Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jan 25, 2020 at 5:25 AM
    #2581
    cynicalrider
    cynicalrider #NFG
    Jersey
    Very clean work and labeling! How do you get those labels to stay?
    Toynado[QUOTED] likes this.
  2. Jan 25, 2020 at 5:35 AM
    #2582
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    They look like they are shrink-wrap labels.
    Dymo makes shrink-wrap and a hand-held device to print on the shrink-wrap. It's not the cheapest shrink-wrap, but it really is convenient.
    SR-71A and Toynado like this.
  3. Jan 25, 2020 at 5:58 AM
    #2583
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    thank you. It’s actually heat shrink tubing that goes in a label maker like @Scott B. said:
    R Molshine 2 Pack 18052 Heat-Shrink Tubes Cable Label Compatible for DYMO Black on Yellow (0.23inch 1/4inch 6mm) 1.5m https://www.amazon.com/dp/B01D83B59K/ref=cm_sw_r_cp_api_i_1IelEbRRHYCMA
    **this is showing black on yellow, but mine is black on white**
    DYMO Label Maker | LabelManager 160 Portable Label Maker, Easy-to-Use, One-Touch Smart Keys, QWERTY Keyboard, Large Display, for Home & Office Organization https://www.amazon.com/dp/B005X9VZ70/ref=cm_sw_r_cp_api_i_6KelEb7E74XFX
    rob1208, harryn and Kolunatic like this.
  4. Jan 25, 2020 at 10:23 AM
    #2584
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I did the very same, pretty cool that I didn't have to modify the power steering fluid reservoir bracket in any way and how the holes lined up perfectly. There's some tearing and separation going on underneath that will require some immediate attention in the near future. Have you noticed the same?
  5. Jan 25, 2020 at 7:29 PM
    #2585
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    That’s a bummer. A ton of ppl I know have sheet metal tipping there. I guess I just got lucky. Mine’s still in tact
    MonkeyProof[QUOTED] likes this.
  6. Jan 26, 2020 at 3:32 AM
    #2586
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    I love the jacket on that wire. Source?
  7. Jan 26, 2020 at 12:13 PM
    #2587
    Toynado
    SF Bay Area
    tacomgee likes this.
  8. Jan 27, 2020 at 7:27 AM
    #2588
    cynicalrider
    cynicalrider #NFG
    Jersey
    Well shit, I already have a label maker. I wonder if there are tubes compatible for it. I need to check once I find out what model I have.
  9. Jan 27, 2020 at 12:29 PM
    #2589
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Clear shrink tube over you label?:notsure:
  10. Jan 27, 2020 at 1:16 PM
    #2590
    cynicalrider
    cynicalrider #NFG
    Jersey
    Stop using common sense Murph!
    Fifthwind[QUOTED] likes this.
  11. Feb 11, 2020 at 12:14 PM
    #2591
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Hey everyone, thought this was a good thread to ask some question since the AV thread doesn't get much action. This summer I am looking into revamping my audio system in my taco. I am going to be upgrading to 3 skar zvx v2 8s behind the seats (its possible), 4 skar fsx 6.5s in the doors, some huge Skar VX4-STs in the a-pillar using customspeakerpod's pods, and some Skar VX35-st in the doors by also using pods from customspeakerpods. I'm not 100% sure on the amps I'm using since the zvxs can handle a LOT of power over their rms. It's going to be 4000w+ and before yall come out of the bushes asking why I'm doing this, its because I like loud boom boom.
    Now for the actual questions:
    So I know what I'm doing for wiring (0 gauge upgrades, distribution fuse blocks, ect), but I'm not exactly sure which route to take for producing all the volts I need for a system like this. About 15k miles ago, my stock alt went out and it was replaced with an aftermarket alt by a local shop. I imagine this new alt is probably to the same specs as the stock one. Should I go for dual batt, High output alt, or both? I have seen guys who run 4k systems on stock electrical so I know its possible, but I want to do this right the first time. Also, what voltage should I be shooting for with this much wattage draw? I know this thread is mostly oriented to setups for lighting, solar, and others, but I'm sure yall can interpret this for car audio.
