Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Dec 15, 2020 at 8:07 AM
    #2961
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    They suck batteries like nobodys business. About 26 minutes of flight time each one.
    Zim
    fatfurious2 likes this.
  2. Dec 16, 2020 at 7:40 PM
    #2962
    konerri
    konerri Member
    Here is my latest Dual Batteries Build for my Tacoma. I think its cool and super advanced for a DIY Build. Feed Back is always appreciated.
    crashngiggles, The Pirate and Bastek like this.
  3. Dec 16, 2020 at 10:08 PM
    #2963
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Sorry but you lost me at "No DIY'er has ever attempted anything like this" Congrats and good luck.
    Zim
  4. Dec 16, 2020 at 10:09 PM
    #2964
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I got lost too
  5. Dec 16, 2020 at 11:47 PM
    #2965
    fatfurious2
    David
    Ashburn, VA
  6. Dec 17, 2020 at 7:20 AM
    #2966
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    fatfurious2[QUOTED] likes this.
  7. Dec 17, 2020 at 8:30 AM
    #2967
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Interesting.
    Looks like way overkill. IMHO, you solve problems that don't really exist in the real world (or could be solved with a much simpler design.)
    I am a little concerned with all the uncovered +12 points. I would hate for a load in the bed to shift and short out something.
    Obviously, a lot of thought went into the design, and proved successful.
    Tacman19 and MJTH like this.
  8. Dec 17, 2020 at 10:15 AM
    #2968
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
  9. Dec 17, 2020 at 10:45 AM
    #2969
    fatfurious2
    David
    Ashburn, VA
    Hah! I realized i need to connect my 2nd battery to a ground too. Just not sure where. I guess a bed bolt?
  10. Dec 17, 2020 at 12:12 PM
    #2970
    Scott B.
    Scott
    Georgia
    A better idea is to run a heavy cable directly to the frame. The bed bolt does go to the frame, but will not give you the best electrical connection - minimal surface area of the threaded bolt to the frame, and an area subject to corrosion.
    I used a Blue Sea Cable Clam to seal the wire passing through the bed, and slid a terminal lug under one of my slider bolts to the frame.
    Clean the paint from under the bolt for a clean electrical connection.
  11. Dec 17, 2020 at 12:36 PM
    #2971
    fatfurious2
    David
    Ashburn, VA
    At this point i am gathering info. I need to redo my dual battery setup, but first I need to make sure my bed is water tight, as much as I can. Im in limbo right now, while I wait for my gfc to be built. And its winter, so I don't have the full draw coming from my electrical setup - fridge, lights etc.
    I am also planning on changing my battery and solar to something bigger. So there lies another project, but after step one.
    Thank you for your input! Its definitely going to be worth it in the end. And I know I will have more questions too
  12. Dec 17, 2020 at 12:36 PM
    #2972
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How do you like that Cable Clam? I was looking at those the other day as a possible firewall pass through. Im at the point now where I need a dedicated solution for all the wires I got
  13. Dec 17, 2020 at 12:37 PM
    #2973
    fatfurious2
    David
    Ashburn, VA
    I saw another thread where someone was using a cat5 ethernet cable. One of those going from the engine bay into the cab.. could be a possibility
    SR-71A[QUOTED] likes this.
  14. Dec 17, 2020 at 7:25 PM
    #2974
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    I’ve thought about this for a while. Only down fall is the amount of amperage it’ll carry. And having a lot of relays in line. I wish there was a nice relay/fuse block that wound work but I haven’t seen any.
    one day I’ll go switch pro
    SR-71A likes this.
  15. Dec 17, 2020 at 7:30 PM
    #2975
    fatfurious2
    David
    Ashburn, VA
    I run a sPod. They use an ethernet cable coming into the cab. Its good because there are 8 wires in one/I have 8 available switches. They built everything into a circuit board that can dim/strobe any light attached. Now I dont have to worry about relays and switches having different number of plugs on the back. Thats the one thing that I never got. Why does the switch have 4 prongs, the relay has 5, and the light has 2. Where do the rest go?!
    This kind of shows what I mean. I suck at electrical stuff, so I was very willing to drop some $ for someone else to do it. Im not going to do this with my bed battery setup, but I also wont have the same functionality as what I have with the sPod.
    https://www.youtube.com/watch?v=KhyuXKw8qHg
  16. Dec 18, 2020 at 11:42 AM
    #2976
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    I found a nice bolt near the spring perch. I'll get a picture when I can. Its within a foot or two of the bed corner too.
    Zim
  17. Dec 18, 2020 at 5:15 PM
    #2977
    Scott B.
    Scott
    Georgia
    I like them. They seal well, and keep the wires from rubbing on any sharp corners.
  18. Dec 18, 2020 at 8:42 PM
    #2978
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I’d avoid places exposed to wheel debris or could cause build up of rust inducing fust. When shit collects on the frame and you run a current through it bad things happen. I’d favor a vertical surface over a horizontal one.
    SR-71A likes this.
  19. Dec 19, 2020 at 8:06 AM
    #2979
    konerri
    konerri Member
    Thanks for the kind words. This was my first build. I agree that some of these things could been much simpler. Its likly just me, i do things this way. lol. i am working on positive exposed terminals as this week. I will be building a cover for all the electronics.
  20. Dec 19, 2020 at 8:12 AM
    #2980
    MGMSangTaco
    Denver, CO
    I’m in limbo waiting for my gfc too haha. Ordered it august 9th and they moved start dates up cause of increased production but it’s still not until may 2021. There’s so much info in here that I am not too upset I have months to make up my mind completely.
    Anyone see those new battle born batteries with built in heaters? Pretty darn cool but very spendy. I’m still trying to nail down what solar I am going to use- I am semi confused about the redarc I got, I know there’s a yellow solar wire from the unit but seems like people also run a solar inverter as well?
