Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Jul 17, 2018 at 9:11 PM
    #1961
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    To carry the analogy further along, if a simple relay is considered 'dumb' and an ml-acr is 'smart', then a DC to DC charger is a 'genious' because it has the ability to maintain optimal battery health with dissimilar types of batteries.
    If you must run a traditional, wet-cell starting battery and want to run a big, deep cycle AGM type as an auxiliary, then the DC to DC charger is the optimal choice because it takes the power from the alternator and manipulates it so that the AGM can be fully charged without damaging the wet-cell starting battery. Another plus is that most of them can easily manage the addition of a solar panel.
    The only real downside I see to a DC to DC system is you can't self-jump or link the batteries together for winching which are big reasons for going the ml-acr route. That and its 500 amp continuous load capacity.
    tacofort and crymes[QUOTED] like this.
  2. Jul 18, 2018 at 5:26 AM
    #1962
    crymes
    crymes Well-Known Member
    Cameron
    CT
    2017 TRD OR DCSB QS
    thank you!! thats frustrating that you cant self-jump and winch with DC-DC but on the other hand i DO want to do a solar panel in the future...just wanna have my cake and eat it too...decisions decisions
  3. Jul 18, 2018 at 5:45 AM
    #1963
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    You can do the dc-dc charger and run a heavy gauge wire through a continuous duty or a starting relay (both Shound be good around 200A) that way the battery’s charge off the dc-dc but you can have a switch in the cab to link them when needed
  4. Jul 18, 2018 at 5:52 AM
    #1964
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If your batteries are relatively close you can always use jumper cables. I'm not sure the ability to parallel your batteries from the cab is really all that important TBH. It's more important to have a system that works to keep batteries charged and protects the starting one from ever going dead in the first place.
    jubei and tacofort like this.
  5. Jul 18, 2018 at 5:58 AM
    #1965
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    This is my plan as well. Using only the ML-ACR to charge the auxiliary battery tends to leave the aux battery not fully charged.
    My question is, do you need to disconnect the DC-DC charger when the batteries are tied together through the relay?
  6. Jul 18, 2018 at 6:27 AM
    #1966
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Most practical? Probably not...But:
    I have two 6v Trojan T105s in series in my bed (cost about $90 ea. from local golf cart place). These are hooked up to an A/B switch in cubby, with truck main battery on other pole. The two trojans (225ah) will run my edgestar 43qt fridge for 3-4 days by themselves. I keep two flexible plastic 100w solar panels in the back and put them on the roof rack whenever Im parked. 3-4 hrs of sun a day is enough to charge to batteries and run the fridge pretty much indefinitely.
    OneFastGeek, tacofort and Chipskip like this.
  7. Jul 19, 2018 at 6:03 PM
    #1967
    yorkshiredoughboy
    yorkshiredoughboy Well-Known Member
    Yorkshire
    2017 TRDORDC
    Apparently, I'll keep reading.
    ClevSix[QUOTED] likes this.
  8. Jul 19, 2018 at 6:08 PM
    #1968
    yorkshiredoughboy
    Yorkshire
    2017 TRDORDC
    Thanks, I'll add it to the list of possibilities, I would like to have one battery on the passenger side (2017 Off Road) where there is a lot of room already. Looking at mounting options is my first step I guess?
  9. Jul 19, 2018 at 7:25 PM
    #1969
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Good idea
    Figuring out how much power do you need is probably the best place to start. What do you want to run and for how long... Meaning how many watts for how long? I would suggest going at least 10% or more over your minimum power needs.
    Once you know your power needs then you can figure out what battery and charging combinations will meet your needs. Find locations for things to fit.
    Personally I prefer to run a DC to DC charger for the Aux/House batteries.
    Good luck and if you have more questions let us know.
    tacofort likes this.
  10. Jul 19, 2018 at 7:31 PM
    #1970
    yorkshiredoughboy
    Yorkshire
    2017 TRDORDC
    Right now I just want to be able to run my electric cooler overnight and while stoped for a few days. Eventually I will upgrade to a refrigerator but for now that’s all I need. I defiantly want to have a battery under the hood on the passenger side and to run an outlet for the cooler to the bed.
  11. Jul 20, 2018 at 4:45 PM
    #1971
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Where to you guys get your welding cable?
    Remy Battery is out of stock on 1 awg.
    Lowes does not carry 1 AWG.
    Fastenal wants $5/ft for a 1wg welding.
    Thinking about sizing down to 2 awg from Lowes. It's not specified as welding wire so I don't know if it will be as flexible as I need it to be.
