Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jan 24, 2019 at 5:16 AM
    #2181
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Yes, but the ml-acr and others connect the batteries together when charging. Automatically disconnects when the voltage gets below a set point. Using the switch or manually, you can force the connection open or closed. Some uses wound be self jump, protecting a battery during winching, sharing the winching load.
    OverlAnderson[QUOTED] likes this.
  2. Jan 24, 2019 at 5:24 AM
    #2182
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    ah okay makes sense.. thanks guys for the info bout to pull the trigger on Offgrid engineering's set up
    edit: also would a scan guage replace the function of the red button indicator?
  3. Jan 24, 2019 at 5:34 AM
    #2183
    YamaDirtrider
    Josh
    Elizabeth CO
    No. The ml-acr has 5 or so small wires coming off the main body that goes to the red button.
    If you don’t care about remotely controlling the unit you don’t have to connect the switch. In my case, I did not like the switch and only hooked up 1 of the wires. Mine runs in auto most of the time and when I push my switch it forces the connection (ie self jump or both batteries for winching)
  4. Jan 24, 2019 at 5:35 AM
    #2184
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The scan gauge connects to the OBD2 port. It has nothing to do with the ML-ACR and no way to connect to it.
  5. Jan 24, 2019 at 8:20 AM
    #2185
    HerT4R
    HerT4R Nomadic
    Her
    Bless the rains
    2 legs or 2 wheels
    '10 4RUNNER TE (SOLD)
    If you're going to buy the OGE kit why not just get the button too and the wire harness. i bought the ACR, wiring harness, and switch from OGE and I couldnt be happier. I had thought to myself I can make the harness but the ease and time savings of pulling it our of the box and fishing it through the firewall WITHOUT having to really even think about it was very rewarding. Especially after I got a dud ACR off Amazon and lost an entire afternoon trying to save like $20, needless to say it was not worth it. But you know what was worth it? buying from OGE.
  6. Jan 24, 2019 at 8:28 AM
    #2186
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You can have OGE wire the ACR (or do it yourself) to not have the in cab button. I did that because the button really serves no purpose and just complicates the install. The ML-ACR will automatically latch the two batteries together anytime the truck is running and disconnect anytime the truck is shut off (assuming correct voltage increase/decrease of course).
  7. Jan 24, 2019 at 8:38 AM
    #2187
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    The button is nice if your start battery dies and you’re too lazy to pop the hood to manually latch the 2 batteries.
    It doesn’t look too out of place paired with a Peak DBI voltmeter next to it. Ditched the clutch bypass switch by jumping it at the plunger on the pedal, left everything still plugged in, just tucked the oem switch up under the dash.
  8. Jan 24, 2019 at 11:47 AM
    #2188
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    Really, it works however you decide to wire it. You could have the alt battery not connected to anything, and just a reserve. Then close the solenoid to jump the truck from the reserve battery. Most people use the alt battery for "house" functions or to run winches or other items that might run down the battery when the trick is off (or on) leaving you unable to crank.
    So your reasons for forcing the solenoid open or closed may vary. The ACR works by closing the solenoid when it detects charge voltage (alternator running) and then opens when there is not charge voltage. Of course you can override that behavior with the switch, or with the manual override on the solenoid itself.
    SR-71A likes this.
  9. Jan 24, 2019 at 11:52 AM
    #2189
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Anyone have a good leads on a 27F battery tray? (other than the plastic toyo one)
  10. Jan 24, 2019 at 4:52 PM
    #2190
    steveo27
    Pittsburgh
    All of this ML-ACR talk motivated me to dig into my switch issue again. The LEDs never lit up on mine. Ripple checked the install. The harness. Pulled the switch all apart. Blah blah blah.
    Checked the harness and pin outs again. Everything was right. Bench tested the switch. LEDs worked on the work bench w/ powere & ground to the LED pins. Put it back together. Still nothing.
    De-pinned the switch plug at the ML-ACR. Connected just the pins together. FINALLLLLLY the switch lit.
    There is some play where yellow pin 7 off the switch plugs in. It looks seated when it’s not plugged into the ML-ACR side of the plug but when they’re connected, there’s enough slop in it it doesn’t make a connection. Tweaked the pin and plug so it seats better and stays seated. Everything works.
    Lesson of the day, even if you think the pins are seated, double check them.
    Glad it’s sorted out.
    Now my question is....
    When the batteries are either automatically or manually latched, both LEDs light correct? When they are locked out, both LEDs go out, correct?
    tacoma16, HerT4R and YamaDirtrider like this.
  11. Jan 24, 2019 at 4:54 PM
    #2191
    Borrego Taco
    Borrego Taco Well-Known Member
    2017 DCSB TRD OR 4x4
    Correct. Lights are on when linked. Lights are off when disconnected. It does not matter if it is auto or manual linkage or disconnect.
    steveo27[QUOTED] likes this.
  12. Jan 24, 2019 at 4:59 PM
    #2192
    steveo27
    Pittsburgh
    Awesome.
  13. Jan 29, 2019 at 1:40 PM
    #2193
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    What size batteries fit in the stock location behind the headlight without any sort of modification to the fusebox, battery mounts, etc?
  14. Jan 29, 2019 at 9:40 PM
    #2194
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What year is your truck?
  15. Jan 29, 2019 at 9:46 PM
    #2195
    Taco TRQ
    TuRDTaco
    Oops. It’s an 09 TRD. The nice big spot by the passenger side firewall is already occupied. Don’t need crazy deep power reserves. I know I can go lithium, but I’m also trying to stay remotely budget oriented.
  16. Jan 29, 2019 at 9:52 PM
    #2196
    Digiratus
    Roaming the PNW
    The RedHead
    Group 27F is the stock size IIRC. I've read of some using a Group 31 in the stock location without modifications.
    Someone with a 2nd gen should chime in here to confirm.
  17. Jan 29, 2019 at 9:57 PM
    #2197
    Taco TRQ
    TuRDTaco
    Dual 31’s definitely need modification. At a glance it looks like dual 27’s still kind of look like they might. L
  18. Jan 29, 2019 at 10:40 PM
    #2198
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    With both batteries linked via ML-ACR and needing to help someone jumpstart his dead battery, do I have to disconnect my batteries at the switch first or can I just hook up the jumper cable normally?
  19. Jan 29, 2019 at 10:47 PM
    #2199
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    I would just hook up the jumper cables to the starting battery
  20. Jan 30, 2019 at 4:41 AM
    #2200
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    2nd gen trucks came with either a 24F (base) or a 27F (if you have the tow package). Either of those are a drop in replacement in the factory location.
    Dual 31s, 27Fs etc will not fit. Group 31s for example are huge: 13 x 7 x 9.5 inches (roughly). With that being said, it is possible to get dual 35s in the factory location. But its tight from what Ive seen.
