Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jun 18, 2025 at 9:59 AM
    #3861
    trezpass
    trezpass Member
    2023 TRD PRO
    Starting to get it sealed up. then its time to cut some access holes and construct some storage boxes.
    N64_Wallmaster and POOLGUY like this.
  2. Jun 22, 2025 at 8:12 PM
    #3862
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Just finishing a removable powerstation set up charged from the start battery through a dcdc charger.
    Tacodog likes this.
  3. Jul 6, 2025 at 1:43 PM
    #3863
    trezpass
    trezpass Member
    2023 TRD PRO
    Updates on my dual battery/bed storage system.
    Was able to find a water jug with the right dimensions to fit in the cabinets, then got it plumbed up with a quick disconnect for the Dometic faucet.
    got the electrical covered with polycarbonate…
    and finally got around to cutting out the storage entry and piecing together some doors…
    hopefully get this finished up in another few days.
  4. Jul 8, 2025 at 11:21 AM
    #3864
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Upgraded (or, changed) the house electrical system from AGM to LiFePO4 and finally got the write-up posted. Was a fun project!
    Happy to answer any questions!
    As a result, no longer using - and so selling - my ML-ACR if anyone's interested: https://www.tacomaworld.com/threads...ic-charging-relay-with-manual-control.861892/
    For anyone not wanting to read the posts above, here's a quick TL;DR.
    Wiring diagram for the new system:
    Cabinet I built to hold everything:
    Electrical components installed (covers missing on the various bus bars/fuse panels):
    Ptteddy, wradar, rob1208 and 7 others like this.
  5. Jul 10, 2025 at 7:57 PM
    #3865
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Enjoyed the read. Very detailed and informative. I currently have the mg-acr so I was curious regarding your switch to the other system. Very informative. I have to outfit my wife’s vehicle so have some things to consider.
    turbodb[QUOTED] likes this.
  6. Jul 12, 2025 at 3:04 PM
    #3866
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Your project is very inspiring! I’m in the middle of my own battery project, relocating both batteries from the engine bay to the inside of the cab. One thing I kept going back and forth on is incorporating a LifePO4 Battery or not. Ultimately I chose to stay with a AGM Battery because of potential Winch Use.
    Relocating because of the 2nd Gen Inner Fender Core collapse problems..
    Almost Ready to run Cable to the front..
    Question for the 2ndGen Owners, where are y’all installing your ML-ACR switch?
  7. Jul 12, 2025 at 7:36 PM
    #3867
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Love to see a picture of your battery collapse from the engine bay side. Do you do a lot of fast driving over rough roads/trails? Or what have you attributed the sheet metal damage to? Were both batteries in the original battery position? How were the batteries fixed in position.
  8. Jul 21, 2025 at 1:57 PM
    #3868
    wradar
    wradar Well-Known Member
    Virginia
    2021 DC OR // 2002 DC Limited TRD OR(sold)
    What is a good voltage to use as a low voltage cut-off for the starter battery (OEM AGM)?
    I have a single-battery set-up, but have several auxiliary items running off of it through a Victron Smart Battery Protect 12/24V 65A. It's configurable for the low voltage cut-off and restart voltage thresholds. Curious what folks tend to use for their low voltage isolate/cut-off settings on dual battery set-ups to ensure they can still start off the starter battery.
  9. Jul 21, 2025 at 2:19 PM
    #3869
    turbodb
    Dan
    PNW
    AdventureTaco
    Well, on a dual battery system, all of the aux items (or as many as possible) are hooked up to the second (house) battery. That house battery can be run down to nothing and the starting battery will still start the vehicle. That's the whole point.
    If you've just got a single AGM starting battery and you're running your accessories off of that, I'd make sure to keep it above 11.5v at a bare minimum on a strong (reasonably new) battery. 11.8v would be safer.
  10. Jul 21, 2025 at 3:35 PM
    #3870
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Voltage is one factor. The other is the battery’s CCA. You can have a battery that shows 12 volts at the terminals but will not crank over the engine if it only tests at 300 CCA’s.
