Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. May 29, 2023 at 11:02 AM
    #3701
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Better fit for me. 25 extra lbs in stock location and 50# on passenger side. Still room for an air intake routed through firewall, maybe. 120amp hr. reserve. In a pinch could give someone a replacement battery on the trail and still gave an aux.
    May end up having to ditch passenger side battery if it interferes with putting air intake through the firewall so this way will also let me do that easily.
    Wanted lots of reserve amps to try some all electric cooking.
    Also trying out electric heater and blanket in my shell.
    And gotta keep my ice cream and ice cubes frozen.
    hoyden and sawbladeduller like this.
  2. May 30, 2023 at 2:24 PM
    #3702
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    replaced a 31M and a 35 for two 35's this morning. great to shed ~30lbs on the driver side. HKB voltage booster placed.
    TacoEspecial likes this.
  3. Jun 5, 2023 at 9:37 AM
    #3703
    shwilly
    shwilly Well-Known Member
    For those who have their second battery in the bed...
    How are you routing cables into the bed? Are you drilling holes in the composite bed? Where are you passing them through?
    I recently got a canopy and plan to add a second batter near the front of the bed on the driver side.
  4. Jun 5, 2023 at 10:07 AM
    #3704
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    For cable pass throughs into the bed, I use Cable Clams from Blue Sea - https://www.bluesea.com/products/1001/CableClam_0.68in
    Drill a hole for cable, and 4 small holes for the screws to secure the clam. They work great, and are, of course, water tight.
    You might want to consider placing the battery on the passenger side. The driver's sides of these trucks are heavier (stock battery, fuel tank, driver) so any weight you can move to the pass side is good.
    thebaker likes this.
  5. Jun 5, 2023 at 1:22 PM
    #3705
    shwilly
    Thanks for the pointer. Those seem similar to these.
    Did you pass through on the bed sides, between cab and bed or floor?
    Aws123 likes this.
  6. Jun 5, 2023 at 2:11 PM
    #3706
    Scott B.
    Scott
    Georgia
    I passed through the side of the bed, about 4" back from the front, and maybe 4" above the floor.
    Wherever you go through, before drilling any holes, make sure you have sufficient access/room to the backside.
  7. Jun 5, 2023 at 3:56 PM
    #3707
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    I have run a cable from the front passenger side back along the frame and entered the bed thru the right rear "cubby" box. This cable connects a DC-DC charger, for the third battery.
  8. Jun 20, 2023 at 4:46 PM
    #3708
    99ranged
    99ranged Well-Known Member
    Northern CA
    '19 TRD OR
    My 100ah battery install behind the rear seat
  9. Jun 20, 2023 at 7:06 PM
    #3709
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    What Redarc did you use?
  10. Jun 20, 2023 at 9:16 PM
    #3710
    99ranged
    Northern CA
    '19 TRD OR
    1225D
    Tacodog[QUOTED] likes this.
  11. Aug 1, 2023 at 11:18 PM
    #3711
    Bob K
    Bob K Well-Known Member
    Bob
    2017 TRD Off Road
    Nice finish work with the crimps, loom, and shrink tube.
    Bastek[QUOTED] likes this.
  12. Aug 27, 2023 at 7:47 PM
    #3712
    Aws123
    Aws123 Well-Known Member
    Adam
    Colorado
    2019 tacoma trd off road
    I used these in the front passenger side corner of the bed up on the wheelhouse area. The cables run behind the wheelhouse liner. Those cable glands hold everything tight.
