Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Sep 24, 2014 at 1:09 AM
    #261
    skygear
    skygear                    
    In your setup, protecting the wire is a smart move. Anyone for that matter of there is a battery in the bed. Might want to just put one on the positive going to the bed in the front of the truck. Then one on the negative side of the battery in the bed. Can't arc of there's no negative ;)
  2. Sep 24, 2014 at 1:15 AM
    #262
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    jesus dude..haha i did my full setup all myself for under 500 if not 400..well..the battery part..
    the rest of it..well..i don't want to know..
  3. Sep 24, 2014 at 1:43 AM
    #263
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Hah well maybe it was a little less than that I don't remember exactly, but it was alot more expensive than I thought. I also bought some tools I didn't have so that I could make the cables myself (large cutters and a hydraulic crimper) so I added that into the cost. I also have a decent amount of cable left over for other projects. The two yellowtops alone were close to 400 when I bought them with a discount. Mount was another 150 or so, then the isolator was another 150. So there's 700 right there without any cable or connectors lol
  4. Sep 24, 2014 at 1:47 AM
    #264
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sheesh..i just got one more yellow top, case for like 30 bucks, 140amp alt for 135 bucks, 500amp solenoid for 50 bucks, some 4 ga wire, and ends and i had everything else to solder it all up haha
    i considered it one of my smaller projects really. Love having it thats for sure.
  5. Sep 24, 2014 at 1:57 AM
    #265
    skygear
    skygear                    
    Which crimper do you have?
  6. Sep 24, 2014 at 2:04 AM
    #266
    skygear
    skygear                    
    The battery business is booming thats for sure. I like the idea of lighter lithium based systems though. With the proper access to the cells, at the right price point, could make a killing on them. The LIPO/ LiFe/ etc. market is still in its infancy in my opinion. Other Chemistries too. I feel the issue would only be the AH ratings. Would be nice to have a Group 31 sized battery with close to 200ah though. at a fraction of the weight.
  7. Sep 24, 2014 at 4:01 AM
    #267
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Fuses or circuit breakers are not used in path between your your starting battery (or auxiliary battery) to the starter solenoid because on a cold morning, depending on the temperature, you could require in access of 500 amps to crank your engine. The primary purpose auxiliary battery is for deep cycle loads and should be a deep cycle battery. Starting batteries are designed for shallow discharges and when used in deep cycle applications will prematurely fail.
  8. Sep 24, 2014 at 7:59 PM
    #268
    skygear
    skygear                    
    Bill is speaking to all of us. He is a Battery guru. Electrical genius. ;) Has a blog and all. Look at his post history. Speaks the truth. A wise man to bounce ideas off of.
    :spy::fenforcer::bucket:
  9. Sep 24, 2014 at 8:26 PM
    #269
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Ohs no he'll be the king expo man!
  10. Sep 24, 2014 at 9:10 PM
    #270
    skygear
    skygear                    
    I have solar panels sitting in the back yard that I use for longer trips...
  11. Sep 24, 2014 at 9:13 PM
    #271
    skygear
    skygear                    
    Negative side. - Yes, it would accomplish the same thing for th battery in the rear. So if an arch started, it would blow the Positive side up front first, then the negative side a split second later in the rear. BUT now that battery would be completely isolated from the system and even though the arch point would still exist. There is no way for it to continue to arch. The battery is not grounded at that point. SO the circuit cannot complete.
  12. Sep 24, 2014 at 9:16 PM
    #272
    Blackdawg
    Monte
    Wyoming/St. Louis
    Still ground though from the other battery. So without something on the hot wire the ground doesn't seem worth it.
  13. Sep 24, 2014 at 9:25 PM
    #273
    skygear
    skygear                    
    He was saying he wanted 2 breakers. One on the HOT in the engine bat to the rear. Then the other on the hot side in the rear of the truck still would accomplish the same thing.
    The wire would be compromised if the breakers tripped. The battery in the rear would be offline or separated at that point. The issue that happened would still be there.
    I was nearly imposing to move the one in the rear to the negative post. it would do the same thing but completely isolate the battery with the one blown in the front on the HOT and the NEG blown on the rear.
    With the same outcome. This way just protects both sides of the circuit.
    Take a 9v square battery. Lick one post, now lick the other, ok? Now lick them both.
    For good or bad, just one approach. BUT Bill said no, so might want to take that into consideration. I do. I have none of the battery protected with breakers. The only additional protection I have is the braided loom on it, and my solid connections I made on them.
  14. Sep 24, 2014 at 10:37 PM
    #274
    skygear
    skygear                    
  15. Sep 25, 2014 at 8:01 AM
    #275
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    ^^^ Hydraulic crimper FTW!
    foxrcing07 likes this.
  16. Sep 25, 2014 at 10:38 AM
    #276
    Jrs13086
    Jrs13086 Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    subbd for this
  17. Sep 25, 2014 at 1:45 PM
    #277
    skygear
    skygear                    
    I am willing to pick one up. I need to know where or who has a reliable one. Anyone have a recommendation? If not I'll get some research done before the EXPO and make proper arrangements.
  18. Sep 25, 2014 at 1:53 PM
    #278
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    This is the crimper I have. It works quite well, but the dies are metric. You have to do a partial crimp and then turn the lug to finish it. That way you don't get the wings on the crimp.
    http://www.amazon.com/Hydraulic-Cri...F8&qid=1411678185&sr=8-7&keywords=lug+crimper
    An example of the work this crimper can do. That's 1/0 cable, and there are plenty of larger dies left if you're going with a larger gauge.
    Toynado and SilverGhost like this.
  19. Sep 25, 2014 at 1:56 PM
    #279
    skygear
    skygear                    
    Looked at that one this morning. Might see if greenly or alien has one.
  20. Sep 25, 2014 at 1:57 PM
    #280
    SMKYTXN
    Nathan
    Houston
    DCFB
    They probably do. I'll stick with the $50 unit for occasional use though.
