Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Sep 10, 2017 at 11:19 PM
    #1681
    Snowtrooper17
    Snowtrooper17 Well-Known Member
    Colorado
    '17 White TRD OFFRD V6 4x4 ACLB
    I've combed through this thread and looked at a lot of builds but not seeing what I'm looking for. I'm set on having my aux battery in the bed where I have a removable platform/storage. I have purchased a CTEK D250S rather than a MLR or solinoid which I intend to also locate in the bed as some day I will connect my PV panel to it.
    What I'm looking for examples (pictures preferably) of are the way/path people are routing battery cable from the alternator/starter battery back to the inside of the bed. I would hate to go through the firewall into the cab only to exit the cab(interior) to get into the bed. It would seem running cable and wire loom to the bottom of the engine compartment and underneath the cab makes sense. Are people using boots, cable glands or just grommets to go through the composite bed floor or sidewall?
  2. Sep 10, 2017 at 11:44 PM
    #1682
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I don't have dual batteries, but I just used a grommet to penetrate through the bed.
  3. Sep 11, 2017 at 12:39 AM
    #1683
    Arlaghan
    Arlaghan Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    What I would do in your case is try to make a "copy" of this using your CTEK D250S (since this product is only available in Australia, but you can easily build your own using the individual components):
    Then the install is buried in this more in-depth educational video. (I recommend watching it, really explains a lot about the whole technology, but needs an hour of your time.)
    As for me, I will run the wires down from the engine bay, along the frame (path the brake line takes) and then out the bed over the cubbies. I'm following this for inspiration:
    https://www.tacomaworld.com/threads/12v-bed-power-powerwerx-panel-installation.452432/
    Chipskip, ClevSix and Kolunatic like this.
  4. Sep 11, 2017 at 2:47 AM
    #1684
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Run the cable down to the frame then run the cable along the frame to the bed, then drill a hole in the bottom of the bed and route the cable through the hole.
  5. Sep 11, 2017 at 10:50 AM
    #1685
    Snowtrooper17
    Colorado
    This very was helpful in giving me ideas for how to get things together in a semi-permanent install which is my goal. I love the idea of using a fused connection with Anderson Plugs from alternator to the input on the CTEK controller so that I can always have the cables routed without needing to keep the battery and controller on-board full-time. :thumbsup:
    Arlaghan[QUOTED] likes this.
  6. Sep 26, 2017 at 10:13 PM
    #1686
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I’m in need of some suggestions here for my setup.
    I have (2) 34m AGM deep cycle batteries I have already installed but I need help deciding on the isolator or charge controller.
    I like the idea of the DC-DC mppt charge controller shown in the kickass videos above but that is very expensive. I would like to stay less than $200.
    Also I plan to add a 120w solar panel to keep batteries charged while running a 65qt fridge for long camping trips. (Additional cost)
    I have a winch that I only use when the engine is running, so I think it would be best to have both batteries connected while the engine is running so the winch can draw power from both batteries. (Does that make sense?)
    I am thinking that a simple solenoid to disconnect the batteries from each other when the engine is off should work, correct?
    Is it possible to modify alternator to provide 14v of charging?
  7. Sep 26, 2017 at 10:49 PM
    #1687
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    possible to alter the output to 14v by changing location of the voltage sensing wire..
    https://www.tacomaworld.com/threads/boden-build-2015-dclb-4x4.362640/page-3#post-10274246
    DDD[QUOTED] likes this.
  8. Sep 26, 2017 at 11:09 PM
    #1688
    Arlaghan
    Alex
    Redmond, WA
    There are other possibilities for DC-DC chargers that won't break the bank. Assuming one of your batteries is the starter battery, then this could work for you:
    http://www.ebay.com/itm/CTEK-D250S-...UT-/162586167960?_trksid=p2385738.m2548.l4275
    The only drawback compared to say.. RedArc, is its 20 Amps vs 25 Amps.
