'd still be buying the oiled filters.
  9. Jul 27, 2008 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have run the oiled filters for a long time as well. Until I started doing oil analysis. After I saw what kind of crap is getting into the engine from poor filtering, they ALL went in the garbage.
  10. Jul 27, 2008 at 3:31 PM
    Janster
    Jandy
    Lancaster, PA
    Oil analysis? What would that tell you?
    If you don't over-oil the filters, it shouldn't get into your engine. Besides that - if the oil gets into the engine, it'll burn up in combustion. It can't be anymore harmful than any crap in the gasoline we use.
  11. Jul 27, 2008 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oil analysis can tell you everything thats getting into the oil, aluminum, calcium, zinc, whatever is exposed to your engine. Oiled filters generally dont filter efficiently anything smaller than 50 microns. And, yes, dirt gets thru them. I have seen at least 10 intake tracts that had oiled filters on them, and they were DIRTY. On my last Tacoma, when I installed the super charger and saw my intake, I was like :eek:. And my filter was always oiled perfectly and cleaned regularly. Anything larger than 20 microns (from what I was told by a friend who is an engineer for what was once Garret Aviation) will cause wear in an internal combustion engine. When I saw how much dirt was in my intake, I pulled my head and did a full inspection. Now, Im in dirt every day, so I may be an "extreme" case, but since I have stopped useing oiled filters, my oil samples have been much better, with just the "regular" metals in the oil, and everything in the good range. You should get samples done every now and then if you want to keep an eye on what is going on inside your motor.
  12. Jul 27, 2008 at 4:14 PM
    Janster
    Jandy
    Lancaster, PA
    I don't have enough time in my schedule to keep my truck clean on the outside let alone time to do tests. I'd take termite inspections on my house as a higher priority than an air filter test (or even an engine oil analysis).
    No offense....
    But again - it can't be any worse than whatever 'stuff' is in the gasoline we run through the engine.
  13. Jul 27, 2008 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesnt take any time. When changeing the oil, put a little bit in a bottle that they give you, and throw it in the mail. We have a bunch of Heavy equipment, and put lots of miles on our vehicles, so I just throw my oil in with the rest. BUT, to each his own. :)
  14. Jul 27, 2008 at 5:34 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    LOL! You should know by now you can't win, Chris. :lalala:
    I, too, have done multiple oil samples and found high silicate counts while using K&N that went down after when using better filtering non-oiled filters. I just changed my oil recently but I do have analysis for the change prior to that so I'll be able to tell after my next oil change how well the AFE is working.
  15. Jul 27, 2008 at 5:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'm glad to hear that someone has seen the same results as me! Thanks, Wilson. :)
  16. Jul 28, 2008 at 9:43 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I don't see why anyone would run an oiled filter instead of dry at this point unless they couldn't find one to buy. I mean, they cost about the same except you have to buy an oil cleaning kit for the oiled ones. So that means there's more work to clean it, and the cleaning kit adds to the cost. When there's ones you can wash, rinse, and put it back in why bother with oiled ones? :laugh:
  17. Jul 28, 2008 at 10:21 AM
    Janster
    Jandy
    Lancaster, PA
    It's a matter of choice.
    It's the same reason why YOU (and everyone else here) decided to buy a Toyota instead of ****** something else.
    Who's to say the dry-flo filters (or any filter) is better than the others?
  18. Jul 28, 2008 at 10:25 AM
    piercedtiger
    Jon
    Southern Tier, NY
    ummmm.... because a dry filter is cheaper, easier to maintain, and has no chance of f'ing up your maf sensor because there is no oil? I said nothing about filtering. Simply the time and money involved in maintaining them and the fact a dry filter will never f'up your maf sensor. Seems like dry filters are better all the way around. (Guess maybe that's why OEM filters are never oiled? :rolleyes: )
  19. Jul 28, 2008 at 12:24 PM
    Janster
    Jandy
    Lancaster, PA
    Most people might look at it that way... but not everyone. Again - it's a choice. Lots of people use K&N's or other oiled filters. They have their own oppinions to use one or the other. As do I.....
    Are all AFE filters cheaper in ALL applications?
    Not everyone has problems with their MAF ....I never did.
    How much time do you really save in cleaning the AFE? I haven't cleaned mine yet, so I can't comment on if it saves time or not.
    OEM filters will never be high performance filters (oiled or dry)- they're too expensive.
  20. Jul 28, 2008 at 1:05 PM
    piercedtiger
    Jon
    Southern Tier, NY
    Well, wash, rinse dry, and put back in the AFE. I assume you have to do all of that AND apply oil to a K&N. And you mentioned letting it set for 24 hours. Gee, I don't think I can be without my truck for an entire day. I do these maintenance things between other errands and tasks, or after work. Losing it for 24 hours is hard to do most of the time. That also skews the cleaning time if we're comparing that here. :D
    Also, how much does the cleaning kit for the K&N cost? That was my main point. Dish soap and water I already have at home are all I need for the AFE or other dry filters. Don't need to spend more money on special oil/cleaners for dry filters. That alone makes the maintenance cheaper.
