Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Dec 31, 2018 at 3:33 PM
    #2141
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Thanks for the info. Do you have a diagram of your setup or pictures of it? Are you running an ML-ACR like everyone else on here? I checked the wires coming from my camper and they are actually 10awg which is great. I can just run 10awg straight from the battery(or fuse block if I add one) to the camper with a quick disconnect in the bed like I was originally planning.
  2. Dec 31, 2018 at 3:47 PM
    #2142
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    There should be some in my build page or farther back in this area. Even though it’s 10awg personally I’d go a step bigger so voltage drop is not as bad.
    Bastek likes this.
  3. Dec 31, 2018 at 3:53 PM
    #2143
    Atl-atl
    Phoenix+Flagstaff
    Cool I'll look through your build thread, thanks. As for the camper wiring, the 10awg wires go directly into the power converter and I don't want to open that can of worms so it will stay 10awg. I could run 8awg off the battery to the disconnect in the bed and keep the 10awg from the camper. Then if I change my setup in the future at least the wires coming off the battery are bigger.
    Bastek and SR-71A like this.
  4. Dec 31, 2018 at 3:55 PM
    #2144
    YamaDirtrider
    Josh
    Elizabeth CO
    Think it’s in the last few pages. And yea I’d suggest exactly what ya said, don’t need to require the camper but on the truck side bigger is better
  5. Dec 31, 2018 at 6:46 PM
    #2145
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
  6. Dec 31, 2018 at 8:09 PM
    #2146
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I went bigger with the thought of having connected batteries while winching. The amps can be very large and coming from the second battery which is in the bed of my truck, so bigger is better in that case. Additionally, going bigger allows a bit of a safety net in case you do have a draw or an issue (although things like breakers and fuses come into play). Its better to have a safety net (in my opinion) if you decide to extend your system as well.
  7. Jan 3, 2019 at 4:30 AM
    #2147
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
  8. Jan 3, 2019 at 5:06 AM
    #2148
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I put one in the rover, haven't had any issue with it yet. It sits more than it's driven and fires off everytime.
  9. Jan 6, 2019 at 1:11 PM
    #2149
    KaptainH
    Kris
    Gainesville, GA
    Making a run from the engine bay to my bed where the isolator and second battery will be mounted. Using 1/0 from the front to the isolator- do I need to use 1/0 from the isolator to the second battery or can I go smaller?
  10. Jan 6, 2019 at 1:24 PM
    #2150
    Sandman614
    Tim
    '06 SR5 Off Road
    Will you be pulling starting/winching current from both batteries, or just one. If both then yes.
  11. Jan 6, 2019 at 5:01 PM
    #2151
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    What’s the point of running 1/0 if you’re gonna bottleneck it with a smaller gauge anyway?
    SR-71A likes this.
  12. Jan 6, 2019 at 5:09 PM
    #2152
    Sandman614
    Tim
    '06 SR5 Off Road
    If he's not pulling high amperage from the 2nd battery then it's fine. Like using it to power lights and such.
    KaptainH likes this.
  13. Jan 6, 2019 at 5:40 PM
    #2153
    KaptainH
    Kris
    Gainesville, GA
    I'm only going to be power lights, and an air compressor. I just want to make sure there's a big enough run to the isolator for the alternator to recharge my bed battery. I reckon I'll just run 1/0 to from the isolator to the battery anyway.
  14. Jan 6, 2019 at 6:18 PM
    #2154
    Sandman614
    Tim
    '06 SR5 Off Road
    I ran 10(ten) 4 ga wire from my battery to the bed of the truck for my 'house' battery. Even though our alternators are 100+ amps you will never see that at the battery for simple recharging.
  15. Jan 7, 2019 at 6:43 AM
    #2155
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    ^ This.
    There are a ton of charts that can be used to figure wire size is needed based on max current. But it doesnt make a ton of sense to go from big to small.
    http://www.offroaders.com/technical/12-volt-wiring-tech-gauge-to-amps/
  16. Jan 7, 2019 at 6:46 AM
    #2156
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    So if I put my ACR under the hood where my main battery is, and put a second battery in the bed, would you not run 1/0 from the bed to the ACR? My winch is hooked to the battery under the hood, as is my switchpro.
    tacoma16 likes this.
  17. Jan 7, 2019 at 6:59 AM
    #2157
    SR-71A
    Zack
    Southern Maine
    Larger wire is always better imo. Just because the winch is wired to the main battery doesnt mean that it wont pull power from the house battery. And it will pull quite a lot when it does.
  18. Jan 7, 2019 at 7:01 AM
    #2158
    Sandman614
    Tim
    '06 SR5 Off Road
    If the accessories running off the rear battery don't require larger wires, leds pods pull like 3 amps, then there is no need to run larger wire. I don't have any reference for how much amperage a 'house' battery pulls from the alternator to charge but it's not enough to melt my smaller wire run (correction I ran 4ga wire to my acr/2nd battery, but still a far cry from 1/0 wire). The accesories I'm running on the 2nd 'house' battery do not pull high enough amps to require larger wire.
  19. Jan 7, 2019 at 7:05 AM
    #2159
    SR-71A
    Zack
    Southern Maine
    You're not wrong, but it still doesn't make any sense to go from a large wire to a smaller wire before getting to the house battery. Just pick one and run with it
    Boomkanani likes this.
  20. Jan 7, 2019 at 7:13 AM
    #2160
    Sandman614
    Tim
    '06 SR5 Off Road
    If you have it sure no reason not to, it's not gonna hurt anything but there is no benefit to it.
    SR-71A[QUOTED] and Boomkanani like this.
