DTRL Lens Melting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wizo, Mar 12, 2010.
  1. Mar 23, 2010 at 3:05 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    just sayin'
  2. Mar 23, 2010 at 3:08 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    why didnt you just switch to the halogen bulbs before you brought it to the dealer?! problem would have been solved. you are the 3rd person i have heard this happen to...very wierd as there are thousands of tacos running around out there w/ no problems.
  3. Mar 23, 2010 at 3:10 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Now that you spent all that time investigating the lense temps, etc, Toyota's factory DTRL setup will melt the lenses over time. I've read about it on other Tacoma forums and on the highlander forums as well (our other vehicle). They use bulbs that burn too hot or are just too close to the lenses. Another quality toyota part (yes, sore subject with me due to my front diff bearing).
  4. Mar 23, 2010 at 3:11 PM
    808trdsport
    808trdsport Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
    not really true. Stock bulbs did this to mine. I went to the dealer and they changed the whole headlight. I asked them if they plan to fix the problem so it won't happen again, and they said probably not. Unless Toyota deems it a problem. With all this safety issues in the news it may be time to tell them its a fire hazard.
    I forgot to mention I also have HID's installed and they gave me no problem at the dealership.
  5. Mar 23, 2010 at 3:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You are correct but I think it depends on what state you live in.:rolleyes: I know California has that law but here in NV where I live, they could care less.:cool:
  6. Mar 23, 2010 at 3:38 PM
    wizo
    wizo [OP] Well-Known Member
    Port St. John, FL
    09 PreRunner 2.7L
    2.5" Walker Evans C/O's, All Pro UCA's,
    Thanks I have printed this and reviewing.
    I wish I would have swapped back to stock but in all reality that is not whats causing the issue.
    Do you have any pictures? Also would you be willing to send me a copy of the repair order. This would help me greatly as my dealer claims they nor the Toyota rep have ever seen this happen.
  7. Mar 24, 2010 at 9:37 AM
    05Moose
    Jim
    With regard to Headlights (not auxiliary lighting like fog lights, aux lights, etc), the headlight laws are the same across all the States. Headlight laws are not State laws, they're Federal. Whether your local law enforcement cares or not is a whole different story.
  8. May 12, 2010 at 6:19 PM
    Pantherfan
    Pantherfan New Member
    Florida
    08 Prerunner SR5 Longbed
    I have Tac 08 with the same issue of burned in lens on the DTRL. It got factory lamps. I am out of warranty with respect to mileage. Any suggestion on a replacement lamp that will not cause this problem and is there a way to just replace the DTRL lens only? Any assistance would be great.
    Thanks
  9. May 12, 2010 at 6:28 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    i have a few extra sets of blinker lenses if you want one. all you would have to do is open up your headlights and replace them. very easy, preheat oven to 275, TURN OVEN OFF!, place headlight in oven for 10 min, take lense off, then install is reverse of removal!
  10. May 23, 2010 at 7:19 AM
    Kahunadave
    Kahunadave Well-Known Member
    Dave
    Orlando, FL
    05 DC PrernrTRD Sport
    K&N CAI-series 63, custom Billet Grille, Magnaflow exhaust, AR Tactic 17x8, Toyo A/T opencountry 265/70/17, Iridium plugs.
    You're kidding right?! :D .. I have an '05 ALL stock.. and YES the DRLs did the same thing after about 2-3 yrs..can't remember exactly when they started looking like Cr@p.. but i bought a pair of '07 headlamps w/a few broken tabs and was thinkn of switching out.
  11. Jul 20, 2010 at 11:21 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    This is my experience.
    I installed the DTRL mod on my '06 .... ran them for three years with no problem. The lenses as clear as the day I first drove it off the lot.
    I did the same on my 2010 this week. One thing I have done is replace the factory 4157 amber bulbs (12.8 volt/28.5 watts) with 3157 amber (12.8 volt/26.9 watts.)
    There doesn't appear in daylight to be any difference.
    I'll sit back and let the engineers chime in.
  12. Jul 27, 2010 at 12:07 AM
    wizo
    Port St. John, FL
    09 PreRunner 2.7L
    UPDATE:
    The dealer has replaced my headlights. They informed Toyota Corp has requested they do this and send them my old ones for inspection. The replacement was done last month (June) and I have not received any further communication from them. It is my guess they will not provide the results of their findings especially if they find a defect. I will be keeping a close eye on the lenses fro here on out.
    Also of note I had removed the HID kit and put the stock bulbs back in April. Even after this the lenses continued to melt.
  13. Jul 27, 2010 at 1:39 AM
    JKD
    JKD Well-Known Member
    Based on what I've read about this problem, I would be inclined to look for a LED bulb replacement solution for the turn/park indicators if I had DRL installed.
  14. Jul 27, 2010 at 3:01 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    I have done a search for both #4157 and #3157 amber LED with a wedge base ... no results. I don't expect it will be long before they become available.
  15. Jul 27, 2010 at 10:48 AM
    #35
    JKD
    I see 3157 wedge base bulbs in amber and other colors here and other places online.
  16. Jul 27, 2010 at 11:30 AM
    #36
    jpmorrisvb
    Jimmy
    Virginia Beach
    Thanks for the link man ...... I hadn't found that.
    Now .... wow .... $23 plus ... I'll stick with my dula filament #3157 .....
  17. Jul 27, 2010 at 2:11 PM
    #37
    TRDfly
    TRDfly Well-Known Member
    Traverse City, MI
    Silver 07 DC, TRD off-road....it's the bomb!!
    DRL, Black Headlight mod, H.I.D's, Wet Ass Seatcovers, White instrument cluster, Illuminated 4x4 switch.
    I did this Mod a year ago.....it's still on......no issues on an 07 TRD O.R.!
  18. Sep 14, 2010 at 11:13 AM
    #38
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    Res-erection: I have the same prob on my 09. At the dealer now and they said they've never seen this on Tacos but Higlanders had a problem with high beams melting the lens. I'm at 55K miles so they're contacting the extended warranty company for replacement. My bulbs are stock so if the exteneded warranty company doesnt cover it, the dealership will. This is a defect no matter how you look at it.
  19. Sep 14, 2010 at 11:20 AM
    #39
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Right, just in case I was the only one paying attention in school ;) HIDs are great because they provide a lot of light for very low power. 35, 55w is nothing. And they run MUCH cooler than a halogen because of this efficiency.
    So of course they aren't the problem, unless something is shorting or burning out - they'll run cooler than your stock bulbs!
    The only way they could cause a problem with your DTRL's is if they somehow interfered with the circuit the DTRL's are on... and they're completely separate, anyway, so I don't see how this is possible.
  20. Sep 14, 2010 at 11:24 AM
    #40
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    On the HIDs, HIDs are more efficient than halogens. HIDs are great at producing a ton of light with very little power, so of course they run cooler than your halogens. The dealer is dumb.
    Unless they're somehow forcing the DTRL's to run at a higher wattage when the HIDs are off (and on a separate circuit, aside from the relay to turn them on) this makes no sense.
    I have stock lights. Just to be sure, I can get my temp gun and see what temp my lenses are at after I get home from work for you. I suspect I'm running hot too (and will be installing a DTRL disable switch shortly.)
