Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. May 25, 2020 at 12:51 PM
    #2761
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Which battery would you guys recommend hooking up my winch and ARB twin to? The starting battery (X2 27F) or the aux battery (X2 group 35)?
    I have a Redarc BCDC.
    Both accessories will only be used while the truck is running, so I am thinking the starting battery is the most practical to hook them up to, yes?
    Bastek likes this.
  2. May 25, 2020 at 4:38 PM
    #2762
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Starting battery. They draw a lot of power and wound kill the other battery after a few hard winch pulls.
  3. May 25, 2020 at 7:42 PM
    #2763
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Thanks for the advice, I think I have a pretty firm grasp on what I'm going to do. Off Grid Engineering aux battery tray by the fire wall, ML-ACR, two 100w solar panels, charge controller connected to the aux battery, blue sea sub panel in the bed. I think a 50 amp breaker with 3/0 to the rear should be sufficient to run everything. It sounds like the solar will be able to top off two AMG batteries to the proper voltage to prolong the battery life. The last few things I'm trying to figure out is what charge controller to use and where to mount it, where to mount and what gauge to use, and where to mount the sub panel.
  4. May 25, 2020 at 8:17 PM
    #2764
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    I'd hook the compressor up to the aux battery. The winch can go to either one if the batteries are linked, but since the alt is directly connected to the starter battery and your overall wire runs would be shorter, I'd hook the winch to the starter batt.
    zerotimeouts likes this.
  5. May 27, 2020 at 10:59 AM
    #2765
    Gnarbuckle85
    Gnarbuckle85 Well-Known Member
    Sean
    H-Town, TX
    2011 TRD Sport DCLB Silver
    DON'T JOIN TACOMA WORLD!! JUST DON'T!
    Need some recommendations from you guys on my solar charger settings inline with my dual battery set up please.
    I have the OGE Dual Battery setup, w/MCLR - Running on "Auto", (2) Group 35 Ody AGMs, and recently just hooked up a 130W Solar Panel tied to a Victron MPPT 75/15 Solar Charge controller direct to my aux battery.
    What I am needing help with is utilizing the correct settings in the Victron Bluetooth app to optimize battery charging from solar.
    Battery specifications:
    Victron App Settings screen:
    Based on my batteries and running the mclr on "Auto", what should I set the the following to:
    (Battery Voltage) - I figured 12v but technically the MCLR being on Auto is transferring charge between (2) 12V batteries.. = (24) volts
    (Max current charge) - 15A I figured this is the max and why the controller is the 75/15 model. But should I reduce this down from 15v?
    (Absorption voltage) - What would you recommend?
    (Float voltage) recommendations?
    (Equalization voltage) recommendations?
    I have tried to do a ton of internet research but am getting frustrated.. Any help would be greatly appreciated.
    Thanks,
  6. May 27, 2020 at 11:03 AM
    #2766
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  7. May 27, 2020 at 11:53 AM
    #2767
    Gnarbuckle85
    Sean
    H-Town, TX
  8. May 29, 2020 at 10:14 PM
    #2768
    harryn
    harryn Active Member
    Auxiliary Power
    An mppt controller is intended for use when the panel Vmp (roughly its normal operating voltage) is substantially higher than the battery max charge voltage.
    In this case, the Vmp ~ 18 and the Vbat max is ~ 14-15 volts, so the 3 volt differential is marginal. Those are really for when you have 2 panels like that wired in series.
    I know that people like the cool victron phone application, but a better solar charge controller for this application is a pwm controller - example bogart enginering.
    It isn't completely obvious, but what these agm batteries need is not only total watts of charging, they need a lot of charging time. The pwn controller will operate on lower light levels, so charging starts earlier and ends later in the day.
    The effect is even stronger in areas that have overcast / diffused lighting. I have done the math on these systems and used mppt controllers when the calcs all said it should work - and then ended up replacing some mppt controllers on customer projects. You have to be watching the dials to really appreciate how panels and controllers really behave in poor lighting.
    As far as settings for the victron, usually you can use the default AGM settings as the ods are very well behaved.
    If you want to dig deeper, then just use the settings in the battery technical manual.
    Digiratus likes this.
  9. Jun 14, 2020 at 10:23 PM
    #2769
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Haven't learned much yet. Relocating a dual setup under my bed in my 5vz 1st gen and only need the primary vehicle battery connected at the beginning for getting out of my driveway. Any resources for building / sourcing wire / terminals / solder etc. and how to move primary starting battery wires for relocating?
    Few things I've sourced, but not married to if there's more cost effective / similar cost but higher quality alternatives:
    Battery Wire
    https://www.amazon.com/TEMCo-WC0180...NPKCX7B2KWY6&refRID=745972YGNPKCX7B2KWY6&th=1
    Crimpers
    https://www.amazon.com/WBHome-Hydra...g/dp/B0811VYCQ6/ref=psdc_553392_t1_B00KS4R3PI
    Terminals
    https://www.amazon.com/SELTERM-Gaug...DCDRHND1HPZ&psc=1&refRID=KKH3J7PQ6DCDRHND1HPZ
  10. Jun 15, 2020 at 8:16 AM
    #2770
    MountainManGuy
    Colorado
    My Victron mppt has been awesome. Even on cloudy or rainy days I still get enough voltage from my panels for a decent charge rate. The phone app is fantastic and after using it I wouldn't use any other controller that didn't have that feature. Using 2 100watt panels, my controller really only bulk charges for part of the day and usually float charges for a greater part of the day as the batteries are already full. My main power draw is an ARB fridge/freezer.
