Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jan 14, 2021 at 5:05 PM
    #3001
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    sure? Id guess normal BST rules apply, like local threads?
    geekhouse23[QUOTED] likes this.
  2. Jan 14, 2021 at 5:07 PM
    #3002
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Jan 28, 2021 at 4:34 AM
    #3003
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    OGE split system.
    House battery supplies power to the blue seas fuse block in the engine bay, and blue seas weather deck panel in the alucab canopy camper in the rear. Running 9 inside/outside lights, fridge, 6 USB outlets, 4 12v sockets.
    Starter battery supplies power for Switch pros, running compressor, multiple driving lights, rock lights.
  4. Feb 24, 2021 at 6:46 PM
    #3004
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So this seems like the best place to ask since you guys that have multiple batteries are running lots of things off them.
    Here is the situation as it sits. I have too many wires coming off my battery and its ugly (ring terminals stacked on top of each other). I want to swap out the factory terminal clamps to make the wires a little cleaner.
    Currently connect to my battery is
    2 stock wires (power and starter or what ever it is)
    1 4 gauge wire for my amp
    1 16 gauge wire for aux fan
    1 14 gauge wire for light bar
    My light bar is a dual mode (yellow or white) so it has 2 relays, the wiring that came with it just daisy chains it. I am putting in a 4 spot fuse block (atc) that will run my light bar, my aux fan, and soon ditch lights.
    Do you guys think that these terminals will work just fine for me?
    https://www.amazon.com/gp/product/B07C41STTJ/ref=ox_sc_act_title_1?smid=A29WNUYJ8SYTGZ&psc=1
    I figure the dual 4 gauge will be able to handle the starter wire and my amp wire. Then the dual 8 gauge can handle the truck power and my fuse box (light bars, ditch lights, aux fan).
  5. Feb 24, 2021 at 7:15 PM
    #3005
    fatfurious2
    David
    Ashburn, VA
    I have this that needs to go on soon:
    https://sdhqoffroad.com/collections...dhq-built-billet-battery-terminal-upgrade-kit
    Maybe also look into investing into a SwitchPro or Spod? it will ease your wiring too
    Tacman19 likes this.
  6. Feb 24, 2021 at 7:31 PM
    #3006
    5nahalf
    Erik
    Minnesota
    I had thought about getting the sdhq terminals, but that would just put the ring termials scattered on 3 sides of the terminal.
    As for the switchpro. I had looked into getting one, but in the end I just dont plan to have enough things plugged in to need that many switches. I have just the overhead switch panel (meso) that holds 6 switches. I have the 2 stock ones, then I added 4 more, only using 3 - yellow light bar, white light bar, rear lights, "push to turn something on" switch. Once I get my new bumper, that dual color light bar will turn into a single color light bar, then ditch lights, rear lights(reverse lights), and my mystery button (will probably end up being side lights).
    Tacman19 and fatfurious2[QUOTED] like this.
  7. Feb 24, 2021 at 7:56 PM
    #3007
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  8. Feb 24, 2021 at 8:01 PM
    #3008
    bagleboy
    Scott
    Norcal, Santa Rosa
    I kinda prefer ring terminals myself. Those set screw retainers are shit on door knobs so I wouldn’t expect them to be any better on a battery clamp.
    SR-71A and Tacman19 like this.
  9. Feb 24, 2021 at 8:15 PM
    #3009
    5nahalf
    Erik
    Minnesota
    Im starting to think the same. Guess Ill just wire up what I have now to the factory terminals, then when the weather gets better I can pull the battery out, see what I have for space and find some good terminals.
  10. Feb 26, 2021 at 10:30 AM
    #3010
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Along the lines of what bagleboy said I prefer these myself
    https://smile.amazon.com/gp/product/B00X36RILW/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
    Its much easier to grab a HF hydraulic crimper, crimp on some copper ring terminals of the appropriate size, and bolt them on. For the set-screw style things to work well and not loosen over time I think you either want solid core wire, or crimp ferrule terminals on first. Not sure if they even make those for such large wire
  11. Feb 26, 2021 at 10:37 AM
    #3011
    5nahalf
    Erik
    Minnesota
    Ive got some 4 gauge ferrules from my car audio stuff, but I hate them as half the time the set screw strips out before its even tight enough to hold them.
