Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Apr 11, 2021 at 10:00 PM
    #3041
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    There is apparently a harness ground under the drivers seat where pointed. Anyone use it?
  2. Apr 13, 2021 at 3:18 AM
    #3042
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I'm using a threaded hole behind rear passenger seat (in DC). I scraped off some paint from the face of it, and it works well for me.
    It's behind the battery, not visible in the pic.
    SR-71A likes this.
  3. May 10, 2021 at 9:55 AM
    #3043
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    In the design phase for my first dual battery setup, and THIS comment about winch power got my attention, as I am running a Warn 9.5xp currently. I know it has been a few years, so I am curious how this setup has aged and if you ran into any issues?
    Ngneer likes this.
  4. May 10, 2021 at 9:56 AM
    #3044
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Anyone install a fuse panel on the passenger side of the engine bay (over the top of the ABS module) as opposed to the drivers side?
  5. May 10, 2021 at 10:00 AM
    #3045
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Most people do driver because most wires will come in through the driver side fire wall since the switch will be near the driver
  6. May 10, 2021 at 10:00 AM
    #3046
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Winches are high current draws. So short wire runs are king. In a Tacoma your closest battery is going to be the main (unless you do a side by side setup). Either way you will also want to make sure the batteries are linked together through the ML-ACR (or similar) before starting a pull
    Lineback[QUOTED] likes this.
  7. May 10, 2021 at 10:06 AM
    #3047
    Camby
    Brian
    Denver
    I realize that, however I have a catch can and a SC coolant reservoir on the driver side, hence why the only spot I have left in the engine bay is over the top of the ABS module.
  8. May 10, 2021 at 10:12 AM
    #3048
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have been considering it, but have not built a mount yet.
    I also have a catch can, and a supercharger waiting to be installed.
  9. May 10, 2021 at 10:12 AM
    #3049
    Overland&UpMoutains
    Parker
    Deleware
    what’s on top of the current fuse box?
  10. May 10, 2021 at 11:54 AM
    #3050
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I’ve seen a few. The other reason for the driver’s side install is shortest possible cables from the battery but some install in the cab or bed so there’s no real limitation.
  11. May 10, 2021 at 11:56 AM
    #3051
    Camby
    Brian
    Denver
    There be no room in the driver side corner
  12. May 10, 2021 at 12:45 PM
    #3052
    Overland&UpMoutains
    Parker
    Deleware
    yea there is, put it in top of the OEM fuse box
    Like this
  13. May 12, 2021 at 6:39 AM
    #3053
    Camby
    Brian
    Denver
    I’d like to keep access to my stock fuse box
    bagleboy likes this.
  14. May 15, 2021 at 9:34 PM
    #3054
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    I put a hinge on mine with a wing nut. Couple of turns and I can get to it.
    Zim
    EDIT: honestly if you're blowing a fuse or having a relay issue, there's a problem some where else....just saying.
  15. May 16, 2021 at 12:45 AM
    #3055
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yeah but it’s there for a reason...ditto. It’s tempting and I see it plenty but its not for me either.
    Tacman19[QUOTED] likes this.
  16. May 16, 2021 at 12:57 AM
    #3056
    bagleboy
    Scott
    Norcal, Santa Rosa
    I prefer to run ground returns rather than scraping paint and having to upgrade the chassis ground to the battery. For in-cab stuff I use a common buss w/#10 back to the battery for the low-medium draw accessories and dedicated returns for big stuff but there are threaded holes all over the place, mostly M6 and M8.
  17. May 25, 2021 at 5:43 PM
    #3057
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Any chance you have a photo or three? And a wiring schematic? Thanks.
  18. Jul 5, 2021 at 4:37 AM
    #3058
    Overland&UpMoutains
    Parker
    Deleware
  19. Jul 28, 2021 at 8:51 PM
    #3059
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    which size is that yellow optima?
  20. Jul 28, 2021 at 11:10 PM
    #3060
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Based on the post configuration, I'd say it a group 34/78. @Blackdawg
