Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Sep 1, 2014 at 12:04 AM
    #241
    skygear
    skygear                    
    Yes, the blue sea ML-ACR is a MONSTER!!!!!
    You have a source for the discontinuation of the 7622? I'm curious now. Might need to stock up on them for other people. I'll give them a call tuesday also to pry a little further.
    I know BUSSMANN Makes them, errr a version of them. The ACR also has a 24v version, maybe they are revamping them in some way?
  2. Sep 1, 2014 at 12:07 AM
    #242
    skygear
    skygear                    
    I might just look for another one on the cheap online to take apart just to post disassembled pics of it.
    Believe me when I say, i do my research. From what I found out there in the wild, this was the absolute best off the shelf system I could find. Besides the lack of an actual 'gauge' - that is what drew me to redesign the switch. When I can come up with the MOQ (minimum order quantities) for the switch, then I feel it will be THE BEST. Switch will be able to be integrated into any other system out there on the market too.
  3. Sep 1, 2014 at 8:34 AM
    #243
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    It's just wasn't showing up under blue sea's drop-down menu. But once I searched directly for it it's showing up now. :confused:
    My bad.
  4. Sep 1, 2014 at 8:36 AM
    #244
    skygear
    skygear                    
    No stress. Had me concerned.
  5. Sep 2, 2014 at 3:06 PM
    #245
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    so when you guys install your dual batterys, are you putting circuit breakers on both ends of the lead that goes from the isolator and the aux battery if that distance is far? say, i have the aux battery under the bed. put a circuit breaker next to that battery and one next to the main batter?
  6. Sep 2, 2014 at 3:10 PM
    #246
    BamaToy1997
    Bill
    Navarre, FL
    You would have to have one HELL of a circuit breaker if you plan to use the second battery for a winch or a jump start considering most jump starts can reach 300 amps, and most winches pull 450 amps or more.
  7. Sep 2, 2014 at 3:35 PM
    #247
    skygear
    skygear                    
    Yeah, Bill said it true. NO is the answer. I do battery - Isolator - battery. No breakers.
  8. Sep 2, 2014 at 3:59 PM
    #248
    paranoid56
    San Diego
    14 double cab taco
    even with a 18ft run of 0ga wire? i have put mesh sleeving over it, and extra protection against any sharp edges. but just still kinda bugs me having that large of wire with no protection.
    and yes, this would not be powering a winch or the starter. I put a 150amp breaker on one side, but wasnt sure what about the other lol.
  9. Sep 2, 2014 at 6:24 PM
    #249
    BamaToy1997
    Bill
    Navarre, FL
    Unfortunately when it comes to large current draws, it is difficult to protect them, hence the reason there are only a limited number of systems. While mine is not bullet-proof, the 250A charging isolator will protect the primary electrical system in the case of a short in the second battery's cable. It will get a little messy, but it will protect it. However the second battery that is remotely located does not have the same protection. It CAN be protected by a big enough circuit breaker, but when you are talking 450A plus, it is VERY expensive to protect them.
  10. Sep 3, 2014 at 4:07 PM
    #250
    TXGnftr
    TXGnftr Well-Known Member
    Texas
    Bill,
    I've been looking at dual batts for about a week. In my research, why do you suppose Piranha, NL, and Painless recommend using in-line 100 amp midi fuse coming off the positives?
    By the way, this thread has been full of great gouge...:bowdown:
  11. Sep 16, 2014 at 11:00 PM
    #251
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Great thread. Great information. Thanks
    Getting ready to do this.
  12. Sep 16, 2014 at 11:44 PM
    #252
    skygear
    skygear                    
    Glad someone found it useful!
  13. Sep 17, 2014 at 12:21 AM
    #253
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    When I had bought my ACR back in 2012 I paid $150 on Amazon. Seems it's up to 195 now on amazon :eek::eek:. What I like about the ACR the most is that it's a latching relay and doesn't require to be continuously energized to keep the batteries tied together. Also the fact that there's a manual override in case the solenoid plunger does happen to take a dump on ya.
    81elco likes this.
  14. Sep 17, 2014 at 11:37 AM
    #254
    skygear
    skygear                    
    See. There's anti failure built in all over this unit. That's why I like them so much.
  15. Sep 22, 2014 at 12:42 AM
    #255
    skygear
    skygear                    
    I cary jumper cables. More so I can act as recovery for other vehicles.
    As for the ML-ACR, might want to contact West Marine, I know there is or was a 20% sale going on.
  16. Sep 22, 2014 at 12:45 AM
    #256
    skygear
    skygear                    
    You mean this one http://www.ebay.com/itm/Blue-Sea-Sy..._Accessories_Gear&hash=item3a968eaace&vxp=mtr
    I would get it. Thats not a bad deal. And it is the 7622 that we all are using. So yeah, You are on the right path.
  17. Sep 22, 2014 at 12:48 AM
    #257
    skygear
    skygear                    
    LOL ) I see you "b***y ( 33Feedback score is 10 to 49)" - Congrats1!!
    Now get some 2/0 or 4/0 gauge so you can take full advantage of the HIGH cranking amps this bad boy is capable of. I have been using 2/0 and watching on eBay for some welding wire in 4/0 at a reasonable price.
  18. Sep 22, 2014 at 12:54 AM
    #258
    skygear
    skygear                    
    You ever thought of storing the Jumper cables in the engine bay? I had my small ones in there for a time. Then I got some 2/0 gauge jumper cables. Wont fit in the spot I had them before.
  19. Sep 22, 2014 at 1:29 AM
    #259
    skygear
    skygear                    
    Yep, your engine bay is full. More so than mine.
  20. Sep 24, 2014 at 12:34 AM
    #260
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i think having two on the main run that long isn't a bad idea. You'll want one be the solenoid to pop off if the batteries are linked to stop flow going from the starter battery and you'll want one by the 2nd battery to pop to stop flow from going form it to any from the battery to the solenoid.
    Yes just a 100 amp break on the aux box with the 100amp breaker for the blue seas one...i didn't know which one you were using.