    Any advice helps. Thanks :)
  12. Feb 11, 2020 at 6:10 PM
    #2592
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Drawing that much power I’d suggest a high output alt, voltage booster, and a sealed agm battery or Capacitor at the amp.
    4000watts is over 300amps.
    A stock Tacoma with tow package alt max is 160A. An upgraded alt will probably be ~260A which while still under is a lot better. If your running the alt at max you will quickly burn them up.
  13. Feb 12, 2020 at 10:38 AM
    #2593
    PilotMM
    PilotMM Well-Known Member
    Las Vegas
    '17 TRDOR DCSB
    RLD Canopy, Icon Stage 4 plus RXT leaf
    Nice BBB. Are you using a Sterling alternator to battery charger? Do you have a build thread? I want to set up a dual battery system down the road and think LiFePo4 is the way to go.
    Cheers!
    -M
  14. Feb 12, 2020 at 5:02 PM
    #2594
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yeah, I love the weight ratio as well as power storage. I completely divorce this system from the truck. I do run a voltage booster to the truck battery (31 series AGM) at 14.7 volts float charge.
    I am woefully deficient on my build thread but I do have some more pics. I charge this battery through a MIPP Solar Charger/Inverter all in one. I have 3x100 watt solar panels mounted on top of the truck with a remote monitor installed. The Solar Charger allows you to manually set charge rates and also contains thermal protection for the LiFePO system.
    B5F48270-7A76-4178-9B7A-4852985CD009.jpg E21851E7-099C-4028-BE10-BA1B4304E8A6.jpg
    wi_taco, CRUZZER, rob1208 and 8 others like this.
  15. Feb 12, 2020 at 7:50 PM
    #2595
    PilotMM
    Las Vegas
    '17 TRDOR DCSB
    Sweet! My buddy that builds out vans was trying to get me to buy a Merlin panel (Group buy thing) a little while back but I am still not ready to put in a second battery. He uses Victron for monitoring. I just got my RLD camper shell on last week and I want to build an Aux fuse system before I get an extra battery. You should do a thread on the details of your electrical set up. Its sweet and I would love to read more about it.
    Cheers! :cheers:
    -M
  16. Feb 15, 2020 at 9:15 AM
    #2596
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    @zippsub9 How did you ground this 'divorced' system?
  17. Feb 15, 2020 at 9:42 AM
    #2597
    zippsub9
    Halfmoon, NY
    14 DCLB
    The solar inverter/controller is grounded on the frame just below the rear passenger seat by the exhaust.
    I will get off my ass and get a build thread together eventually.
  18. Feb 20, 2020 at 8:01 AM
    #2598
    zippsub9
    Halfmoon, NY
    14 DCLB
    So, I misspoke before. My solar controller/inverter is not grounded to the truck. I have the PV panels grounded to it, the lithium battery grounded to it as well. My DC accessory panel runs off a ANL fused link to the back of the truck and also is grounded back to the lithium. No accessory or any part of the system is grounded to the frame or chassis.
    I recently went back to a single battery under the hood and removed the frame grounding strap to completely segregate the system. Sorry for any confusion.
  19. Feb 20, 2020 at 8:16 AM
    #2599
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    no worry. interesting, grounding leaves me wondering. I have a dual battery under the hood, grounded to chassis/body screw. I'm setting up a Lithium system in the truck bed under a campshell. no grounding wire to chassis. I have read no ground to chassis is OK for small system. I do plan to connect the lithium and AGM starter with an isolated DC/DC charger.
  20. Feb 20, 2020 at 8:30 AM
    #2600
    zippsub9
    Halfmoon, NY
    14 DCLB
    a general rule of thumb is to streamline the return of the charge back to its source. Chassis ground typically goes through very small contact points and spot welds. I use these for low current applications. A winch, for example, I go back directly as possible to the source of not exactly. Depending on what and where you want to run off it should help drive your decision. Because our beds are fiberglass composite I was grounded to the frame in the rear. My dual battery setup under the hood had a grounding strap to the frame and the chassis for my accessories to take either path.
