dual fuel tanks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ohdrj1all, May 4, 2011.
  1. May 4, 2011 at 5:57 PM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    gas is lighter then water. at only 6lbs a gallon. the extra weight of the 10 extra gallons is not an issue at all. good luck noticing the gas change.
  2. May 4, 2011 at 5:59 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Thx
  3. May 4, 2011 at 6:02 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    So the Hilux tank fits the taco?
  4. May 4, 2011 at 6:03 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Driving around with an extra 150lb of gas will change your mpg a bit.
  5. May 4, 2011 at 6:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Metric lbs
  6. May 5, 2011 at 5:57 AM
    ohdrj1all
    ohdrj1all [OP] Well-Known Member
    AZ
    2003 XtraCab 4x4 SR5 2.7L 5spd
    That Long Ranger is pretty interesting. Getting one shipped to the US would have to be a pricey undertaking though (unless they have a US distributor).
    I would be interested in even a smaller (say 10 gal or something similar) aux tank. I am surprised that with the popularity of Tacomas with the off-roading crowd that this isn't something more readily available.
  7. May 12, 2011 at 7:11 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Actually, shipping from Australia is cheap; once it gets here you get screwed.
  8. May 12, 2011 at 7:30 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    city yes, freeway no, 4x4ing big time
  9. May 12, 2011 at 8:08 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    looks like they are sold/distributed through ARB
  10. May 12, 2011 at 8:15 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    a pint is a pound the world around. a 60 gallon tank would add a substantial amount of weight to the truck. it depends on your needs if you do alot of long hauls it might be worth while, but 2 5 gallon jerry cans is a better choice imho its way cheaper and you can lose them for when your not driving across the country lol.
  11. May 12, 2011 at 8:35 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Keep in mind the tank itself will weigh a bit too, not just the extra fuel
  12. May 12, 2011 at 8:43 AM
    Wicked 2007
    Bay Area, CA
    that tank is about 80lbs. although not sure how much the factory one weighs to compare...
  13. May 12, 2011 at 8:45 AM
    malander
    max
    01 limited trd 4x4
    Are we still talking dual tanks or just a bigger replacement?
  14. May 12, 2011 at 8:46 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
  15. May 12, 2011 at 9:10 AM
    #35
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
  16. Feb 13, 2013 at 5:26 AM
    #36
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    If you put the spare tire in the bed or on a bracket off the back then a tank from any full size Jimmy or Blazer(1973-1991) will fit in there and you could use the skid plate that comes with them as well. As to switching back and forth, there are switches used on dual tank motorhomes that switch everything over between tanks(power for pump, sending unit, gas and return lines). Might also want to look at the old saddle tanks on a short box chevy.
  17. Feb 13, 2013 at 8:25 AM
    #37
    Barbaro
    Barbaro Active Member
    06 PreRunner DCSB Indigo
    Have you ever thought about a marine fuel tank? Yes they are stainless steel and expensive, but you could probably get one custom made if you wanna fit it under the truck. You are going to have to buy an expensive fuel pump and drill some holes (I dunno how comfortable you are with that).
    I've thought about this and if you put it in the bed you could just use gravity and let that magical force fill your existing fuel tank until the one in your bed is empty.
    You could split the fill-up hose that connects to existing tank with the one in the bed with a one way Y-valve and there you go no pumps or switches needed.
    The bed tank would also be out of the way from potential hazards like rocks and tree stumps.
    In reality I would just buy some Rotopax and attach them to the bed rails and call it a day. Put them in when you need them, take them out when you don't.