    I've never heard of Temco, but I could get 80 ft of 1 awg for $150
    https://smile.amazon.com/dp/B01JMNKT7O/ref=twister_B01JMNKHVC?_encoding=UTF8&psc=1
    edit: Screw it. I'm going to go with Temco off Amazon. Hopefully it won't burn the truck down.
    parsonsjr likes this.
  12. Jul 20, 2018 at 6:03 PM
    #1972
    YamaDirtrider
    Josh
    Elizabeth CO
    I bought all more wire/ terminal ends from temco on eBay. Was cheeper Than Amazon
    SportsmanJake[QUOTED] likes this.
  13. Jul 20, 2018 at 9:47 PM
    #1973
    Digiratus
    Roaming the PNW
    The RedHead
    Crimp supply...
    https://www.amazon.com/dp/B0161NX786
  14. Jul 21, 2018 at 11:39 AM
    #1974
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I checked a few places and got conflicting answers so I just went with 0 awg ofc amplifier power wire from a buddy who owns an audio shop. I hope this doesn't become a mistake down the line. The main thing catching my attention was how low of a temp rating the other wires insulation had. The wire I ended up going with had almost double the temperature rating and since I ran along the frame rail and up the firewall under the bonnet I figured the higher rating the better. I dont have a fridge or winch yet but between my audio and lighting I guesstimated the wattage use and added 15% for good measure. When I do go fridge and winch add on I dont know what the hell Im going to do.
  15. Jul 21, 2018 at 11:44 AM
    #1975
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    I have just by happenstance two yellowtop dual purpose agms. Same size and age but heard if it isnt a "dual purpose" agm that some people have had problems using a deep cycle as thier starting battery. I could be wrong but I believe the dark grey case yellow top optimas are not for starting while the light grey case yellow top is dual purpose.
  16. Jul 21, 2018 at 11:45 AM
    #1976
    golfindia
    Yes.
    pickup truck
    Most fridges are 4 - 5 amps. 0 awg should suffice for that. ( ;^)
    SamuelJ likes this.
  17. Jul 21, 2018 at 11:59 AM
    #1977
    YamaDirtrider
    Josh
    Elizabeth CO
    First off ofc is a joke. Sounds good and can charge more for no benefits.
    0awg for a second battery in the bed is fine. 2awg wound work well but the larger the better so Your good. Factory winch wire are ~4awg... but not meant to run long distances
  18. Jul 21, 2018 at 1:24 PM
    #1978
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    What you are comparing against and double of what? The best source of large gauge cable locally is welding supply houses and generally speaking it's the cheapest way to get very high quality cable if you're buying online.
    It's high strand count so it's very flexible. It'll be high quality copper if you buy known brands from reputable places. And the insulation is usually at least 125°C and sometimes 150°C and mechanically very durable, being EPDM rubber.
    Welding cable is pretty the only thing I use for cable larger than 4 gauge. But I only ran a 8 gauge to the bed of my truck and welding cable doesn't go that small so I just used UL1426 marine cable that was rated 105°C. But nothing wrong with J1128 automotive wire, which you can get that up to 125°C.
    If you're using hardware store wire designed for households, then yeah, it's going to be 60°C or whatever since that's all you need for a house. Those types of insulation aren't designed to be as resistant to chemicals and oil, either.
  19. Jul 22, 2018 at 12:49 AM
    #1979
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Good to know about the chemical resistance I didnt think about that but yeah the stuff at home depot definitely didn't look like a good idea. Like you said it isnt supposed to be used in automotive right? Welding cable probably is the best choice, I went with amp wire mainly since I lucked out and got it cheap through a friend.
  20. Jul 22, 2018 at 6:40 AM
    #1980
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Maybe. There aren't really any codes that you must use or have inspected the wiring like in homes, although the rules for marine and RV are probably the best general guideline. So what you have available at Home Depot is often not really intended for automotive use but it may work fine. They sell spools of 90°C THHW PVC hook up wire, which has alright chemical resistance to gasoline and oil (since you might find that in a garage or shop). But being a building wire it's not designed to flex or be in wet condition and stiffens up in cold temperatures, so there are better choices for vehicles. But standard SAE-J1128 automotive wire is also PVC and IMO not really that much better. It's pretty stiff, too, so I prefer using the cross linked polyethylene insulations (SXL, TXL, GXL), which will have better temperature range (and this is what is suggested in the J1128 for use in engine bays over PVC).
    SamuelJ[QUOTED] likes this.
