Dual Battery Setup Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by docloco, Oct 16, 2015.
  1. Oct 16, 2015 at 10:06 AM
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    DrFunker and docloco[OP] like this.
  2. Oct 16, 2015 at 10:10 AM
    docloco
    docloco [OP] Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
  3. Oct 16, 2015 at 10:18 AM
    docloco
    Ron
    Florida
    Thats why I'm spending so much time and effort planning this.
    DrFunker likes this.
  4. Oct 16, 2015 at 12:46 PM
    DrFunker
    DrFunker Well-Known Member
    And asking the right people. :thumbsup:
    That's what I do. :wink:
  5. Oct 16, 2015 at 8:09 PM
    docloco
    Ron
    Florida
    My next question is, how do I make the house battery accessories only hot when the car is on?
  6. Oct 16, 2015 at 8:16 PM
    docloco
    Ron
    Florida
    Maybe keeping it hot would be good too. While it will be a long time before I have something as large as a fridge, it would be nice to always be able charge phones. Although, next week I'm doing the 100/400w anytime mod, but thats just when the car is on.
    ramonortiz55 likes this.
  7. Oct 18, 2015 at 7:23 PM
    BamaToy1997
    Bill
    Navarre, FL
    What are you exactly looking to do with having the aux battery only running with the key on? The reason I ask is that most people want to use the aux battery to power things like a fridge or camping lights. You don't want to have your ignition on just to run things such as that as it is a waste. I have always said that I was not a fan of the IBS and Blue Sea systems because they are not a true isolation system at all. They simply connect the aux battery in parallel to charge it.
  8. Oct 18, 2015 at 8:17 PM
    docloco
    Ron
    Florida
    Never mind. I got my answer. Thanks.
    BamaToy1997[QUOTED] likes this.
  9. May 13, 2016 at 6:41 AM
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    Thanks for any help. So trying to do this. Where do I hook up the brown isolation wire from the Blue seas ML ACR (Isolation #1 on Diagram). Do I just remove dash ,look in the steering column in the truck and use a wire tap> Is there a "best"place to tap in the line? I think Im puting the switch on left side of steering wheel in stock switch locations so is the starter switch wiring going that direction since its going hrough the firewall grommet? How do I know which one it is?
    Thanks again
  10. May 13, 2016 at 6:44 AM
    docloco
    Ron
    Florida
    The isolation wires are actually optional. I didn't use any of them.
  11. May 13, 2016 at 6:51 AM
    NicP
    Nic
    colorado
    05 DC LB
    oh. so from the ml acr to the manual in cab combiner switch all you need is the red to open and close the combination circuit and the yellow to illuminate the switch??
  12. May 13, 2016 at 7:08 AM
    NicP
    Nic
    colorado
    05 DC LB
  13. May 13, 2016 at 7:21 AM
    NicP
    Nic
    colorado
    05 DC LB
    on @Pirhett I couldnt find his dual batt setup?? Is there a link to his setup?
    Pirhett likes this.
  14. Aug 30, 2016 at 11:03 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Bumping this thread and looking for verifification.
    Is it necessary to hook up the brown wire on the blue sea ml acr?
    Why would one hook it up or not hook it up, advantages to either setup?
    I'm installing in 99 v6 Tacoma if it matters
  15. Aug 31, 2016 at 10:24 AM
    #35
    dragonhrt
    dragonhrt Well-Known Member
    Ottawa
    07 TRD Offroad
    OME 3 Inch Lift, 5100's
    Sorry to sound very noob, but what are the advantages going with a dual battery setup?
  16. Aug 31, 2016 at 10:53 AM
    #36
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    You're doing the right thing by going through all the research. Wiring is easy, but to get it done right it's expensive and time consuming.
    Just remember if you are going to run more than 100A make sure it's well fused and the AWG is sufficient for the runs.
  17. Aug 31, 2016 at 11:21 AM
    #37
    Laxtoy
    Maltby, WA
    Running 1/0, did big 3 upgrade and running high output alternator, I've done my research but the comment I quoted in my earlier post presents an easy solution if I can omit that step.
    Need to reiterate my question, is it necessary to run the brown wire off the blue sea 7622 ml acr?
    What happens if I don't? What is of added benefit if I do?
  18. Aug 31, 2016 at 12:40 PM
    #38
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It is my understanding that the brown wire is not necessary in our application.
    It is there for marine applications where starting/cranking power is drawn for extended (longer than 30 second) periods of time in some applications. In those situations, it will protect electrical components in the circuit by isolating them from surges that can occur during heavy amp draw.
    Iggy likes this.
  19. Aug 31, 2016 at 5:57 PM
    #39
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It's a fair question. There two general camps with a little bit of cross over for some.
    Those that need power when the vehicle is off, similar to the needs of an RV, needing to run a fridge, or compressor, or inverter, etc... These folks usually add a deep cycle battery. A sub group are the off-roaders with winches. These folks tend to prefer the AGM batteries - deep cycle qualities but with a high CCA rating. The aux battery is isolated from the primary battery in the event the electrical devices drain the aux battery. This way, your primary battery always has enough juice to start the vehicle.
    The second camp are those that simply want a back-up battery in case the primary dies. I'm in this group. I go off-roading solo and if my primary battery dies on me, it may be days, or sometimes weeks, before I see another soul that could jump start me. Yes, there are battery packs, but you have to haul them, and only a very expensive battery pack can start a really dead battery. Any 12-volt battery can be used as an aux battery for these folks. Those that can afford it will go for an AGM battery, but you can throw in a $60 Wallyworld battery if you want.
    You can wire the batteries directly in parallel, always pos to pos and neg to neg, if all you want is the same voltage but with more power. This is the cheapest way to set up a dual battery system. However, this also shortens the life span of a battery because the weakest battery is always draining the stronger battery - never the other way around, that's not the way battery chemistry works. To increase longevity, you want the batteries connected when the car is running so that the alternator charges both batteries, but you want a device to isolate the batteries when the car is off so they don't drain each other. This device can be a simple on/off high amp switch that you flip on and off, accordingly; or, a high end electrical isolator that reads the voltage level of both batteries and does all the thinking for you.
