Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Dec 20, 2016 at 8:07 PM
    #1441
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    :rofl::rofl::rofl:
    Jim Bob likes this.
  2. Dec 23, 2016 at 7:39 PM
    #1442
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    DaveInDenver and Thelgord like this.
  3. Dec 26, 2016 at 4:54 PM
    #1443
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Off Grid dual battery going on-
  4. Dec 28, 2016 at 7:34 AM
    #1444
    orafrith
    orafrith Well-Known Member
    Keep the pics coming
    BountyOR_VF2 likes this.
  5. Jan 10, 2017 at 9:22 AM
    #1445
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    Some pics of my setup. Also posted in another thread. IMG_0636.jpgIMG_0636.jpg IMG_0637.jpg IMG_0653.jpg
  6. Jan 10, 2017 at 10:17 AM
    #1446
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Yeah. Mine is home made too. With the Wirthco tray. See OP. I think there's a link to my setup.
  7. Jan 13, 2017 at 6:18 AM
    #1447
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    Battery Mart is the cheapest place I found them
  8. Jan 14, 2017 at 2:36 PM
    #1448
    Kilroy
    Kilroy Well-Known Member
    Dango
    Republic of Texas
    Silver 2013 TRD Off-road DCSB
    Stuff and things.
    Subd for reference.
  9. Jan 15, 2017 at 10:27 AM
    #1449
    Sandman614
    Tim
    '06 SR5 Off Road
    Should I ground 2nd battery in bed of truck to the frame or run a ground wire to the 1st battery? *note: system not designed to self-jump-start.
  10. Jan 15, 2017 at 10:40 AM
    #1450
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I did both, and to the engine block as well, but my system is designed to start the engine. I would still wire to all three points, just not be too concerned with wire gauge, maybe 4AWG.
  11. Jan 15, 2017 at 10:43 AM
    #1451
    Sandman614
    Tim
    '06 SR5 Off Road
    Well that sounds redundant. I know the body and engine are grounded. The frame has to be grounded somewhere because I hookup all accessory (lights, etc) grounds to the frame.
  12. Jan 15, 2017 at 6:04 PM
    #1452
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If anyone is looking for a good deal on batteries Sam's is having a sale... at least the Sam's in my area is..
    tacomgee and Whitecloud like this.
  13. Jan 15, 2017 at 9:34 PM
    #1453
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I ran a full ground cable (1/0) all the way back to the starting battery. The last thing I wanted was to create potential ground gremlins.
  14. Jan 17, 2017 at 3:43 AM
    #1454
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Subd.
  15. Jan 21, 2017 at 6:12 PM
    #1455
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    I had a 31M in service, then installed a dual battery system, with a 35 as the start battery. Used this un-even combo (35/31M) about ten months. Last week i swapped out the 31M for a second 35. After about 5 days, I turned off the truck in the parking structure at work, and my winch began beeping. only way to stop the beep was to lock off the ML-ACR. With a hand-held voltmeter I get 12.9V on the start battery with engine off. With engine running the start battery reads 14.2V. The new 35 does not read any volts. I can get the winch to work with the ML-ACR in the ON position, but without the start battery connected the winch won't run...
    The curious thing about the new 35 battery is the positive terminal rotates relative to the plastic case. I was thinking maybe the shiny brass color post is a thread-on cap over the real battery post and is just not threaded on properly. I do not think the battery post should be moving at all, but I don't know how these units are put together.
    Any ideas about battery post movement?
  16. Jan 21, 2017 at 6:18 PM
    #1456
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    They should NOT be moving
    Sandman614 likes this.
  17. Jan 21, 2017 at 6:20 PM
    #1457
    Sandman614
    Tim
    '06 SR5 Off Road
    correct, get it warrantied
  18. Jan 22, 2017 at 12:37 PM
    #1458
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    Took the battery out of truck. the Terminal is a cap and is threaded on, and was moving because it was not threaded on adequately. I have tightened it up. I do get 12.8V across the terminals outside of the truck. There must be some other issue in my winch wire-up, explore further.
  19. Jan 22, 2017 at 2:50 PM
    #1459
    Sandman614
    Tim
    '06 SR5 Off Road
    Oh weird lol
  20. Jan 31, 2017 at 11:12 PM
    #1460
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I basically did the same but my batteries are under the hood.
    @Sandman614 Look up Big 3 upgrade. I actually did a Big 4 upgrade.