  9. Sep 29, 2017 at 8:07 AM
    #1689
    DangerClose
    DangerClose Well-Known Member
    2014 TRD Sport DCSB / 2001 SR5 4X4 XC
    @OneFastGeek , which batteries did you use for this? My Oem battery just died and am looking to upgrade.
  10. Oct 2, 2017 at 4:57 PM
    #1690
    Blown383
    Blown383 Well-Known Member
    I'm running the Dirty Parts dual battery kit and Ive been looking for a OEM style switch that'll replace the bulky 3 position toggle switch. Has anyone come across a dual pole dual throw switch that'll fit in the factory slots?
    -B
  11. Oct 9, 2017 at 9:19 AM
    #1691
    MonkeyProof
    SoCal- SGV
  12. Oct 9, 2017 at 9:46 AM
    #1692
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    Sorry, didn't see this till today. Optima Batteries 8071-167-FFP D51 YellowTop
  13. Oct 18, 2017 at 12:39 PM
    #1693
    Echodawg
    Echodawg Well-Known Member
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    I posted this elsewhere but never got a response.
    I am running dual batteries, mainly so I can jump my main if I have a dead battery when camping out in the backcountry. I want to hook up an auxiliary Blue Sea fuse block, to keep the wiring clean for accessories. Should this be wired to the main starting battery or to my auxiliary battery? Anyone have any suggestions?
  14. Oct 18, 2017 at 1:19 PM
    #1694
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It depends on how you set things up and when you want to use your accessories. Generally people setup a starting/Winching battery for truck on accessories and a house/aux battery for truck off accessories .
  15. Oct 18, 2017 at 1:36 PM
    #1695
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    ^ Yup.
    I've got everything that was tied to my stock battery still that way, and all the lights and extra power pull from the aux
  16. Oct 18, 2017 at 11:13 PM
    #1696
    Echodawg
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    That is what I was thinking, run it to the aux. My auxillary battery is on the passenger side of the engine but my Pelfrybilt fuse box mount is near the starting battery. Is there any thing to be concerned with having the fuse block on the other side of the engine bay so far from the auxillary battery?
  17. Oct 19, 2017 at 2:43 AM
    #1697
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Run appropriately sized cable from the aux battery to the fuse block, and you'll be fine.
    Sandman614 likes this.
  18. Oct 19, 2017 at 12:33 PM
    #1698
    Riggiding
    Riggiding Well-Known Member
    Ricky
    So cal
    2016 white Tacoma Trd off-road
    Great thread! So many useful things
  19. Oct 19, 2017 at 8:34 PM
    #1699
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    And put a fuse between the aux battery and fuse block. Put the fuse as close to the aux battery as possible.
  20. Oct 21, 2017 at 4:14 PM
    #1700
    winnili
    winnili Active Member
    Lance
    09 4wd LB tacoma
    leer topper, bedrug much more to come
    Hello everyone I posted this earlier in the 2nd gen group and didn't get a reply and while i'm on a short timeline figured I would post it here.
    Hello,
    First off let me start by saying I went down a 4-6 hour rabbit hole last night researching dual battery setups vs single. I'm the type of guy that likes to plan and think things out but unfortunately my battery took a sh*t yesterday which is forcing me to rush. I plan on running a ARB fridge soon as well as a winch and compressor, I will of course eventually go to a full dual because of accessories i'm going to be running and the ability to jump myself if the need arises.
    This is what i'm considering buying for the now situation though. the Pelfreybilt Battery cage which comes up a lot around here. I'm also looking at switching to the 31M Optima, because i'm in Montana and the other compatibly batteries aren't as available that would work in the battery cage.
    Will my standard leads work switching my 2009 Tacoma Group 27 leads over? (I realize this might be a stupid question however I do not mix with electrical)
    Should I change any other components out?
    Things I should know about a Optima Maritime blue top in Montana Winters?
    Will my stock alternator do OK will the increase in Battery Size and charging? Is this going to have any negative effect on the battery?
    Thanks as always for the help as you guys are bad for the bank account but good at helping me not mess things up.
