Dual alternators
Discussion in 'Audio & Video' started by dicktation808, Feb 9, 2012.
  1. Feb 9, 2012 at 12:54 AM
    dicktation808
    dicktation808 [OP] Member
    Maka
    Kauai
    This might be a dumb question but would it be possible to install two alternators in a 2010 tacoma?
  2. Feb 9, 2012 at 5:26 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Is your engine on this site?
    http://www.nationsstarteralternator.com/Extreme-High-Amp-Output-Military-Applications-s/279.htm
    Google is your friend:p
    I'm not seeing any dual setups. There are some high output singles though. Why would you need two alternators anyway? With a high output alternator, dual batteries, and an isolator, you will be fine.
  3. Feb 9, 2012 at 6:11 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If you're pulling more than 130 amps (stock towing package alt) you're either doing something wrong or are a very VERY seasoned SPL competitor...and not likely using a Tacoma.
  4. Feb 9, 2012 at 6:57 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Inverters with a welding setup, or serious winching pull some juice.
  5. Feb 9, 2012 at 8:10 AM
    ItalynStylion
    Steven
    DFW, Tx.
    True, I didn't think about things other than audio (since we're in the audio section).
    Just curious, how much do large winches pull under load?
  6. Feb 9, 2012 at 9:23 AM
    DevL
    DevL Well-Known Member
    Up to 400-500 amps... thats why you have a second battery, not a second alternator. A second alternator in a tacoma is silly.
  7. Feb 9, 2012 at 9:33 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    superwinch lp8500 draws 320amps at full load.
  8. Feb 9, 2012 at 11:18 PM
    DevL
    Warn m8000 435 amps
    Warn Xd9000i 460 amps
    Warn 9.5xp 480 amps
    Warn m12000 440 amps
    Superwinch x9 420 amps
  9. Feb 10, 2012 at 12:01 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    If you have room for them, no it`s not impossible, find someone that`s good, to build you a bracket and can make sure your pulleys are aligned and you`re good to go
    I used to run the stock alternator and a 200 amp Leece Neville
    I dont have it on now but I still have the bracket to bolt on if i ever need it again
  10. Feb 10, 2012 at 12:08 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    there is a thread out there somewhere about using a chevy 350 200amp alt out there somewhere just need a 1/4" spacer and an wiring harness adapter i'll see if i can find it again.
  11. Feb 10, 2012 at 12:29 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Is this is what you're thinking of? (140A GM alternator with dual Optima Yellow Tops)
  12. Feb 10, 2012 at 12:45 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    yea that's one of them but there is a website that had complete bolt on kit for the tacoma with up to 200amp alternator and harness for like 250 bucks. IIRC... I'm trying to find it, I'm looking to upgrade my alternator and dual batt. on my 4 banger before i add a winch.
  13. Feb 10, 2012 at 6:06 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Holy crap....I refuse to believe that. That's just straight up impossible. :eek:
    How the hell do you fuse something like that? Consider this, in your house, you typically run every electrical outlet in an entire room of ONE 15A breaker. I can't even fathom what 480A of draw is like. You must run like dual 0Gauge power wires to something like that.
    *runs to go read up on winches*
  14. Feb 10, 2012 at 6:40 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    That's why winches are designed to be powered by batteries that can dump the amperage needed for a short time and then be recharged over a longer time by the alternator. Also the rated amp draw would be just before it stalled. It won't draw close to that during normal loads.
  15. Feb 10, 2012 at 6:50 AM
    ItalynStylion
    Steven
    DFW, Tx.
    It better not be even close to that type of draw. Reason being is that you'd need multiple runs of 0Gauge wire to and from the unit to handle that type of draw. That's like 5000watts of power at 12V.
    What are you considering to be a "normal" load?
  16. Feb 10, 2012 at 6:54 AM
    98tacoma27
    Ben
    Not Beech Creek
  17. Feb 10, 2012 at 7:12 AM
    ItalynStylion
    Steven
    DFW, Tx.
  18. Feb 10, 2012 at 7:17 AM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
  19. Feb 10, 2012 at 7:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    :notsure:
    Looks like the have a distributor close to Denver....but the map isn't the greatest to read.
  20. Feb 10, 2012 at 3:55 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
