Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Feb 18, 2016 at 5:37 AM
    #921
    Subdewd
    Subdewd Well-Known Member
    Pearl Harbor, HI
    15 TRD OR 4x4
    That's a good looking mount. I'm wanting to do something similar. Right now I just have a mess of wires and nothing permanently mounted. Did you have a shop make that for you? Or did you do that yourself?
  2. Feb 18, 2016 at 5:42 AM
    #922
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    I designed it and had a shop make it for me.
  3. Feb 18, 2016 at 6:26 AM
    #923
    Subdewd
    Pearl Harbor, HI
    15 TRD OR 4x4
    Thanks! Any possibility to get the drawing/dimensions of it? Might look at doing something similar and would be a good starting point. You mounted it to those two holds on the side right?
  4. Feb 18, 2016 at 6:26 AM
    #924
    docloco
    Ron
    Florida
    PM me.
  5. Feb 18, 2016 at 6:45 AM
    #925
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    I know this is in here somewhere, but I can't find it. What gauge wire are you guys running from the starting battery to the ML-ACR? I was planning to use 1/0. Is that sufficient?
    abarber11 likes this.
  6. Feb 18, 2016 at 8:15 AM
    #926
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    1/0 is what I used
  7. Feb 18, 2016 at 8:18 AM
    #927
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
  8. Feb 18, 2016 at 9:11 AM
    #928
    DaveEli
    David
    Virginia Beach
    I am running the 1/0 cable to the bed for my second battery from the ML-ACR.
  9. Feb 20, 2016 at 6:00 AM
    #929
    DaveEli
    David
    Virginia Beach
    Another question, for those of you using the ML-ACR, why are some using the Isolation #1 brown wire and some not? And where are you hooking it up?
  10. Feb 20, 2016 at 7:10 AM
    #930
    abarber11
    ATX
    2011 DCSB
    You don't need to use it. My understanding is it's a feature for boats where sometimes they crank the engines for extended periods before they start. The brown wire would keep the batteries isolated for 3 or 5 minutes after key on rather than 30 seconds
  11. Feb 20, 2016 at 8:39 AM
    #931
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I hooked it up to the accessory in the fuse box.
  12. Feb 20, 2016 at 9:30 AM
    #932
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    You don't need it in the car. It too keep sensitive electronics from being exposed to high crank amps at startup.
  13. Feb 20, 2016 at 10:57 AM
    #933
    DaveEli
    David
    Virginia Beach
    You mean the fuse box under the hood, or in the cab?
  14. Feb 20, 2016 at 8:51 PM
    #934
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Under the hood. I used a meter to find a switched power that I tapped into, wouldn't auto switch on and off without it.
    DaveEli[QUOTED] likes this.
  15. Feb 22, 2016 at 9:47 PM
    #935
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Read all 48 pages!
    I don't have any high power accessories. My reason for a 2nd battery is primarily as a backup system. I tend to off-road in the dez solo. I'm avoiding the high tech stuff and going simple and affordable. I've purchased everything but the battery.
    I will be upgrading the wiring with two gauge except I got 1/0 gauge for the alternator wire. My first question pertains to the alt wiring. My 07 Taco has a four gauge wire from the alternator to the fuse box. Wire bolts on 8mm bolt on engine end of the box. From same end below the box is a six or eight gauge wire that goes to the battery. This wire does not appear to be easily replaced and not much is mentioned here on upgrading this wire. Has anyone replaced it? How? Are you guys bypassing it?
    ebbs15 likes this.
  16. Feb 23, 2016 at 5:03 AM
    #936
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I read all 48 pages too!
    No high powered accessories as well... until I get a winch. I need the backup system for your same reason, since I also to tend to go off-road solo... in the mountains (no desert here.) After looking at all the whiz bang gizmos and doodads and re-evaluating my complete electrical ineptness, I will also trying to avoid the high tech stuff and go simple and affordable. I haven't acquired the battery as well, because i haven't figured out where to locate the 2nd battery, as I've heard varying opinions on this thread. I think I'll locate the second battery in the passenger side space in the engine bay. Not sure yet.
    I will however, likely go with the Stage 1 kit that @BamaToy1997 offers, since it appears to be a simple and complete solution and I think it deals with all the wires that you have mentioned. The options for a second battery isolation system is also offered by Bama when I need it later.
    Good luck with your install... post up your progress if you can.
    Thanks.
