Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Mar 15, 2021 at 6:52 PM
    #3021
    REDARC_Ryan
    REDARC_Ryan Well-Known Member
    Michigan
    2021 Tacoma TRD Off-Road
    OME BP-51's, CBI Covert Bumper, Rhino Rack Roof Rack, Mits Alloy Tray & Canopy, Alu Cab RTT, Falken Wildpeak A/T, RIGID Lighting
    You wouldn't be the first one, it's really just trying to minimize voltage drop works great especially when the Aux battery is in the rear passenger of the bay. The most important parts of the install is proper gauge wire for length, and proper chassis grounding. 4-6ft with 6AWG wire expect in perfect conditions about .08-.1V loss. Nothing crazy, but can be effected by materials, temp, and lots of other factors.
    Glueman likes this.
  2. Mar 15, 2021 at 6:54 PM
    #3022
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    thanks for the info. Check out post 3019, thought on the battery placement? Is that okay or should I make the effort to move switch the starter and aux so the aux has more room on the drivers side
  3. Mar 15, 2021 at 7:00 PM
    #3023
    REDARC_Ryan
    Michigan
    Unfortunately, I don't think I'm qualified to answer that question. I will leave that to other members who may have more experience with that placement. I will say there are tons of Taco's with batteries in that area, so it must be quite safe if done properly near that line. It would make that BCDC install quite a breeze though!
  4. Mar 15, 2021 at 7:02 PM
    #3024
    Overland&UpMoutains
    Parker
    Deleware
    how to say go for it without saying go for it (I appreciate the professionalism)
    REDARC_Ryan[QUOTED] likes this.
  5. Mar 16, 2021 at 6:33 AM
    #3025
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Hello Ryan, I am eventually planning on installing a Redarc BCDC 1225 in my vehicle for a second battery that will be located in the bed of my truck. I just needed some clarification regarding this installation. I have a x2 power AGM battery for my main with a voltage chip to raise the voltage to a consistent 14.5 volts going to the main battery. So going off of the previous conversation, the questions are:
    1. Is it best to mount the Redarc in the engine bay and then run the line to the rear of the bed to the battery or mount the Redarc closer to the battery in the rear of the truck?
    2. With either mounting point, knowing that I will be running about 15 feet of power cord, what Awg wire should I use depending upon the answer of the first question?
    3. I am going to be running a 100 Watt solar set up as well so does that factor into the equation on where it is mounted?
    4. For the second battery, I am planning on running either a Deep cycle battery or Battleborn Lithium battery, will the Redarc lessen the cycle life of either of these 2 batteries (Especially the Battleborn Lithium)?
  6. Mar 16, 2021 at 3:55 PM
    #3026
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think I read/watched somewhere, that said mounting the DC-DC charger closest to the second battery was best
  7. Mar 16, 2021 at 6:32 PM
    #3027
    REDARC_Ryan
    Michigan
    1. It's best to mount as close to AUX battery as possible, this will ensure little to no voltage drop occurs.
    2. Best cable size is in chart below for 25amp/40amp options
    3. It does not, you can just run your hot cable off the solar directly to the BCDC, ground to chassis.
    4. BCDC will most likely improve the life, due to keeping it appropriately charged especially in the Deep Cycles that can be seriously harmed by depletion.
    If you have any other questions don't hesitate to ask!
  8. Mar 17, 2021 at 10:33 AM
    #3028
    utbytn
    utbytn Active Member
    Moab, UT
    2019 TRDOR DCSB ; 2003 TRD Xtracab
    @REDARC_Ryan Will the BCDC charge the starting battery through solar if the aux battery is full? I don't recall finding an answer to this but have seen other brands advertised as doing so.
  9. Mar 17, 2021 at 3:21 PM
    #3029
    REDARC_Ryan
    Michigan
    Unfortunately, it will not back feed into the starter in order to protect the start battery it has an internal battery isolator.
