Dual battery DC to DC charger
Discussion in 'Technical Chat' started by Droz, Dec 9, 2022.
  1. Dec 9, 2022 at 2:07 PM
    Droz
    Droz [OP] FIDO
    2021 Tacoma TRD Sport DCSB
    Man it is tough to reach the positive terminal on the alternator on a 2021 V6. So we HaVE to connect the charging wire to the alternator even tho it is “electricly” on the same cable as the batter positive terminal???
  2. Dec 11, 2022 at 4:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just what are you trying to do?
    Most Dual battery Systems run a battery isolator to charge the batteries.
    To keep them both from drawing down at the same time.
    Unless your dealing with factory installed dual batteries.
  3. Dec 11, 2022 at 4:09 AM
    Jpmurph
    Jpmurph Well-Known Member
    17 DCLB TRDOR
    What brand? The DC to DC charger I have is connected to the battery positive terminal
  4. Dec 15, 2022 at 2:33 PM
    MR5X5
    MR5X5 Well-Known Member
    If I follow you.... The only difference between the battery + terminal and alternator + terminal is the wire between them, so yes, you are fine hooking up to the bat + instead of the alt +. But per Bivy don't you have a charge controller between the two bats?
  5. Dec 19, 2022 at 11:59 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    SR-71A likes this.
