Dual Battery Setup Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by docloco, Oct 16, 2015.
  1. Oct 16, 2015 at 1:38 AM
    docloco
    docloco [OP] Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    I am in the process of planning out a dual battery setup for my 2015 TRD OR. After researching several products and threads, I think I have it narrowed down to what I want, but I am having difficulty with the proper wiring schematic for what I want. I am not an expert electrician by any means, but I can follow clear direction. This is what I want to use:
    [​IMG]Blue Sea Systems ML-ACR
    [​IMG]Blue Sea Systems ST Blade Fuse Block
    [​IMG]12v LED Double Battery Voltage Monitor
    Similar to this setup - 687474703a2f2f696d672e7461706174616c6b2e636f6d2f642f31342f30372f31382f34617665767533752e6a7067.jpg
    The wiring for this part is easy.
    I've seen conflicting wiring diagrams. The first diagram doesn't show the Blue Sea Systems 12 circuit fuse block with negative bus. On this diagram, there are two switches. Which product do I need for this? Do I need a solenoid switch? If so, the second diagram is for a Blue Sea Solenoid Switch, but its drawn as connected to the starting battery.ML-ACRs.jpg
    I want to get my hands dirty and do this myself, but I also don't want to burn up expensive equipment because I left something out or connected something backwards. Any help would be appreciated. Thanks.
    Rock Lobster likes this.
  2. Oct 16, 2015 at 2:16 AM
    DrFunker
    DrFunker Well-Known Member
    Check out @Crom set-up. He has duel with solar. And he is really great with this stuff.
    So is @Dj Suisav Ton of knowledge with this guy too.
    Hope they can help ya Ron.
    I'll be watching this one. :spy:
    Dj Suisav likes this.
  3. Oct 16, 2015 at 2:20 AM
    docloco
    Ron
    Florida
    I've seen Crom's setup and I like it. I'm not putting in a roof rack just yet, but it's planned. After that, I'd definitely consider adding the solar. I have somewhat of a checklist of mods in a certain order based on budget and practicality that I'm trying to follow. The dual battery is the beginning for me. I don't think I've seen Dj's. Time to surf a bit more.
  4. Oct 16, 2015 at 2:37 AM
    DrFunker
    Yeah, Crom does nice work.
    DJ doesn't have one in his rig (yet :devil:). But he is a great guy with a wealth of know-how about electrical work.
  5. Oct 16, 2015 at 2:38 AM
    docloco
    Ron
    Florida
    That's exactly what I'll need. Electricity isn't my strong point, unless I'm defibrillating someone, then I've got that covered. :)
    arrakis429 and DrFunker[QUOTED] like this.
  6. Oct 16, 2015 at 2:44 AM
    DrFunker
    :laugh:
    @Dj Suisav would probably tell you - 'much the same'.
  7. Oct 16, 2015 at 6:22 AM
    CChampigny
    CChampigny Active Member
    Chad
    Calgary
    2013 DCSB
    Icon CDC coilovers, Icon 2.0 rear shock, Dakar Leafs, Konig Countersteer wheels, All Pro Skids, Apex Sliders, Apex front bumper, All Pro rear bumper, Access tonneau, LR UCA, BHLM, 285/75/16 Duratracs...I think that its
    The first diagram is the one you are interested in. The top most item in that diagram that looks like a breaker panel is where the blue sea fuse block will go. In a large boat this is in fact the connection to the master breaker panel, which is why there is simply a switch in line, as it would have its own master breaker that would trip if you draw too much power (just like The breaker panel in your house). Since you are using a blue sea fuse block in that spot, you should place a breaker inline, instead of the switch. Double check, but I believe the blue sea fuse block is rated for 80 amps, so simply put an 80amp breaker in line. That is exactly what I did, except I used a bussman relay box as opposed to a blue sea fuse block.
    The second diagram is simply if you want to use the ACR as a relay to enable/disable starting the engine.
    Hope that helps
  8. Oct 16, 2015 at 6:24 AM
    docloco
    Ron
    Florida
    Do you have a link for a particular breaker?
  9. Oct 16, 2015 at 6:27 AM
    CChampigny
    Chad
    Calgary
    2013 DCSB
  10. Oct 16, 2015 at 6:40 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You don't need the battery switches in the diagram. Those are for a boat, which disables electrical for when the boat is stored or dry docked. Agree that first diagram is the one you want.
    Also you don't have to connect all the wires for the ACR-ML product. I believe you only need to connect 4. Battery positive(s), ground, and isolation #1 (brown wire). Can't remember though, it's been 2.5 years since I looked at one.
  11. Oct 16, 2015 at 6:44 AM
    docloco
    Ron
    Florida
    How's this?
  12. Oct 16, 2015 at 8:16 AM
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    HAHA!! anything i can do to help, i'm here. @docloco Yeah I've been wanting to do a blue sea system. But don't have the time to put into it and don't wanna spend the money just yet :(. But it is in the mix!!
    @DrFunker gives me waay to much credit! :humble:I've just done everything wrong enough times to know what's right! :frusty::headbang: also i am an electrician so that knowledge kinda helps at times! but i'm still learning everyday.:drunk:
    docloco[OP] likes this.
  13. Oct 16, 2015 at 8:19 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    @BamaToy1997 is who you need to talk to.
    he sells these dual battery kits.
    docloco[OP] and Dj Suisav like this.
  14. Oct 16, 2015 at 9:08 AM
    docloco
    Ron
    Florida
    Can you advise the proper size fuse for post #11 above with the blue arrows on the left?
  15. Oct 16, 2015 at 9:29 AM
    docloco
    Ron
    Florida
    Thanks. I wasn't sure, but that clarifies it for me. Yes I do want the ability to jump start from the auxiliary.
    This better?
  16. Oct 16, 2015 at 9:38 AM
    docloco
    Ron
    Florida
    I don't need to push limits with electricity. 100A I'm sure will be plenty.
    DoorDing likes this.
  17. Oct 16, 2015 at 9:50 AM
    docloco
    Ron
    Florida
  18. Oct 16, 2015 at 9:57 AM
    Dj Suisav
    Saul
    San Antonio, TX
    I agree with @DoorDing I wouldn't push anything beyond 100 amps. that will be good enough! sorry at work, can't always respond!
    docloco[QUOTED][OP] likes this.
  19. Oct 16, 2015 at 9:59 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :bananadead::bananadead::bananadead::bananadead::bananadead::bananadead::bananadead::bananadead::bananadead:
  20. Oct 16, 2015 at 10:00 AM
    Dj Suisav
    Saul
    San Antonio, TX
    :pray::ballchain::(
