Dual Battery Setups! Let's see them! Multiple Batteries Thread!
Discussion in 'Technical Chat' started by MJonaGS32, Sep 20, 2013.
  1. Feb 15, 2016 at 3:12 AM
    #881
    docloco
    docloco Well-Known Member
    Ron
    Florida
    2015 MGM DCSB 4x4 TRD OR
    It ended up being M8. Thanks.
    SMKYTXN[QUOTED] likes this.
  2. Feb 15, 2016 at 6:08 PM
    #882
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Something i mounted to up there was m6 i think mabey it was the bolts that hold in the oem fuse box
  3. Feb 16, 2016 at 3:17 PM
    #883
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    I am gathering my supplies for adding a second battery in the bed. Can anyone show me pictures where they mounted the BlueSea ML-ACR? Also what size fuse was used between the starting battery and the ML-ACR. Probably have more questions later as the work begins.
  4. Feb 16, 2016 at 3:26 PM
    #884
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    I didn't fuse between the starting battery and ML-ACR but did from second battery to ML-ACR.
    Used one of these terminal post fuses. Ended up with a 250amp though.
    Hope that helps.
  5. Feb 16, 2016 at 4:10 PM
    #885
    DaveEli
    David
    Virginia Beach
    Thanks, that helps, that's where I was thinking about mounting mine. Hadn't checked the clearance yet. I am going to put the 300A fuse in the bed with the battery. May hit you up with a couple questions later.
  6. Feb 16, 2016 at 4:14 PM
    #886
    Nate87
    Nate
    CONUS
    2013 AC TRD OR
    No problem man. Check out my build thread HERE for what I did to install mine. Any other questions, feel free to ask.
    Crom and DaveEli[QUOTED] like this.
  7. Feb 16, 2016 at 4:21 PM
    #887
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    @DaveEli I personally wouldn't mount if on top of the fuse box. Trying to troubleshoot fuses with something mounted on top of it is a PITA (I used to mount a circuit breaker on top of mine and it sucked).
    I used 300A circuit breakers between both batteries and the ML-ACR
    Crom and DaveEli like this.
  8. Feb 16, 2016 at 4:33 PM
    #888
    DaveEli
    David
    Virginia Beach
    I agree with you but as always space is always at a premium. I have the switch for my winch and compressor on the fuse panel plate. What is your reasoning for the fuse between the first battery and the ML-ACR? I am trying to get the most info I can before I make a decision.
  9. Feb 16, 2016 at 4:36 PM
    #889
    DaveEli
    David
    Virginia Beach
    Thanks again. Checked out your site. Man, I love the way you wired up everything, clean and neat. You must be a little anal like me. I can't stand things not right.
  10. Feb 16, 2016 at 5:25 PM
    #890
    MJonaGS32
    MJ
    SF Bay Area (East)
    Added insurance. Some people have it, some don't. People that have it say that if your ML-ACR goes to shit, your battery is protected. People that don't have it say it doesn't really mater. Doesn't really cost much, and I had space for it.
    I also have a circuit breaker between my aux fuse panel and the aux battery.
  11. Feb 16, 2016 at 5:29 PM
    #891
    DaveEli
    David
    Virginia Beach
    Makes sense, cost is minimal. I have the circuit breaker also.
    MJonaGS32[QUOTED][OP] likes this.
  12. Feb 16, 2016 at 8:06 PM
    #892
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Got some pics? I was thinking about a battery tray with 2 Optima 34's in the stock location. But this could be a nice, balanced option as well.
  13. Feb 16, 2016 at 10:12 PM
    #893
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Here's a quick video I did of the proto. Let me know, I have 4 left.
    https://www.youtube.com/watch?v=VyaPsX-9aB0
    Shmellmopwho and madsand like this.
  14. Feb 17, 2016 at 4:32 AM
    #894
    Subway4X4
    Lloyd
    NY/NJ
  15. Feb 17, 2016 at 4:51 AM
    #895
    Subway4X4
    Lloyd
    NY/NJ
    Ramon - This is cool stuff! How does this tie in with your Bama Stage 1 kit? Hopefully, your writeup is detailed enough for an electrical idiot like me.
  16. Feb 17, 2016 at 5:07 AM
    #896
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ill have to show you, but i already started a thread on this with pictures and writeup
  17. Feb 17, 2016 at 5:14 AM
    #897
    Subway4X4
    Lloyd
    NY/NJ
    Ramon - Where's the thread? I can't find it. But that's normal. I'm not that smart.
  18. Feb 17, 2016 at 5:16 AM
    #898
    ramonortiz55
    Ramon
    Texas
    stock
  19. Feb 17, 2016 at 5:28 AM
    #899
    Subway4X4
    Lloyd
    NY/NJ
    OK. Got it. Told you i'm not that smart.
  20. Feb 17, 2016 at 5:47 AM
    #900
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