  10. Mar 27, 2021 at 10:59 AM
    #3030
    2020toyo
    2020toyo Member
    Looking for some info on a dual battery setup.. Was looking at both dc to dc chargers, and battery isolators. Was wondering which is better??
  11. Mar 27, 2021 at 11:56 AM
    #3031
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    DC to DC will be better if you are mixing battery types and/or using solar whereas the isolator will be fine for batteries of the same type and if you have a smaller budget
    Bastek and 2020toyo[QUOTED] like this.
  12. Mar 27, 2021 at 10:07 PM
    #3032
    REDARC_Ryan
    Michigan
    a REDARC bcdc line is both!
    BEAR_KNIFE_FIGHT and thebaker like this.
  13. Mar 28, 2021 at 1:58 PM
    #3033
    Overland&UpMoutains
    Parker
    Deleware
    Dual Battery + Solar set up done. For someone with litterally zero electrical experience prior to this not so bad. For sure the RedArc BCDC25 made this way easier. I would 100% recommend it to anyone who is going dual battery and might one day add solar. It’s really not even that more expensive than buying everything piece meal and a whole lot less wire to run.
    Such a cool moment plugging the MC4 connectors in and seeing the solar light turn on. Kind makes me want to put solar on the house, like free energy amazing.
    Set Up:
    Starter Battery: Stock Group 24
    House/Aux Battery: Duracell Ultra Group 27
    Battery Trays: Off Grid 4x4
    Controller/Charger: RedArc BCDC25
    Solar: HQST/Renogy 100W Panel
    Fuse Box: Blue Sea 12 Circut
    Wiring:
    Starter to RedArc: 8 AWG
    House to RedArc: 8AWG
    House Ground to Frame: 4 AWG
    House to Fuse Box: 4 AWG
    Solar Ground to Frame: 10 AWG
    Solar to RedArc: 10 AWG*
    RedArc lives in the glove box. Drilled a hole through the passenger side firewall to pull cables through. Yes there is already a hole but there is a rubber tube coming out of it and it’s a tight fit. Figured it just be easier to make a new one and throw in a grommet that struggle with the tight fitting if I ever need to make adjustments.
    *RedArc instructions say 8 but 10 seems fine given the current and it hides better coming down the windshield trim
    31374820-FAB0-4A49-91D1-4FFEA7744B94.jpg 36A304A5-543D-4FEF-B378-E54AFF15EC28.jpg 22DEB854-883A-4771-90AE-0AED7B629391.jpg 0F75B9DE-CDDD-40EA-B21E-CE155CDF2291.jpg E7B651E2-AE2F-4A94-8D1B-7E36CB667037.jpg
    BigRus75, jenot, Grossomotto and 4 others like this.
  14. Apr 10, 2021 at 2:03 PM
    #3034
    The Pirate
    The Pirate Takoyaki Takoma
    Did that switch come with the RedArc?
  15. Apr 10, 2021 at 2:10 PM
    #3035
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Doubtful, it looks like a Blue-Sea switch.
    SR-71A and The Pirate[QUOTED] like this.
  16. Apr 10, 2021 at 9:50 PM
    #3036
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    Hi, I was looking through posts on adding a second battery behind the back seat. Where do you attach your ground?
  17. Apr 10, 2021 at 10:00 PM
    #3037
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Have heard of people using the seat bolts
  18. Apr 11, 2021 at 1:07 PM
    #3038
    REDARC_Ryan
    Michigan
    That switch is not ours, unsure which brand sorry!
  19. Apr 11, 2021 at 1:50 PM
    #3039
    ivanza
    Bay area, CA
    2017 MGM TRD OR MT
    seat bolts don’t sound like a good idea. They are coated surfaces so you only have the thread for conduction. Probably have to run it to a chassis ground.
    Tacman19 and REDARC_Ryan like this.
  20. Apr 11, 2021 at 7:36 PM
    #3040
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    So is the spot where the battery ground lug is bolted. There are threaded holes all over the rear cab wall as well as under the center console.