    Also, I live in Colorado so we do get a decent amount of sun.
    harryn[QUOTED], Bastek and Ngneer like this.
  11. Jul 6, 2020 at 10:18 PM
    #2771
    jmoto
    jmoto Active Member
    JT
    SoCal
    2020 Tacoma TRD Pro 6-Speed M/T
    C4 Step Sliders Toyo A/T III's OGE Dual Battery System (Auto Relay) OE Aux Fuse Bracket w/ Blue Sea Fuse & Breaker Blue Sea Rear Aux Power for Dometic CFX Leer 100XR Total Chaos Bed Stiffeners Prinsu Top Rack iKamper Skycamp 2.0
    1BEA631A-F800-4A37-A4FC-F99A606B3D6E_1_105_c.jpg AEA720D4-8420-4918-944E-93426E97B164_1_105_c.jpg
    First time testing out Gunkote (titanium) on the Off-Grid Engineering dual battery trays and Overland Equipped fuse block bracket. Also, put on a few layers on those two raw front bed hooks. Little bit of a sloppy job but good practice before working on the AR15.
    Dalandser likes this.
  12. Jul 7, 2020 at 5:39 AM
    #2772
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Man that looks good
    jmoto[QUOTED] likes this.
  13. Jul 7, 2020 at 3:23 PM
    #2773
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    After over thinking the heck out of it, I gathered and finally installed my dual battery set up. I also cleaned up wiring under the hood. It just had to be done...
    I opted for Northstar 31A AGM battery, Ctek D250se DCDC charger, and topped it off with 100W slim solar panel.
    IMG_20200707_20487.jpg IMG_20200707_23552.jpg IMG_20200707_51837.jpg IMG_20200707_53337.jpg
    Done all this work in order to run a 75qt fridge... :facepalm:
    Bob K, Chux, SR-71A and 6 others like this.
  14. Jul 7, 2020 at 3:44 PM
    #2774
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    But soooooooooo worth it.
    Bastek[QUOTED] likes this.
  15. Jul 7, 2020 at 3:49 PM
    #2775
    John90XJ
    John90XJ Well-Known Member
    2006 Tacoma Access TRD OR
    Let us know how important the solar panel is to overall package. I've got basically the same thing and have debated the need for a panel as I generally move every day anyway and the fridge is such a low draw.
    Also, could you take a shot of the 2nd battery from a little further out so we can get a better idea how you laid it out? Did you have to forego any functionality after the install?
    Nice clean work. ;)
  16. Jul 7, 2020 at 5:48 PM
    #2776
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Thanks! Took a WHILE to wrap all the wires in those sleeves!
    With child seats and all the crap, that's the best I can do
    Battery is installed on a group 31 sized tray and tied down with a strap i got in HD. And only downside I see right now, I lost behind the seat storage.
    As for solar, hmmm... When running fridge/freezer combo it can draw ~5Ah, so I'd get approx 11 hrs out of the battery. Of course finessing the hell out of setting, it is possible to almost double that. Sooo I figured adding solar would only help, not harm it.
    Also, when not running the fridge, it actually topped off my starting battery! So there is that.
    Is it really important, maybe not. But also I don't have enough real life data to argue it either way.
  17. Jul 7, 2020 at 9:23 PM
    #2777
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Not sure if I dropped this in here, but ....here! Lol.
    Zim
    So I'm still in the design/build mindset. I fab'd up this mount which I like and might keep. I've only drilled 4 holes in the truck, none in the bed, and no one will ever see 3 of them...lol. Does not take up much room, and it's neat and clean to a extent. I can store some things under, and over if I want. Already went camping, and just using the lights we had plenty of power. Charger will probably not live there as I charge my golf cart too. Just playing around and having fun. Film at 11.
    Zim
    tacoma16 and Bastek like this.
  18. Jul 19, 2020 at 5:25 PM
    #2778
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I just purchased a Redarc BCDC1225D DC DC charger. I will be installing the 2nd battery in the back of the rear seat. I am sourcing parts for the setup, 6 AWG cables, 40a breaker, etc.
    Does anyone have a wiring diagram where to place the breakers and what size? I am going with breakers instead of fuses.
    wi_taco likes this.
  19. Jul 19, 2020 at 5:31 PM
    #2779
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Manual is listed on the page: https://cdn.shopify.com/s/files/1/2...ut_Instruction_Manual.pdf?7204406381448510702
    Fuses/breakers should be as close to the battery/ies as possible. Looks like they call for 40A fuses.
    thebaker and 4wdExplorer[QUOTED] like this.
  20. Aug 3, 2020 at 10:23 AM
    #2780
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Alright so i have a dual battery set up and i have the accessories running off the aux battery but it only allows this when the isolator pops on since i have the cole hearse one. anyway around this without breaking the bank?
