Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. May 2, 2016 at 8:52 PM
    #1081
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Which dual battery controller?
    Pretty sure a 12 volt battery is not going to like having a 22 volts source connected to it. Do the panels have their own voltage controller?
    FWIW, I am no guru...
  2. May 2, 2016 at 9:26 PM
    #1082
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    4.8 watts and 22 volts? So 0.22 amps? FWIW I have a 50 watt panel and its not nearly enough to help with any charge at all. It gets up to 13.2 volts but unfortunately doesn't do anything to charge the batteries. As far as I know the northstar AGMs, for instance, need about 14-15 volts and 7+amps and more is better. That's right around 100 watts or more. I've heard a rule of thumb of a minimum 1 watt charging per amp hour for solar.
  3. May 3, 2016 at 4:41 AM
    #1083
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
  4. May 7, 2016 at 9:42 AM
    #1084
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I tried to update the OP as best as I could - for now. There are several more details I'd like to add in there, which I will eventually. If anyone has any input and wanted it included in the OP, or if you find any mistakes in the OP, please let me know.
  5. May 7, 2016 at 10:55 AM
    #1085
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Thanks for taking it over. Looks good
    I had a dual battery setup on the front corner with a promarine iso. After a bit of wheeling I started getting a separation of the fender/core. It puts alot of wieght on an unsupported area. So I moved one battery behind the passenger side rear seat and will be rewiring this next week. Click the pic below for the build link.
    MJonaGS32[OP] likes this.
  6. May 7, 2016 at 11:19 AM
    #1086
    MJonaGS32
    MJ
    SF Bay Area (East)
    Yea that was one of major reasons why I mounted the 2nd battery on the passenger side (under hood).
    Anyone that jumps their truck (not me) or any other LT-type driving may consider evening out the weight distribution, if not relocating one or both batteries.
    CVYota[QUOTED] likes this.
  7. May 7, 2016 at 1:54 PM
    #1087
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Jumping? Who said I have had all 4 tires off the ground at the same time? :anonymous:
    Unfortunately, my 11 has the abs on the pass side, so I put my winch solenoid in the tiny spot left over.
  8. May 9, 2016 at 9:21 AM
    #1088
    MJonaGS32
    MJ
    SF Bay Area (East)
    Yea I didn't have any space over there either. Had to relocate the PS fluid reservoir
    before:
    after:
    Thelgord and scott96929 like this.
  9. May 9, 2016 at 2:43 PM
    #1089
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    This is an amazing idea! :thumbsup:
    MJonaGS32[QUOTED][OP] likes this.
  10. May 9, 2016 at 3:04 PM
    #1090
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    That turn out nice. I put mine behind the back seat:
  11. May 9, 2016 at 5:46 PM
    #1091
    Thelgord
    Augusta, GA
    Are you worried about the battery out-gassing? I know old Oldsmobile and VW Bugs had batteries in the back seats, but they also had a sort of drain tube in case the battery out-gassed hydrogen. Or something like that.
  12. May 9, 2016 at 5:49 PM
    #1092
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i think most use a AGM battery which are gel and that shouldnt be a problem?
    abarber11 and ebbs15 like this.
  13. May 9, 2016 at 5:59 PM
    #1093
    Thelgord
    Augusta, GA
    I honestly don't know. If anyone has information on this I would greatly appreciate it as it open new mounting locations.
    CVYota likes this.
  14. May 9, 2016 at 6:38 PM
    #1094
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    The optimum is a sealed battery with dry, spiral cells, it is designed to go into interior locations and be mounted in any position. No gases, no water. Do not try this with a regular battery.
    samiam and Thelgord[QUOTED] like this.
  15. May 9, 2016 at 7:02 PM
    #1095
    Thelgord
    Augusta, GA
    Cool thanks :)
    CVYota likes this.
  16. May 10, 2016 at 6:54 AM
    #1096
    Spansfelder
    Spansfelder Well-Known Member
    Austin, TX / Germany
    05 4WD
    Would you happen to have pictures of the tray? I am assuming it is self made?
    What size battery would fit there?
  17. May 10, 2016 at 8:10 AM
    #1097
    MJonaGS32
    MJ
    SF Bay Area (East)
    I don't have pictures of the tray I made, but it just made out of ABS plastic that I had laying around. Here is what it looks like with the PS reservoir removed
    You can see the top of that area is elevated ~2". The plastic tray I made kinda looks like this (I used different colors to show the two pieces I had laying around - put together with screws):
    Although it's plastic, it's super thick ABS plastic and it's bolted to the truck using some of those existing holes. The Optima is a group 35 and as you can see in the previous pic, it's a snug fit.
    Here's a picture of the PS reservoir in it's new place. Just took the existing bracket and moved it, no modifications to it, although I needed longer hoses (2 diff sizes).
  18. May 10, 2016 at 9:07 AM
    #1098
    Spansfelder
    05 4WD
    Thanks for the detailed description, I was hoping to fit a bigger battery than the 35.
    Ordered the Columbia Overland tray, but that also limits me to the 35's....
    I might use that way to mount a third battery later down the road.
    This might be a dumb question, but is there any reason not to mix an AGM battery with a standard lead battery?
  19. May 10, 2016 at 8:33 PM
    #1099
    Digiratus
    Roaming the PNW
    The RedHead
    I have a question for those using a BlueSea 7622 ML-ACR.
    When you have your red switch set to the middle setting (both batteries linked), what I think of as auto mode, and both batteries are fully charged, and you shut off the engine, how long does the ML-ACR leave your setup linked?
    I guess, I am asking, does it separate them immediately (less than 5 minutes) or does it take a while, say a couple of hours or does it stay linked, what I would call a long time, say 48 hours or longer?
    The scenario I am describing is, you are parking the truck in your garage and not using either battery for anything during this time so there is no external drain to speed up the process.
  20. May 10, 2016 at 9:37 PM
    #1100
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    I actually just looked into this like an hour ago. I'm getting a dual battery kit from OGE and it uses the ML-ACR, and was wondering the same thing. From my research, and I'm not sure which model it was specifically or if there's a difference for that matter, it links them at 13v detected for 2 minutes, indicating a charge is detected(vehicle running). It opens the relay at 12.75v detected for 30 seconds. So in a perfect world your battery should be at 12.7v, at rest, but it's not. So I would assume it would disconnect them 30 seconds after the vehicle is shut off. This is what I gathered from my research.
    Here's the link that I got the info from...
    https://www.bluesea.com/resources/1366
    HeliMedic likes this.
