Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Dec 21, 2015 at 11:09 PM
    #701
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    You can run all your accessories on the "other" battery and your truck will start every time on the "main" battery
  2. Dec 21, 2015 at 11:14 PM
    #702
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Should I run my winch on the main battery? I was looking at this diagram.
  3. Dec 21, 2015 at 11:19 PM
    #703
    MJonaGS32
    MJ
    SF Bay Area (East)
    I run my winch on my main battery because it pulls a lot of amps and the main battery is closest to the alternator. Some people run winches on the aux battery. I think I remember someone saying because if your truck dies, you can still get yourself out of a situation with the winch... or something like that. idk, I thought it made more sense to put it on the main battery, especially bc I have a ton of accessories hooked up to my aux battery
  4. Dec 21, 2015 at 11:21 PM
    #704
    anthony250f
    Anthony
    San Diego, CA
    Will the stock alt be able to charge both batteries? I want to do a bigger alt but it won't fit due to uca gussets
  5. Dec 21, 2015 at 11:23 PM
    #705
    MJonaGS32
    MJ
    SF Bay Area (East)
    yes
    how close are your uca gussets? my 250a alternator isn't thaaat much bigger than oem. Damn I knew I shoulda taken a comparison pic
  6. Dec 21, 2015 at 11:24 PM
    #706
    anthony250f
    Anthony
    San Diego, CA
    Really close...like almost touching
  7. Dec 21, 2015 at 11:34 PM
    #707
    MJonaGS32
    MJ
    SF Bay Area (East)
    stock alt will be fine then. maybe just do the Big 3 (or 4) upgrade
  8. Dec 22, 2015 at 8:07 AM
    #708
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Ya, I have 3 batteries now and a Big 4. My stock Alt charges all of the batteries just fine.
  9. Dec 22, 2015 at 8:11 AM
    #709
    anthony250f
    Anthony
    San Diego, CA
    Wow that's crazy...I don't use many accessories at one time...I just wanted one so incase I did leave something on and I won't get trapped off road, but I don't wanna spend the big $$$ on a high tech system
  10. Dec 22, 2015 at 8:52 AM
    #710
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Eventually I am doing a dual battery but until then I have one of these. $100 and it will start a dead battery between 6-10 times on one charge. You can charge it via cig lighter while you're wheeling on set it up with a $50 goal zero solar panel and never be stranded! Cheap insurance.
    The snap on truck sells it so it's good enough for me
    http://www.amazon.com/Portable-Powe...r=8-1&keywords=Pocket+battery+jumper+Rockford
  11. Dec 22, 2015 at 9:04 AM
    #711
    anthony250f
    Anthony
    San Diego, CA
    I have two of these (they were free) never used it on my truck but it doesn't work great
    http://www.peakauto.com/products/electronics/jump-starters/600-peak-amp-jump-starter/
  12. Dec 22, 2015 at 9:10 AM
    #712
    bayareataco
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
  13. Dec 22, 2015 at 4:14 PM
    #713
    Mesaboogie13
    Mesaboogie13 Well-Known Member
    Bryan
    Louisiana
    '15 DCSB TRD OR
    Work in Progress...
    After reading the entire post I have a few questions for our veteran electricians with the 12V system. I plan on placing my second battery behind my passenger seat like a few of the members on here have done. I have a few questions before i start after christmas!!
    First:
    I have already purchased the ML-ARC and need to know if it matters where I place the system... closer to my starting battery or place it behind the seat with battery and aux panel. Does it matter?
    Second:
    I have figured on roughly 16 feet from battery to battery. Does anyone think that number to be different?
    Third:
    Will 1/0 be the most correct gauge o connect the two together?
    Finally there has been a long discussion about placing fuses between the batteries. yay or nay?
  14. Dec 22, 2015 at 5:05 PM
    #714
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I have spent quite a bit more then I expected but, soon, I will be done and I will be able to do all that I needed. It is understandable to only build it to what is needed by the owner.
    I would like to start off saying that I am not an electrician but I have been building my own 12v system myself.
    First:
    I have seen it done both ways. I have mine installed right next to the aux battery because that is what worked for my system but I have seen others install theirs right next to the main battery. From my perspective, it is probably better that it is as close to the Main battery as possible since that is less unprotected wire that could have issues.
    Second:
    That sounds about right. I had 25' of cable and that allowed extra to jump between the three batteries and start the build of a Big 3 kit.
    Third:
    This is all dependent on how many Amps you plan to put through the ML-ACR and the distance. I used 2/0 because I plan on using more amps from time to time. The ML-ACR is rated to 500amps but using 2/0 put me at 225amps continuous and 400amps intermittently. The instructions do not use anything below 2/0 so I couldn't say for sure what it would be for 1/0. 4/0 to 2/0 is a 75amp drop so 1/0 might be 150amps?
    Finally:
    Yes, I didn't know this at first and had to redesign everything while I was building it to accommodate the fuse before and fuse after the ML-ACR. I think it is important to protect the electrical system that you are spending so much time and money to build.
  15. Dec 22, 2015 at 5:10 PM
    #715
    Mesaboogie13
    Bryan
    Louisiana
    '15 DCSB TRD OR
    Work in Progress...
    What size fuse did you use before and after the ML-ACR. I will probably go with 2/0 then, i picked up the ARB CKTMA air compressor and at full load can pull, i believe 80amps. By placing the ML-ACR closer to the main battery it frees up more space behind the seat for the fuse box and relays.
  16. Dec 22, 2015 at 7:56 PM
    #716
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I have all 300 anl type fuses. one before the ML-ACR and one after. There is one more between the battery and the Bussmann fuse panel.
  17. Dec 22, 2015 at 10:50 PM
    #717
    Buda Pest
    Buda Pest Well-Known Member
    Can anyone help me? It's probably been answered here somewhere but I don't have the attention span to read 37 pages to hopefully find something.
    I want a dual battery system, one that charges off the truck naturally but the second battery is isolated from the rest of the truck. I wish to charge the battery off the truck but use it only for aux items, i.e. off road lights, winch, shower, etc. Anyone have any diagrams for this specific wiring request? Also, what do you guys suggest I use to monitor the charges of each battery?
  18. Dec 23, 2015 at 2:48 AM
    #718
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    Does this help?
    Mesaboogie13 likes this.
  19. Dec 23, 2015 at 11:10 AM
    #719
    Buda Pest
    Where did you find this? It looks about right.
  20. Dec 23, 2015 at 3:19 PM
    #720
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    I think you can find them at bluesea website