  13. Aug 27, 2023 at 8:39 PM
    #3713
    Aws123
    Adam
    Colorado
    What are yalls experiences with lithium house batteries in cold weather (10- 15° nights in colorado). Been running an x2power agm house battery and looking for more capacity for heated blankets and whatnot. Trying to decide on adding another agm or going lithium. Ive seen the heated batteries. Just not sure on the performance when it gets near 0°
  14. Aug 27, 2023 at 8:47 PM
    #3714
    Bob K
    Bob
    2017 TRD Off Road
    I have 4 Battleborn batts in my 18ft trailer in the "basement" (i.e. under the bed). Though that area is not heated, I find that the conductive heat through the rest of the trailer keeps the battery space well above any concerning temps even when outdoor temps are in the single digits. Plus, lithium batts are good for low temp discharge (at least Battleborns are...down to -4 degrees F). It's just charging that gets limited as the temps drop.
    https://www.youtube.com/watch?v=mTeoweIkKgc
    Lithium is superior to AGM in just about every way, but they're pricey. One 100Ah lithium is equivalent to 2 AGMs, and weighs half as much. Do you think the space where you'll have the batts will fall far enough to be of concern?
  15. Aug 27, 2023 at 9:22 PM
    #3715
    Aws123
    Adam
    Colorado
    Well they are in the truck bed under a diamondback bedcover. Better than outside, but not by much lol. Im leaning towards staying with agm for price and ease of adding a battery. Just curious on yalls experiences.
  16. Nov 15, 2023 at 7:56 AM
    #3716
    cacocker
    cacocker Occasional Smartass
    Corey
    Seattle
    2017 TRD OR DCLB MGM
    Mods: https://bit.ly/34WhzsW
    There's a ton of information in this thread, and I'm having a hard time reading through it because I don't really know what I'm reading. Can somebody pointed me to an idiot's guide to a dual battery set up with what is essentially a secondary fuse panel?
  17. Nov 15, 2023 at 10:03 AM
    #3717
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Give it time. Start by taking notes on each part with its name, function, and where it sits in the circuit as doing so will help you internalize and really understand it. Even an idiots guide will still take time and multiple rereadings to absorb. Since there are many different ways people use them reading this thread along with build threads you come across will provide a broad range to inform your design choices. Bookmark those threads you like but try not to simply copy the first one you like and understand. Let it sink in. You’re messing with the electrical system of a sizable investment so diving in with only an “idiots” understanding can cause problems. Reading is free.
    Aws123 likes this.
  18. Dec 9, 2023 at 10:22 PM
    #3718
    GrahamJ
    GrahamJ Member
    Graham
    Dumb question, maybe! If install a new AGM battery can I use my existing OEM battery as a secondary battery in a dual. Battery set up?
  19. Dec 10, 2023 at 3:28 AM
    #3719
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @GrahamJ That is how mine is set up. Did my install in April 2016 with a Deka Intimidator AGM battery. At the time I had a Costco-Interstate lead acid battery. Both are still functioning. In 2017 I added the diode to bump up the voltage regulator output to 14.2 volts.
  20. Feb 23, 2024 at 6:33 AM
    #3720
    Teamrivers
    Teamrivers Well-Known Member
    Brent
    Atlanta, GA
    2018 TRD Off Road 4x4 DBL 5.5
    Diamond Back HD, full interior light change, DiodeDynamics main lamps, Caliraised amber fogs & ditches, Caliraised 25 Degree sliders no plate, SSO slimline front bumper w/ 20" LED Smitty Gen3 winch, Barricade rear bumper with rear in bumper lights from SuperbriteLEDs, Budbuilt rock 2 plates with rerouted exhaust, Method 306, 295 Ridge Graps. OEM Kings tuned from Filthy, Deaver Exp 1, SPC UCAs, 5.29 diffs. Dash mounted 1/4 threaded accessory plate. And a TRD Pro grill...assuming I qualify for pro status.
    Not finding the answers to questions for what I probably already know. I run a dual battery setup with a 200ah LiFEp0 as an auxilllary for rear components and that stays fresh with a DC-DC charger with power from alternator or solar. I have manual switches for rear lighting, compressors, etc. that draw power off of the auxillary battery, and use OEM style switching up front for light bars, pod lights, etc. Is there a switching panel solution that can conrol everything from a single panel, but derive power separately? I can easily install a cheapo Auxbeam that is powered from the starter as a standard install, but I'd need to have relays in the rear (compressors are on a heavy duty 200amp solenoid anyway). I've reached out to switchpros and auxbeam and they're scratching their heads...
