Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jul 13, 2022 at 9:35 PM
    #3541
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    ML-ACR failed. Tried new switch, no change, replaced ML-ACR and all good
    steveo27[QUOTED] and shiftd like this.
  2. Jul 18, 2022 at 8:48 PM
    #3542
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Finished mine this evening. I utilized the Slee tray which includes a pretty stout side bracket to reinforce under the factory mount. Hopefully that stops it from cracking — from what I understand these are the best trays for this setup.
    Everything outside of the tray was fully custom. Thanks to @paranoid56 for working with me on some custom brackets. We designed an over-tie-down holder for some Bussmann modular fuse holders. These things are great and are rated up to 400A (they use a MIDI fuse). I crimped all of the battery cables with a hydraulic crimp tool and pure copper wire. There’s some 1/0, 2, 4, 6, and 8 in this setup :rofl:
    I had to relocate some of the factory wiring which was kind of a pain in the butt, but hey what can you do. The setup works off of a RedArc BCDC 1220. My batteries are small enough that the 20A charge rate should be more than enough.
    I don’t know how long this project took, but hopefully it’ll be worth it. I’m just glad I didn’t blow my ass up!
  3. Jul 20, 2022 at 8:13 AM
    #3543
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Kinda figured based on the symptoms.
    Glad you got it sorted.
    Laxtoy[QUOTED] likes this.
  4. Jul 20, 2022 at 8:20 AM
    #3544
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    which way did you have it mounted? when i had them mounted terminals up i had a lot more failures then once i had the terminals down
  5. Jul 20, 2022 at 9:09 AM
    #3545
    Laxtoy
    Maltby, WA
    EE7E521D-7F1B-4DC3-88FA-AF57AA9EB903.jpg This was how it’d been mounted since 2016, everything worked without flaw until I was welding with just the negative terminals disconnected about a month ago. My suspicion I should have disconnected both negative and positive terminals from both batteries to make sure everything was isolated
  6. Jul 26, 2022 at 9:27 AM
    #3546
    ponts
    ponts Well-Known Member
  7. Aug 13, 2022 at 8:02 AM
    #3547
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    !!! Where you have your battery charger is where I want to put my secondary fuse box. Do you think your guy would be up for making such a tray???
  8. Aug 24, 2022 at 10:14 AM
    #3548
    steveo27
    Pittsburgh
    I went through most of this thread and Google, anyone mount a battery tray/box up along a frame rail under the truck?
    I’d like to double my house battery capacity without upgrading the whole system.
    LiFePo4 would be ideal but out of the question at the moment due to budget.
    What’s in my budget is just adding a second deep cycle battery to the current system to double the capacity.
    No room under the hood or in the bed for one though.
    Any thoughts?
  9. Aug 24, 2022 at 10:38 AM
    #3549
    paranoid56
    San Diego
    14 double cab taco
    not on the frame, but in the spare tire well. worked well for where it was at.
    JDSmith, shiftd, steveo27 and 2 others like this.
  10. Aug 24, 2022 at 11:06 AM
    #3550
    RyanG1990
    RyanG1990 New Member
    Been reading through the forums before jumping in and doing some serious mods to my truck.
    Dual batteries is on the list.
    Question for you guys. With something like the redarc setup from off grid engineering does disconnecting the main factory battery negative ground complicate things? Sometimes it's advised to remove the negative cable if your doing something like working around an airbag or the like. With the redarc setup would you first have to disconnect the redarc setup, then worry about the factory battery or is it ok to keep things intact and just disconnect the factory ground?
    I'm still in the research phase and trying to wrap my head around it all.
    Thanks!
    TacoEspecial likes this.
  11. Aug 24, 2022 at 11:33 AM
    #3551
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Be safe - disconnect both negative battery terminals.
    That way, there is no chance current could flow backwards through your Redarc.
    TacoEspecial and shiftd like this.
  12. Aug 24, 2022 at 11:37 AM
    #3552
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Man, I could NOT get away with a battery in that orientation/location in the midwest. Jealous of you desert folks.
    shiftd likes this.
  13. Aug 24, 2022 at 12:00 PM
    #3553
    paranoid56
    San Diego
    14 double cab taco
    yea, its nice having zero rust issues lol
  14. Aug 24, 2022 at 12:40 PM
    #3554
    RyanG1990
    Thanks, that's a simple way to be sure. Started overthinking it thinking I'd have to disconnect the positive than the negative for the aux before doing anything to the main. Basically the opposite of an install
  15. Aug 25, 2022 at 10:38 AM
    #3555
    steveo27
    Pittsburgh
    If I didn’t have my spare there still, I’d do that.
  16. Aug 26, 2022 at 6:38 AM
    #3556
    TacomaWillow
    TacomaWillow Well-Known Member
    Catherine
    2022 4WD 6 cyl SR5
    Which IGN fuse did you use? There are two that have IGN in the label.
  17. Aug 26, 2022 at 6:46 AM
    #3557
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I will check for you. This is the only picture i have right now. I think i used IGN. A multimeter would be helpful too
  18. Aug 26, 2022 at 11:48 AM
    #3558
    TacomaWillow
    Catherine
    2022 4WD 6 cyl SR5
    I've got a 3rd gen but may have the same fuse mapping. Thanks!
    fatfurious2[QUOTED] likes this.
  19. Aug 31, 2022 at 9:54 AM
    #3559
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Quick question guys, I have a renogy 100ah deep cycle battery. I'm curious if this can be run to connect to my main agm battery and charge off of it? I only want to use this renogy to run my fridge.
  20. Aug 31, 2022 at 9:56 AM
    #3560
    fatfurious2
    David
    Ashburn, VA
    You will probably need something between both
