Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Nov 23, 2020 at 4:23 PM
    #2941
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  2. Nov 24, 2020 at 6:57 AM
    #2942
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
  3. Nov 25, 2020 at 6:32 AM
    #2943
    fatfurious2
    David
    Ashburn, VA
    What is the difference between watt hours and amp hours?
    I think i looked up my battery spec, and it said 62aH.
    Tacman19 likes this.
  4. Nov 25, 2020 at 7:54 AM
    #2944
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    AH times the battery voltage would give you the watt hours
    Tacman19 and fatfurious2 like this.
  5. Nov 25, 2020 at 2:51 PM
    #2945
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Basically a 62 AH 24V battery would have twice the watt-hours as 62 AH 12V battery.
    fatfurious2[QUOTED] likes this.
  6. Dec 8, 2020 at 5:47 AM
    #2946
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    So I've been running my BCDC set up for a month or so now and it's working as advertised. Before I put it in I used to throw a charger on my AGM starting battery once a month to top it off and keep it healthy. I put the charger on the other day and noticed that the BCDC will also turn on and start charging the second battery, does this sound Kosher?
  7. Dec 8, 2020 at 6:06 AM
    #2947
    fatfurious2
    David
    Ashburn, VA
    Isnt the bcdc a charger for both batteries? If so, that sounds right..
  8. Dec 8, 2020 at 6:12 AM
    #2948
    E.J.
    Josh
    NWA
    No, the BCDC only charges the second battery. I turns on when it gets voltage from the alternator normally. It's acting like the truck is on, I'm just wondering if this can somehow mess up my charger or something.
  9. Dec 8, 2020 at 6:24 AM
    #2949
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yeah its just a voltage threshold. Putting the charger on the primary battery raises the voltage over that limit which triggers the BCDC.
    Personally I would turn the BCDC off when doing this. That way 100% of the "charge" can go into the primary batt without the BCDC drawing it down at the same time.
    In case you are not aware, there is now an option for 3rd gens to boost the charging voltage programmatically. This requires OVTune, but may be an option for you to look into
  10. Dec 8, 2020 at 5:08 PM
    #2950
    NukedTaco
    Wyatt
    Unless you disconnect the BCDC it will try to drain your main battery down to 11.9V as you are trying to charge it.
  11. Dec 9, 2020 at 8:56 AM
    #2951
    E.J.
    Josh
    NWA
    I got an email back from Redarc tech support saying this. They have an ignition controlled relay that will keep this from happening but I think I'll just deal with unhooking the BCDC for now. Oh and they are sending me a patch for asking a tech question, nice.
  12. Dec 9, 2020 at 1:20 PM
    #2952
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Hmm, That's interesting, I thought hooking up blue wire to ignition circuit was supposed to serve about purpose
  13. Dec 9, 2020 at 1:39 PM
    #2953
    NukedTaco
    Wyatt
    Hooking up the blue wire just changes the on and off voltage settings so it will still charge with a smart alternator
    Bastek[QUOTED] likes this.
  14. Dec 9, 2020 at 1:45 PM
    #2954
    E.J.
    Josh
    NWA
  15. Dec 9, 2020 at 1:56 PM
    #2955
    NukedTaco
    Wyatt
    If you look in the manual hooking up the blue wire changes the on point from 13.2V to 12.0V and the off point from 12.7V to 11.9V this is to make sure the bcdc doesn't stay off if the smart alternator doesn't raise voltage above 13.2 because of low loading and a fully charged main battery. MANUAL
    E.J. likes this.
  16. Dec 9, 2020 at 2:01 PM
    #2956
    E.J.
    Josh
    NWA
    Yeah, I see how hooking up the blue wire isn't going to help my issue. It'd be nice if the BCDC had a physical on/off switch.
  17. Dec 9, 2020 at 3:48 PM
    #2957
    NukedTaco
    Wyatt
    You could always install a battery switch in the engine compartment to connect and disconnect the bcdc. Cheaper than the relay but not as convenient.
    SR-71A likes this.
  18. Dec 14, 2020 at 7:38 PM
    #2958
    fatfurious2
    David
    Ashburn, VA
    I think I might ditch my dual battery setup, and go for a solar setup with a portable generator.. still not sure yet
    Reasoning:
    generator is a LiPo battery. Can be had for around $250 (depending on the size. I used a Jackery 240 as an example). Jackery has 240wh/16.8ah/14.4v, 2 USB, 12v plug, and a 110v AC plug. Can do 12v/AC/solar charging, weighs 6.5lbs.
    100ah deep cycle battery is $180 for a knockoff brand. Much heavier, and Id have to do all the wiring. Granted, I dont need the AC plug/pure sine inverter..
    Bastek and Tacman19 like this.
  19. Dec 15, 2020 at 7:49 AM
    #2959
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Kinda depends on your electrical needs. Like I said before, if you've got disco lights and electric blankets, you might need some extra. I just need to charge a bunch of batteries on all these phones, drones, and camera equipment....oh and a magic chef toaster oven...Ahahahahahhaha.
    Zim
  20. Dec 15, 2020 at 7:57 AM
    #2960
    fatfurious2
    David
    Ashburn, VA
    I was discussing with a coworker (that doesn't really know anything about this stuff/thinking out loud). I have bed lights that are wired to a blue sea, but directly to the battery. I also have 2 USB ports and a 12v plug for my fridge. When im out camping im not worried about charging phones or laptops.
    I don't have a drone yet, but id hope to charge it at home, use it while out, and then not worry about charging it again until i get back home.
    Other than the above, im roughing it. Thats what camping is for me. I don't need to bring my blender or wood stove for pizzas. (Definitely like this way more than being at home haha. Dont even use that stuff there either)