  11. Jul 21, 2025 at 4:10 PM
    #3871
    turbodb
    Dan
    PNW
    AdventureTaco
    This is true, but hard(er) to measure in the field since many might bring a multimeter, but rarely a CCA tester. It's also not what any of the devices that @wradar wants to hook up to his battery are basing their on/off state on; those are all using voltage, hence my suggestion to keep the voltage reasonably high.
    wradar likes this.
  12. Jul 21, 2025 at 4:40 PM
    #3872
    Chuy
    Lakeside, CA
    Silver Taco
    No doubt, low voltage is a general indicator of a battery’s health. Measuring cca’s in the field is easier than ever. You can get a small cca tester for under $20 now. I have three but never carry them in the vehicle. I measure at every oil change and before a long trip.
  13. Jul 21, 2025 at 4:59 PM
    #3873
    wradar
    Virginia
    Thanks, all. Agreed, a CCA cut-off would be amazing, but until Victron, RedArc, or the others get to cracking on the production of such a beast, the next best thing (voltage) is what I’m left with for automated load-shedding engine-start-up security. I went with 12.2V cut-off and 12.5V restart just to really hedge my bets.
    turbodb likes this.
  14. Jul 21, 2025 at 5:03 PM
    #3874
    turbodb
    Dan
    PNW
    AdventureTaco
    12.2v might be a little high; keep an eye on it when you're in camp. An AGM/Lead-Acid can get pulled down into the 12v range pretty easily when loads are running (fridge, etc.) and then climb back up when they are off. I noticed that my Dometic Fridge has a "high" cutt off of 11.8v, which is Dometic really saying "be 100% sure the fridge doesn't kill the battery," which is why I started there.
    Also, a lot of the victron stuff can show voltage over time via Bluetooth. You could watch that graph as devices turn on/off to see how things end up over the course of ~8-12 hours (to simulate overnight).
    Something like this that I get from my Victron Solar setup:
    wradar[QUOTED] likes this.
  15. Jul 21, 2025 at 5:07 PM
    #3875
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Solar panel is mounted and working perfectly. Fridge running 24/7 and per the solar charger app battery is still at 100%. Since I use a smart isolator it charges BOTH batteries as well
    N64_Wallmaster likes this.
  16. Jul 21, 2025 at 5:12 PM
    #3876
    wradar
    Virginia
    Great info, thanks! I'll make the tweak.
    I installed a shore power connection for a battery charger in order to let me keep a very low-draw radio scanner running when I park at home. On the (likely) chance that I forget to turn the scanner off when I park at work or elsewhere, I just want to be sure I don't run the battery down so low it won't start. Since it's not powering a fridge or anything I actually need to keep running, a higher-level cut-off would probably suffice, since my priority is vehicle starting, not aux power.
    I've been letting it sit unplugged in the driveway today and monitoring the voltage as it drops (the Victron has a BT-enabled app that has a current voltage readout), and I'm several hours in and it's only dropped about .3V. If it makes it ~8 hours and stays above cut-off, great, but as long as the cut-off ensures it starts, that's key.
    While the experiment runs, I'll keep researching small form-factor LiFePo4 batteries to give me 50-100A of "I don't need to worry about this anymore." :D
  17. Jul 21, 2025 at 5:24 PM
    #3877
    wradar
    Virginia
    That's a handy feature! That clinches it: guess I need to get a solar set-up. :cool:
  18. Jul 23, 2025 at 8:51 PM
    #3878
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    N64_Wallmaster and essjay like this.
  19. Jul 23, 2025 at 10:01 PM
    #3879
    MonkeyProof
    SoCal- SGV
    I have that very same battery gauge in that same exact spot, and I'm pretty sure you were the inspiration for that when I did my first dual battery setup a few years ago!! Unfortunately my ARB Locker Switches occupies those slots. I'm thinking about removing the Inverter Switch to make room for the ACR Switch. I have used the Inverter once or maybe twice previously, not even sure if it still works to be honest.
    Some progress made... 2/0 Gauge Cable x2 27M AGM Batteries
  20. Jul 24, 2025 at 8:50 AM
    #3880
    steveo27
    Pittsburgh
    I jumped the clutch bypass switch at the pedal and tucked the switch up behind the dashboard
    The inverter is kinda useless so that route isn’t a bad idea.
    Theres enough slack in the harness you can hang the button right above the “ashtray” and just remove the pocket if you need access.
    MonkeyProof likes this.
