Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jul 12, 2014 at 11:01 AM
    #161
    Linus
    Linus Well-Known Member
    Pierce County, WA
    '13 DCSB TRD 4x4
    Relentless front/rear armor and skids, CVT hardshell RTT, BAMF slider, ENGO EPF10k winch, dual batt, OME 886 & Dakar leafs, ARB 63qt fridge w/ rear seat mount, BajaRack, ARB awning, Pioneer audio
    The main batt is nearly empty. Lots of heavy gauge on the aux batt wired to front & rear winch, a stereo amp, and I went with double cables from each 7622 terminal to the battery positives, in order to meet the continuous amp load for winching when batteries are combined. Had some extra so I figured it couldn't hurt.
    Time to wire the control. I guess I'll leave the brown wire start for isolation out of it, and just let it run auto until I figure out that wire location.
  2. Jul 12, 2014 at 1:58 PM
    #162
    Linus
    Pierce County, WA
    '13 DCSB TRD 4x4
    I'm going with the same concept, just two things to mount. This little monitor took forever to get there from S. Africa (ebay), $25 with shipping I think. It'll fit real well next to the Blue Sea switch.
    adventureclassicsla likes this.
  3. Jul 12, 2014 at 8:01 PM
    #163
    skygear
    skygear                    
    My current ( play on words) setup.
    wavytrent likes this.
  4. Jul 12, 2014 at 8:05 PM
    #164
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    You are really on the ball today with the play on words Sky...
    "A lot of terminations...and determination..."
    :laughing:
    Mount looks nice. Did you get the ACR mounted yet or just placed under there for now?
    EDIT - I see in the RFRM thread it is mounted...looks sweet!
  5. Jul 12, 2014 at 8:09 PM
    #165
    skygear
    skygear                    
    Look in the RFRM thread. I posted a pic of the mount hanging after I sprayed it.
    So, yes, mounted it. That corner is done til I get a Contactor.
  6. Jul 12, 2014 at 8:13 PM
    #166
    CanisLupus
    Stokesdale | NC
    ^^ Saw it right after I posted.
    :thumbsup:
    PS - I think the lights on my dash may have just been a fluke...they didn't come back on after I stopped for food, so hopefully they stay off. Will disconnect/reconnect battery if they pop up again though.
  7. Jul 12, 2014 at 8:14 PM
    #167
    skygear
    skygear                    
    Awesome. Glad it all worked out then.
  8. Jul 17, 2014 at 2:00 PM
    #168
    Linus
    Pierce County, WA
    '13 DCSB TRD 4x4
    Finished the Blue Sea 7622 install today. 4avevu3u_0b87ccb6f60317b5182bcd3383741f00456cd798.jpg
  9. Jul 17, 2014 at 2:52 PM
    #169
    skygear
    skygear                    
    Did you figure out the wire?
  10. Jul 17, 2014 at 3:11 PM
    #170
    skygear
    skygear                    
    Have a link for that too?
  11. Jul 17, 2014 at 3:18 PM
    #171
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Technically you probably don't need the start isolation feature. That is really meant for boats in which you might be cranking for a while. If you have a truck that works well and starts without extended cranking, it is not needed. What I was told by Blue Sea is that when you are cranking if you notice accessories like your radio fading out, go ahead and hook it up. They said it was far more applicable to using in a boat than a fairly modern vehicle.
  12. Jul 17, 2014 at 3:22 PM
    #172
    skygear
    skygear                    
    Makes sense.
  13. Jul 17, 2014 at 3:25 PM
    #173
    Linus
    Pierce County, WA
    '13 DCSB TRD 4x4
    tacoma16, Bobcdn and Manwithoutaplan like this.
  14. Jul 17, 2014 at 3:31 PM
    #174
    Linus
    Pierce County, WA
    '13 DCSB TRD 4x4
    Now that I have it all hooked up, I realize you're right. The built-in delay negates the need for what seems to be an extended delay "start isolation" feature. Just the standard wiring seems to be at least 30 seconds before the switch closes, but I haven't timed it. Guessing it closes after the main batt recovers from the cold cranking, and would probably vary based on the charge/main batt level.
    I ended up not using those other wires and insulated them separately.
    Manwithoutaplan likes this.
  15. Aug 8, 2014 at 10:13 PM
    #175
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Wow. Reading though this whole thread is like looking at one of my grandma's old quilts. Is this a conglomeration of several threads? Because I'm curious what mod allowed that? :facepalm: LOL.
    But I digress...
    Curious what you guys have been using as a battery maintainer/charger?
  16. Aug 8, 2014 at 11:20 PM
    #176
    skygear
    skygear                    
    Yes, this was a similar thread to every other thread thats a 'Show Us YOUR.... Shell, 35's, black rims, tires, etc. ' SO yes. this is a conglomerate of threads all in one that I copied and pasted together. This was not a HOW TO thread by any means.
    Battery Charger/ Maintainer. - Haven't needed it yet, but I have an OPTIMA 1200 Battery Maintainer floating around somewhere.
  17. Aug 9, 2014 at 12:55 AM
    #177
    skygear
    skygear                    
    I wanted that 400 version they sell. It is only 4amp charge. VS the 12 amp in the 1200. Would have been slick to put that hardwired in. i like a faster charge.
    Another down side to the Optima versions. They only charge 12v batteries, nothing else. i originally wanted something that covered the full range, just in case I had to help someone else. Was thinking of adding 6v cells for the solar.
    http://www.optimabatteries.com/en-us/products/charger
  18. Aug 9, 2014 at 9:36 AM
    #178
    License2Ill
    Ian
    Alright. It may be helpful it you linked the original threads that had the bulk amount of posts. Not the posts from the "What did you do today" threads. But maybe the posts with the bulk parts attached. Just a suggestion. I was pretty confused. Haha.
    I'm going to give one of the CTEK chargers a try. A 25A. They charge every type of L.A. battery. I have two of the diehard/odyssey 31M batteries. I've read they need a high amp charge (40A) which is kind of ridiculous And I've heard quite a few instances of people killing their batteries with a dual setup after a year or two from just charging from dc sources. Not sure of their setups though.
    Stewzz likes this.
  19. Aug 9, 2014 at 10:48 AM
    #179
    la0d0g
    running for the hills
    For crawling not hauling
    Don't like the thread? GTFO and stop reading it.
  20. Aug 9, 2014 at 11:11 AM
    #180
    skygear
    skygear                    
    On the subject of links. The quotes are links to the original posts. By all means though. If you want to organize this thread, do so. Then post up the organized links and such and I will update the OP with your post and credit you for it. There are already tons of subscribers to this thread. No sense in making another.
    As for the charger, I would like to see the links to the one you mention. Plus if you have links to the data you mentioned on charging amperage. That would be useful. I was under the impression charging amperage was only relative to duration of the time. Then again sulfation issue etc.