    I was looking at those terminals actually, I think it might of been your videos of the install that I watched.
  12. Feb 26, 2021 at 11:46 PM
    #3012
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you gotta have them you could crimp ring terminals on then cut the rings off to get your ferrules.
    SR-71A[QUOTED] and Bastek like this.
  13. Feb 27, 2021 at 7:38 AM
    #3013
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    That's thinking outside the box right there! :thumbsup:
  14. Feb 27, 2021 at 10:59 AM
    #3014
    bagleboy
    Scott
    Norcal, Santa Rosa
    Use what you have if it will do the job well. I went the other way and converted the stock negative clamp to a ring connector by cutting off the the band clamp for the battery terminal and drilling a hole through the remaining tab. This preserves the stock crimp. The stock positive clamp has a lug for add-ons and already has a cover but the negative terminal has no such lug. If you ground all your accessories to the chassis you’ll need to upgrade that ground wire. If you don’t then it means a new battery clamp set up for a ground buss cable. I just needed one good connection on each battery terminal for the aux supply and buss bar grounds.
    Bastek[QUOTED] likes this.
  15. Feb 27, 2021 at 12:13 PM
    #3015
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I think this might be a mother of most inventions lol.
    I upgraded mine to one of those "mil spec" terminals when I installed my winch. A moment after cutting off stock negative clamp/rings I realized I should/could have left it alone, but it was already too late. I have a pic somewhere in this thread
  16. Mar 15, 2021 at 9:37 AM
    #3016
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Advise please! (questions at the bottom)
    Moving my starter battery to passenger side so I can put a bigger aux battery in the start location.
    I plan to
    Starter Set Up
    1) extend the stock positive charging cable across the engine bay to connect with my starter battery
    2)extend the fuse box wire across the engine bay and connect with starter
    3) find a ground point on passenger side
    Aux Battery Set Up
    1) hook it all up to RedArc to charge, likely mount on top of fuse box.
    2) use stock ground wire to ground the battery.
    Here are my questions
    1) where should I ground the starter battery which will be relocated on the passenger side. I’ve been told “engine or frame” but could anyone give more detail? How best to attach to engine or frame?
    2) can I use the stock ground wire to ground my aux battery (on the driver side) or is that wire tied into other things?
    3) Because I’m extending the fuse box wire, do I need a fuse coming off the starter battery going to the fuse box or is that redundant?
  17. Mar 15, 2021 at 12:47 PM
    #3017
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    From the looks of it, there is a possibility to install Group 27 battery on pass side. Might be easier than moving and flipping batteries around.
    Joe23 build and BS
    Looks like this might be the bracket
    Greg.Brakes.Tacos likes this.
  18. Mar 15, 2021 at 4:47 PM
    #3018
    REDARC_Ryan
    REDARC_Ryan Well-Known Member
    Michigan
    2021 Tacoma TRD Off-Road
    OME BP-51's, CBI Covert Bumper, Rhino Rack Roof Rack, Mits Alloy Tray & Canopy, Alu Cab RTT, Falken Wildpeak A/T, RIGID Lighting
    It's best to mount the BCDC's behind the grill in front of the radiator in some fashion. They are temperature sensitive, although it may work in that location just be aware that it will shut off at 175F and will taper in efficiency up to that point. We offer universal mounting brackets for the BCDC's that should be on our website soon!
  19. Mar 15, 2021 at 6:43 PM
    #3019
    Overland&UpMoutains
    Parker
    Deleware
  20. Mar 15, 2021 at 6:44 PM
    #3020
    Overland&UpMoutains
    Parker
    Deleware
    I know you are suppose to mount it as close as possible but how far is too far? I was thinking of mounting it in the glove compartment box or under the dash and run the wire through the firewall. Maybe 4-6 feet of wire
