Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jul 13, 2018 at 4:16 PM
    #1941
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Thanks! I was hoping so since I'm about 2 feet shy of enough 0 awg to run a second line to the fuse block from the batt in the bed. So could I run a jumper from isolator to fuse block? They are about 6 inches from each other. I figured crimp, solder, and heat shrink two ring terminals on a 6in piece and call it done. That would be acceptable?
    tacofort likes this.
  2. Jul 13, 2018 at 4:50 PM
    #1942
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Yea. As long as it’s on the same side of the battery you’ll be good
    SamuelJ[QUOTED] likes this.
  3. Jul 16, 2018 at 6:39 AM
    #1943
    360joules
    360joules FWC Stalker
    Troy
    Portland Oregon
    SOLD
    Gents, from some sources I am learning that for a dual battery system it’s ideal to have the same type, size and age of batteries. Yet other sources state that there is a starting battery type and that a different type (AGM) is a better choice for the accessory battery.
    Is one opinion here incorrect or are they both correct, but just different?
  4. Jul 16, 2018 at 6:49 AM
    #1944
    YamaDirtrider
    Josh
    Elizabeth CO
    Both correct, kinda. If you link them via a blue sea ml-acr or simmilar you want them the be the same type, same age and it’s good to be the same size.
    If you link them with a dc-dc controller where they never connect to each other then they can be mid matched.
    Optima, Odyssey and others are agm which is a better battery.
    Most agm’s can and will say if there dual purpose(starting and deep cycle)
  5. Jul 16, 2018 at 6:52 AM
    #1945
    360joules
    Troy
    Portland Oregon
    SOLD
    Excellent. Thank you.
    BEAR_KNIFE_FIGHT likes this.
  6. Jul 16, 2018 at 6:57 AM
    #1946
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    From what I have read and heard, if you have a 'dumb' isolator like the ML-ACR -- dumb in the sense that it doesn't know the differences between battery types -- you should stick to 2 of the same type batteries. With some of the 'smart' isolators/chargers/etc I believe many of them offer the ability to mix batteries to suit your needs. For example, I am running dual AGMs linked with an ML-ACR. I am considering a smaller Li-ion in the bed for the fridge, and planning on linking this battery to my solar system and aux AGM battery with a smart system -- I think CTEK offers one that works well.
  7. Jul 16, 2018 at 6:07 PM
    #1947
    yorkshiredoughboy
    yorkshiredoughboy Well-Known Member
    Yorkshire
    2017 TRDORDC
    Hello All, I'm interested in running a 12v cooler off of a second battery, can you point me to the most practical setup I could run to add a 12v outlet in the bed?
    Thanks I'm reading through the thread but didnt see anything yet.
  8. Jul 16, 2018 at 7:28 PM
    #1948
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    It's not that simple of a question to answer.
  9. Jul 16, 2018 at 8:00 PM
    #1949
    360joules
    Troy
    Portland Oregon
    SOLD
    Thanks for this info. What CTEK are you looking at?
  10. Jul 16, 2018 at 8:19 PM
    #1950
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  11. Jul 16, 2018 at 8:53 PM
    #1951
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
  12. Jul 17, 2018 at 10:32 AM
    #1952
    cynicalrider
    cynicalrider #NFG
    Jersey
    Where are you guys sourcing battery cages for 24f's? I looked everywhere and all that was coming up was for 34's like trail gears.
  13. Jul 17, 2018 at 11:34 AM
    #1953
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    I ran the perfect switch single rectifier for a couple years and switched over to the ML-ACR. You can’t unlink the batteries with the perfect switch nor could you use the house battery to start the truck unless you swapped the batteries out or ran jumper cables. I’m much happier with the ML-ACR.
  14. Jul 17, 2018 at 12:19 PM
    #1954
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    According to this chart, the two sizes are very close dimensionally. I am guessing a cage made for a group 34 will also work (or be made to work) with a group 24.
    https://www.jegs.com/Sizecharts/bcigroup.html
  15. Jul 17, 2018 at 12:21 PM
    #1955
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    Not for a Tacoma, although they make a Tacoma kit as well.
    This is from Genesis Offroad.
  16. Jul 17, 2018 at 12:28 PM
    #1956
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I compared northstars dimensions to trail gears cage and it looks like I'd def need to mod it. Even their 24F I got from them is different dimensions from my current 24F I have in the truck. I need to modify my box that holds my winch solenoid in order to get it in the truck. It's a little longer and a little thinner, but the bottom footprint is still the same size.
  17. Jul 17, 2018 at 1:18 PM
    #1957
    Digiratus
    Roaming the PNW
    The RedHead
    That's true. I found Northstar and Odyssey (same dimensions) 24Fs to be slightly taller than other 24Fs. It could be an AGM thing. :notsure:
  18. Jul 17, 2018 at 4:34 PM
    #1958
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
    how is the ML-ACR a "dumb" isolator? Per blue sea's website, I was under the impression that it has a "smart sense" both battery banks to automatically manage the charging of each battery. If it is able to do this, why is it not ideal to have two different batteries for this type of isolator?
    It seems like most people here go with the ML-ACR so that means that they all must get two idential batteries to run with it, which seems to be a more expensive option as far as the dual battery system goes (having to buy two batteries instead of just one for aux use). Why are the other isolators considered to be "smart" and to be safe with two different batteries not more popular in general over the ML-ACR?
  19. Jul 17, 2018 at 6:05 PM
    #1959
    YamaDirtrider
    Josh
    Elizabeth CO
    By dumb it’s meant that when the batteries are connected it’s no different than running a wire between the two. The alternators is the one that charges both batteries.
    A “smart” system takes power from the main battery and sends it to the aux battery. The 2 batteries never know the other exists.
    A relay is a “dumb”
    The ml-acr is an over glorified relay.
  20. Jul 17, 2018 at 7:05 PM
    #1960
    MrCrowntown
    Alyn
    Ky
    Good feedback, thanks! I've been shopping around and it popped up.