  17. Feb 23, 2016 at 9:00 AM
    #937
    abarber11
    ATX
    2011 DCSB
    I'm not sure if I understand exactly what you're talking about, but if you're referring to the small, short wire from the positive battery terminal into the under-hood fuse panel I can say that almost none of us replace or bypass it. There's a couple reasons:
    1. If you're not connecting high draw items to the existing internal or external stock fuse panels it's unnecessary to replace it because there's no more draw than normal
    2. It's a pain in the ass to get to and replace
    3. We hook up auxiliary blue sea fuse panels directly to the battery and run extra equipment off those.
    4. <s>That wire isn't part of the charging system so won't affect the efficiency at all<s> edit: in the stock harness, the wire from alternator output does route through the fuse panel. apologies.
    Bottom line is that there is no reason I know of to replace it or bypass it. The wire is plenty big to run all of the stock electronics for the truck.
  18. Feb 24, 2016 at 12:15 AM
    #938
    Chuy
    Lakeside, CA
    Silver Taco
    Yes, that wire, but I disagree with #4, that wire is what charges the battery (on my 07; could be diff on other model years). I find it counterintuitive to upgrade all the wiring except that one. I eventually plan on replacing my alt with a 200 amp model; so, I'll be looking to upgrade that wire by replacing it or adding a jumper wire. What I picture doing is running a two gauge wire from alt to relay; a two gauge wire from relay to fuse box, replacing the current four gauge wire. Then, either running a two gauge wire from relay to battery, or from the fuse box to battery. I may leave the short wire alone because I don't know what else may be under the fuse box to it.
    I'm putting together my own upgrade kit. Below is what I've gathered so far (everything purchased on Amazon):
    Temco two gauge wiring. $32 for 10' each of black and red housing. Battery wiring.
    Crimp Supply 1/0 wiring. $23 for 10' of red housing. Alt and starter wiring.
    200 watt Cole Hersee solenoid relay #24213. $37.
    Best Choice 10-ton crimper. $48. (looks identical to other 10-ton crimpers with diff labels.)
    Fastronix military type battery connectors. The $31 kit for one battery and $7 x2 solo connectors for the other.
    Wirthco metal battery tray. $13.
    DROK cigarette lighter volt meters. $8 x2. Already had these, but added them for reference.
    Scoshe fuse holder and Install Bay 500 watt ANL fuses. $23 (fuses come in 10-pack).
    Add crimps, on/off switch, split wire looms and shrink tubing.
    Future purchase: 200 watt alternator from BNR Parts, an eBay vendor. $195. ($215 for 250 watt model.) Free shipping. They have a 99.9% positive rating and a feedback score of 11209; so, I think they are worth the inherent risk. Plus, their warehouse is a two hour drive from me.
    Here is a pic of my installed battery tray. Used mending brace, L bracket, and washers to level it. Had to get rid of air duct - may have to replace when getting smog inspection. Top spacing is barely 8 inches; my group 24 battery fits but terminals are too close for comfort with hood clearance. Will likely use group 34 battery.
    Crom likes this.
  19. Feb 24, 2016 at 7:06 AM
    #939
    abarber11
    ATX
    2011 DCSB
    I apologize, my mistake I forgot how the original setup was from the factory. You will replace the alternator to fuse panel wire and run that straight from the alt to the battery. Then you can leave that little, short 4 gauge wire connected from the battery to the fuse panel and it doesn't need an upgrade if you do it that way.
    Then there will be 2 factory wires connected to the battery that don't need upgrading. They are positive terminal to starter solenoid and positive terminal to fuse panel. Those 2 are not part of the charging system.
  20. Feb 24, 2016 at 10:52 AM
    #940
    Chuy
    Lakeside, CA
    Silver Taco
    Since there are only two wires connected to the battery post and one goes to the starter, it stands to reason the smaller wire, the one to the fuse panel, is what carries current to charge the battery. Now, I haven't taken the harness apart, are you saying the starter wire has a connection to the to the alt? From a quick inspection last weekend, it didn't appear that way. I found a youtube video showing how to replace the alt fuse; it's under the fuse panel and it appears the short wire connects to one end of it - the same end but at the bottom of the bolt, out of view, where the alt wire comes into the fuse box. I'm gonna take the panel apart this weekend and see if I can replace that short wire with two gauge, unless I can see the alt connects to the starter wire. https://www.youtube.com/watch?v=LO9UgFbt1tY&index=2&list=WL
