DTRL Question
Discussion in 'Lighting' started by LoneStarTaco, Jul 13, 2014.
  1. Jul 13, 2014 at 2:42 PM
    LoneStarTaco
    LoneStarTaco [OP] Well-Known Member
    Skylar
    Longview
    01 Xtra Cab TRD 4x4 Std
    Toolbox, 265/70/16 BFG AT's
    I have been wanting to do the DTRL mod on my 06 tacoma but don't want to pay for the harness. I've been thinking about taking the positive wire from the factory DTRL and moving it into the third hole on the blinker. The third hole, that's currently empty, is power to the low power filament in the bulb. I jumped power from the running light socket into the third hole and it functions correctly and still allows the blinker function.
    My question is, will this have any bad effects? I know that my model headlight is prone to having the DTRL lens melt and that would probably happen even with the harness. Will this be more of a hazard than just the normal melting?
  2. Dec 21, 2015 at 7:32 PM
    gracianoh
    gracianoh Well-Known Member
    06 1e7 access cab 4x4
    I too want to know
  3. Dec 22, 2015 at 12:26 PM
    LoneStarTaco
    Skylar
    Longview
    I did it, and it hasn't had any problems.
  4. Dec 23, 2015 at 5:30 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I did this years ago and there's no problems.
    You're actually better off than having factory DTRL as this mod uses the lower power filament, so the bulb doesn't get as hot and will not melt the lens.
    When I did this I jumpered from the corner marker lights to the third empty hole for the power. I also cut and spliced the blinker wire into the corner marker light so both the front and side marker lights act as blinkers and DTRL.
    There's posts around here that explain this if that's confusing.
