Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Aug 20, 2020 at 5:53 AM
    #2801
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    the faint blink means it has power. you really dont need the optional LED for trouble codes, the main lights are used for that.
  2. Aug 20, 2020 at 6:02 AM
    #2802
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    https://www.newegg.com/p/0R7-001A-012G4
    https://www.indicatorlight.com/10mm-3v-red-led-metal-ip67-signal-indicator-light/
    https://www.ebay.com/sch/i.html?_fr...cat=0&LH_TitleDesc=0&_odkw=3v+panel+mount+led
    https://www.ebay.com/sch/i.html?_fr...itleDesc=0&_osacat=0&_odkw=3v+panel+mount+led
  3. Aug 20, 2020 at 7:07 AM
    #2803
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I am getting a faint blinking when key is out of the ignition. It took me 3 days to notice since it hard to see the faint blinking. When I start the vehicle the LED is fully illuminated which is normal.
    I don’t think the faint blinking when vehicle is off and key is out of ignition is normal.
    I might give this light a try.
    https://www.ebay.com/itm/353127671479
  4. Aug 20, 2020 at 7:13 AM
    #2804
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    The faint blinking is normal, mine does it too :thumbsup: I asked Matt @ off grid engineering and he verified it's normal.
  5. Aug 20, 2020 at 7:16 AM
    #2805
    4wdExplorer
    Orange County, CA
    Ah ok. Good to know! Thanks for the reply. Glad there is nothing wrong.
    I just do not want to have any unnecessary power draw when vehicle is off and key out of ignition.
    I might get the 3v bulb just out of curiosity and report back.
  6. Aug 20, 2020 at 7:23 AM
    #2806
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    If the BCDC is pulling power you will know it, it lights up bright red.
    Did you hook up the blue wire? Matt told me it's not necessary, but what happens is the BCDC will pull power until the starting battery reaches 12.7v which means it drains it down to ~90% every time I turn the truck off. I'm considering hooking up the blue wire to a switched ign source to stop it from doing that.
  7. Aug 20, 2020 at 7:31 AM
    #2807
    4wdExplorer
    Orange County, CA
    My blue wire is unhooked. So the Redarc drains down the starting battery or the house battery to 90%? Just making sure you said engine starter battery. That’s interesting. Thanks for sharing that info.
  8. Aug 20, 2020 at 8:19 AM
    #2808
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    The way it works is the BCDC will pull power from the starting battery to charge the aux battery. It doesn't care if the ign is on or not when the blue wire is left unhooked. So what happens is the BCDC will pull power from the starting battery to charge the aux battery, until it sees the starting battery dip below 12.7v at which point it turns off. The problem is on an AGM battery 12.7v is ~10% drained, so it effectively leaves the starting battery at 90% charged after turning the truck off.
    Edit, if you connect the blue wire to a switched power source, the BCDC will ONLY operate when it sees 12v on the switched power. That's why I think I'm going to connect the blue wire to an add a fuse somewhere in the fuse box under the hood, so it's only working when the truck is running.
    Bastek likes this.
  9. Aug 20, 2020 at 10:03 AM
    #2809
    4wdExplorer
    Orange County, CA
    Got it makes sense. Please report back if you hook up the blue wire and your findings afterwards.
    Your starter battery is AGM? My starter battery is the OEM Toyota battery (non AGM). One of my main reasons going to the BCDC is to completely isolate the starter battery from the house battery in key off situations and charging my AGM house battery to 100%. Also, not buying two identical batteries when you have a perfectly good starting battery wasting money IMO.
    fatfurious2 likes this.
  10. Sep 12, 2020 at 1:56 AM
    #2810
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    So after installing my dual battery system, I started moving wiring over to the 2nd battery such as my aux fuse block, switch pros, and my compressor. Im going to be adding a few more things to the battery.
    Has anyone figured out a mounting solution for a couple circuit breakers by the 2nd battery? I want to mount 2 but want to see what others have come up with.
    I have a 3rd gen with the 2nd battery in front of the firewall on the passengers side.
  11. Sep 23, 2020 at 6:10 PM
    #2811
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Sub'd. Been prepping for a dual battery setup lately. Have been set on the Off Grid Engineering Redarc kit.. but started searching and reading threads and now I'm here...
    thebaker likes this.
  12. Sep 25, 2020 at 6:47 AM
    #2812
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    The other problem is that our 3rd gen's ECU controlled alternators don't supply enough voltage to ever fully charge an AGM battery in the first place. This disappointment sent me down the rabbit hole that brought me to this thread and has me waiting on my OGE/Redarc kit to arrive.
    Bastek likes this.
  13. Sep 25, 2020 at 12:14 PM
    #2813
    MapJunkie
    MapJunkie Well-Known Member
    Washington
    2015 Tacoma OffRoad w/ Drifter
    I think that DC/DC chargers are really required to extend the life of expensive batteries. If you are buying $89 deep cycle batteries at Walmart the pain isn’t as bad if the battery dies early. I think your investment will be worth it.
  14. Sep 25, 2020 at 12:27 PM
    #2814
    E.J.
    Josh
    NWA
    For sure I think the DC to DC charger will be a great investment for the accessory battery, it doesn't seem like it'll top off the starting battery though. Third gens won't fully charge AGM batteries off the alternator, I can drive 4 hours and still end up with 12.7 volts in my quality AGM starting battery.
  15. Sep 25, 2020 at 12:43 PM
    #2815
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    OVTune will have the capability to adjust the alternator settings once the 2.0 files are released for vF format.
    The Pirate and SR-71A like this.
  16. Sep 25, 2020 at 1:00 PM
    #2816
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I think they have versions for nearly all ECUs now. Some are still being improved but you can at least make your own edits.
    The Pirate likes this.
  17. Sep 26, 2020 at 5:43 AM
    #2817
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Confirmed, currently running a higher voltage tune for AGMs.
  18. Oct 5, 2020 at 7:33 AM
    #2818
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Physical size too. This forum has successfully convinced everyone that the group size refers to the Amp/volt specifics and it does not. The group size is exactly that, the physical size of the battery. The other characteristics do change some but folks should be concerned with the operational specifics.
    Zim
    SR-71A likes this.
  19. Oct 7, 2020 at 8:57 AM
    #2819
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    After a bit of a hiatus, Off Grid Engineering is back to on TacomaWorld! Please tag me in any questions you may have about any of the OGE products and feel free to shoot me an email with any questions about products you already own or with any comments you may have.
    E.J., shiftd and Littles like this.
  20. Oct 7, 2020 at 10:40 AM
    #2820
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Do you guys have an all in one system, with redarc dc-dc, for a 2nd gen "sport" that will mount behind the rear seat?
