Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. May 10, 2018 at 6:27 PM
    #1881
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    did the install finally
    SonnyBones likes this.
  2. May 16, 2018 at 8:10 AM
    #1882
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Where do I buy that?
    tacoma16[QUOTED] likes this.
  3. May 16, 2018 at 10:14 PM
    #1883
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    tacoma16 likes this.
  4. May 25, 2018 at 5:32 PM
    #1884
    Lilikoibars
    Lilikoibars Well-Known Member
    2006 Off Road
    Anyone out there have tips for the ABS relocation? I've seen it moved back closer to the firewall in order to fit a battery tray and keep the stock air duct. It's the best space to put a second battery; I already have a compressor between the radiator and washer tank.
  5. May 26, 2018 at 5:06 AM
    #1885
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Personally I think it’s the best locating for a second battery. The abs module is not to hard to push out of the way. A small Wilco battery tray, and some cutting and can get one to fit 328F98DD-E404-4F81-A906-9A1882F1D631.jpg
    Brandon.C.H, Cadmus and POOLGUY like this.
  6. Jun 6, 2018 at 7:34 PM
    #1886
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    The small black switch next to the voltmeter, is that for switch it on? I was wondering how to avoiding it on all the time, so I think this is the solution.
    Please correct me if I'm wrong.
    wmg likes this.
  7. Jun 10, 2018 at 1:43 AM
    #1887
    wmg
    wmg Well-Known Member
    bill
    2009 FJ
    BP-51 OEM LIFT..33;s...full skids....dual Batteries
    finished my console mod or "cup holder... we doan need no stinkini cup holder" been done for awhile, moved the battery ACR switch and everything else onto one mounting ...
    xsf18cdf, jubei, SonnyBones and 5 others like this.
  8. Jun 10, 2018 at 3:53 AM
    #1888
    wmg
    bill
    2009 FJ
    Yup that is an MT wallet in the picture....
  9. Jun 14, 2018 at 6:52 PM
    #1889
    coleone32
    coleone32 Well-Known Member
    Nick
    90640
    2015 Tacoma! First Toyota ever.
    Only The Good Things! Alot more needed...
    Hey guys I want to get in on this group buy for 2 batteries, but I got one problem, and that is what SIZE batteries can (or should) I get? I'm going to go with the Off-Grid side mount for the aux battery and also the front mount with the bluesea mount. I greatly appreciate any input, I already have 2 amps, adding led lights very soon, and also to have some room to grow... I h8 you tacomaworld haha
    oh this is what I'm putting it in 2015 crewcab 4x4 offroad trd
  10. Jun 14, 2018 at 7:15 PM
    #1890
    wmg
    bill
    2009 FJ
    -2- Odyssey 35-PC1400 Battery
    Additional Specs:
    • 850 CCA, 950 MCA, 1150 HCA
    • 1400 Cranking Amps for 5 Seconds
    • 130 Minute Reserve Capacity
    • Cycle life @ 77° F 400 at 100% DOD
    • -40° F to 140° F Temperature Range
    • More Specs: (Adobe PDF)
    • Made in the USA
    BM Part #: 35-PC1400
    Made In: U.S.A.
    Voltage: 12 Volt
    Capacity: 55 Ah
    Type: AGM
    Battery Size: Group 35
    Length: 9.46"
    Width: 6.84"
    Height: 8.69"
    Cold Cranking Amps: 850 CCA
    Shipping Weight: 54.00Lbs
    Warranty: 4 Year (Warranty Info)
  11. Jun 14, 2018 at 7:22 PM
    #1891
    coleone32
    Nick
    90640
    Thank You kind sir
  12. Jun 14, 2018 at 9:11 PM
    #1892
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Which group buy? The one for the Northstar batteries?
    I am pretty sure the group 35 Northstar's are same dimensionally as the Odyssey PC-1400s and very similar specs too. Should fit like a glove in the Off-Grid kit.
  13. Jun 15, 2018 at 5:40 AM
    #1893
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Your dual battery setup looks very nice. I really like the neatness of the wiring.
    So I gotta ask...
    What are you venting in your oil filler cap?
    What are you filtering in your oil catch can line?
    OmegaMan73 likes this.
  14. Jun 15, 2018 at 6:01 AM
    #1894
    wmg
    bill
    2009 FJ
    oil catch line filter is a gas line filter with the basket removed, used as a sight glass , when it starts to show oil on the glass the can is full enuf that it is starting to carry over,,,a just in case thing....
    oil filler line is the return line from the by pass filter.....its a 98% eff at 2 micron oil filter that functions full time at a reduced flow..Oil is supplied from the oil pressure switch port using a tee ....IMG_0278 (1).jpg IMG_0268.jpg
  15. Jun 15, 2018 at 6:02 AM
    #1895
    wmg
    bill
    2009 FJ
    btw tnx.....
  16. Jun 15, 2018 at 6:16 AM
    #1896
    Scott B.
    Scott
    Georgia
    Sight glass - makes sense. I have never overfilled my catch can, but have come close. That is a good idea.
    A friend of mine runs a bypass filter. Another good idea...
  17. Jun 15, 2018 at 6:21 AM
    #1897
    wmg
    bill
    2009 FJ
    I run a 10K Amsoil syn, pull a sample for testing at 5K, dump the can then.....but nice to see real time how the system is working and if it needs to be dumped...
    Retired Utility plant/Ultra Pure Water plant /Waste Treatment plant manager...been messing with oil in that capacity for a few years
  18. Jun 15, 2018 at 6:25 AM
    #1898
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    YES- I guess I didn't realize how easy it was to do this. Any more info/write up?
  19. Jun 15, 2018 at 6:41 AM
    #1899
    Scott B.
    Scott
    Georgia
    Do you change your oil filter at 5K? My friend changes his at 3K or 4K (I forget which) and adds a quart of oil at the same time.
  20. Jun 15, 2018 at 6:51 PM
    #1900
    YamaDirtrider
    Josh
    Elizabeth CO
    Don’t really have a right up, just made the space for it to fit. I used a WirthCo 21085 Battery Tray
    https://www.amazon.com/dp/B00JPJHUHS/ref=cm_sw_r_cp_api_i_iLLiBbZTC2K5R
    Then had to cut off the one mounting foot for the air box. Then once the abs modul Mount was removed I cut and grinder the 2 studs that are welded to the fender, this allowed for the try to sit flat. 8C671997-67C8-4788-B9B8-37ED5499ECFA.jpg
    Once the mount is out I drilled out the 2 spot welds on the flat bar mounting foot. Repurposed this piece to extend the lower mounting. B9720784-279D-4A8D-BDF1-719F63B861BB.jpg
    Assembling everything back together I drilled 2 holes in the battery tray to mount one side of the abs bracket to not only secure it but also the tray. 0C08C150-A06C-4744-B21D-592BD5A22867.jpg
    This gave enough room for a standard optima (group 35) to fit.
    Bent a price of steel to make a battery hold down. Drilled a hole in the fender and added a riv-nut so it’s secure and easy to remove when the time comes. 8F6D86E4-8737-42A7-B6FB-0A70B8B9BF2C.jpg
    Brandon.C.H likes this.
